UPS issue
  • ribcage
    • Sep 2020
    • 45
    • Earth
    UPS issue
    A couple of years ago I got an UPS rated 1000VA 600W, with two 12V 7Ah SLA batteries in series. It ran 24/7 up until recently with a load of about 70 W. When it was new it could hold my setup for an hour or so. Not so long ago a power outage occurred and the UPS hardly lasted a few seconds. The UPS has only ever seen a handful of outages in it's life, and before this one, there probably weren't any for many months. So initially I thought the batteries must be dead, although I've read they typically last 3-5 years, so it's a little strange. I thought perhaps the batteries being at a voltage of 27.6 Volts for a year and never doing any work might not be healthy for them? So I took the UPS out and did some testing on it, it would hold a small desk lamp for 10 minutes, but went critical after adding a second one, it seems like it only works with a small load. I think I measured voltage at battery terminals while the UPS was generating AC, one of them was 13V while the other one was 10V. Probably one battery is faulty? Both batteries seem to be manufactured in August 2019. Could a loose terminal connector cause something like this? For several days I cycled the UPS a few times, the last time it sustained a load of about 70 W for 20 minutes until it went critical. And voltages looked even on both batteries. Not as good as new, but seemed to have gotten better somehow. I placed it back where it belongs, and configured it to perform a short battery test periodically, because I heard some higher end UPS do that. One more thing. The UPS can communicate with my computer either via USB or serial (RS-232), the USB connection is problematic, while serial works very well. I used to use USB, and tried a few times to command it to do a battery test, which didn't really work. Then some time later I found the UPS beeping, which it only does while on battery, and mains power was present, so I thought something got wrong with the firmware because of those commands I issued through the glitchy USB interface. Maybe it was indeed on battery even with mains present, or is it even possible for the circuitry to get arranged in a way that the UPS is generating AC using the batteries, while the batteries are being charged? The UPS type is supposed to be "Line interactive". Anyway just wanted to hear what you think about this...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: UPS issue
    Batteries are the weakest link in a UPS system...
    Ideally your UPS tests the batteries every few weeks or so, so you don't get surprised, but likely one of the batteries died from the UPS trying to charge them. A lot of UPS overcharges batteries, killing them.
    The real issue is that even lead acid batteries need BMS like Li-ion, except they don't go nuclear if abused.
    Since you have a line interactive UPS, it's charging and using at the same time so theoretically you're getting inverter output on your computer side instead of only when the power is out. Not sure if you have a sine or modified sine inverter, hopefully the latter else you'll constantly be feeding your computer modified sine wave, which may or may not be dirty for your use.
    My 1KVA offline UPS ate a set of batteries after just one year - it uses three 6V 12Ah packs which is annoying, would be nice if it was a multiple of 12. I decided to stop feeding it batteries...
    • redwire
      • Dec 2010
      • 3912
      Re: UPS issue
      I'd say you have a bad battery, one cell out of the 6+6 is weak or shorted.
      If a cell is weak or shorts, you'd have a 12V battery plus a 10V battery in series.
      Under load, voltage quickly drops 2V lower than normal and the UPS thinks the "24V" battery is dead.
      Also this can cause a meltdown because the pack is now being overcharged. It's a 22V battery, not 24V battery pack so it all quickly dries out. The defective battery can take out the others. I've seen many server UPS 12V 7Ah arrays some bulged out or get melted plastic housings.
      I find UPS gel-cells don't last if the float charging voltage is a little high, and the temperature is high. Some UPS make a lot of heat when doing nothing and the batteries get warm.
      • ribcage
        • Sep 2020
        • 45
        • Earth
        Re: UPS issue
        I guess you're right, just gonna have to get better batteries.
        eccerr0r, I kind of assumed I'm only getting inverter output when the power is out. There's a loud click when the UPS switches to battery and back, probably a mechanical relay. And when it does, the 50 Hz hum becomes much louder. It's a modified sine as far as I know. I thought the type of UPS that always produces AC is called Online UPS.
        • lti
          • May 2011
          • 2557
          Re: UPS issue
          There are a lot of cheap batteries that only last about two years.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            Re: UPS issue
            Random noname chinese/vietnamese agms are good for no more than 2 years if you are lucky.
            I pick good quality metal units and run with external truck batteries.
            Hours of backup rather than minutes.
            • yaya3gmax
              Laptop Power Issue – Works on Battery, Fails on Adapter Load
              by yaya3gmax
              Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
              Symptoms:
              • Laptop works normally on a pre-charged battery.
              • Battery does not charge when adapter is connected.
              • Without battery:
                • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                • Speakers “pop” when power cut occurs indicating harsh sutdown.
                • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
              08-21-2025, 07:16 AM
            • mkdj
              ASUS X571 no power : battery issue?
              by mkdj
              Mark and model: ASUS X571
              Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
              Tests already made:
              - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
              - I have removed...
              07-14-2025, 09:16 AM
            • code share
              Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
              by code share
              Hi everyone,
              I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
              Here's what I've tried so far:
              • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
              • Booted successfully on AC power only with the battery disconnected
              • Visual inspection of the battery — no swelling, burn marks, or connector damage
              • Battery
              04-21-2025, 12:50 PM
            • huzo
              HP ELITE X2 1013 G3 weird battery issue
              by huzo
              Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
              01-31-2025, 12:09 AM
            • Simone Vergani
              Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
              by Simone Vergani
              I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
              To assist with troubleshooting, I'm attaching two power circuit schematics:
              • Power
              03-05-2025, 02:25 PM
