[ROM] Abir X6 vacuum robot
  • lietuvis10
    • Aug 2019
    • 18
    • Lithuania
    Hello, I would like to share Abir x6 vacuum robot cleaner rom files that I extracted from SPI ROM chips. One chip is on main board and another is on camera module (the problem with robot was in camera rom, after re-write with other robot's rom it started working perfectly fine).
    Maybe this will help you, because I couldn't find it anywhere.
    Camera Dump: 4MB
    MB Dump: 2MB
  • ljgonzalo
    • Jul 2022
    • 1
    • Argentina
    Re: [ROM] Abir X6 vacuum robot
    Hi lietuvis, what was your problem with de Vacuum robot?
    • ex250
      SDJ01RM vacuum robot not powers on, all dead
      by ex250
      Hi friends, I have this vacuum robot at home that is not starting any more, no leds working, power button doing nothing, battery reading seems ok arround 14.4v, I suspect that mainboard is faulty, seems that there is not any clear brand model on it, and of course could not find any schematic. The trand of the vacuum is the Roidmi SDJ01RM, on some sites appears as vacuum mop Eve plus 60 or similar
      If any one could point for where to start... would appreciate, new board is quite expensive arround 100 USD or more
      Many thanks and Merry Christmas to all...
      12-24-2022, 05:12 AM
    • flat-earther
      Hoover FM216LI cordless vacuum refuses to charge
      by flat-earther
      I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
      I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
      5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
      So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
      06-06-2025, 03:14 AM
    • Awesomerp
      Sencor SVC7020BK robot vacuum cleaner problem
      by Awesomerp
      Hello I have been trying to identify and fix a problem with a robot vacuum cleaner, which when switched on cleans for like 3-4 seconds and stops, all the driving, sweeping and vaccum motors stop.
      On the pcb from a battery connector up to a main microcontroller everything seems to be fine (vcc pin input is 5v constant when a switch is switched on).
      And the switch itself is fine looking at the quality of my soldering
      Red LED keeps blinking during those 3-4 working seconds, and when the robot stops LED just remains lit.
      The green one for some reason does not even...
      09-23-2022, 11:36 AM
    • Habble7
      I need a BIOS dump for the Samsung S49CG934SU monitor
      by Habble7
      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
      Suspected Cause:
      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • Mephysis
      DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
      by Mephysis
      Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
      I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
      03-27-2025, 02:34 AM
