TL866A - need to program 25Q21BT but device not on list
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    This is the first time my TL866CS let me down (other than 1.8V eproms for which I ordered CH341 but it did not arrive yet)
    I want to program a 25Q21BT Eprom but it is not found on the list in minipro
    I can see GD25VQ21B but when I try to read my chip, the ID does not match
    0x C8 40 12
    My App is version 6.85 and programmer 03.2.86
    Is there a software update to program this eprom. The datasheet says it is 3.3V (if this is the right one)
    https://pdf1.alldatasheet.com/datash...M/GD25Q21.html
    The Eprom is of a Gigabyte GTX 980 ti 6Gb DDr5
    Follow me on YouTube
    Learn Electronics Repair
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: TL866A - need to program 25Q21BT but device not on list
    Hmmm no replies, but I did a google for 'CH341A supported eprom list' as I also have one of these programmers arriving soon, and the 25Q21 doesn't seem to be supported by that programmer either
    I think the full part number is GD25Q21B - it does have a funny G logo marked on it.
    Is there something odd about this eprom? CH341A is supposed to support 25 series eproms
    • lotas
      • Jan 2016
      • 4765
      • Russia
      Try to replace it with W25X20CLSNIG, they write on the forums that it is an analogue of it.
      Or try to set on the programmer: W25X20CL.
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        OK I'll give that a go tomorrow
        • megaraider
          • Jul 2015
          • 307
          • Portugal
          0x C8 40 12
          That 'G' logo stands for 'GigaDevice'
          The ID code: 0xC84012 is match for 'GD25Q21B'
          Datasheet may be found here: https://cdn.badcaps-static.com/pdfs/...a99e3d6bea.pdf
          btw, 'ELM Technology' [http://www.elm-tech.com] also produces it.
          Compare to dumps available on the internet.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            @megaraider
            I do have that ID code 0xC84012, as I stated in the OP
            The problem is that my programmer does not seem to list support for this IC, but the fact there are bios dumps on the internet suggests that some programmer or other must in fact support it
            I will try using W25X20CL as lotas suggest -it certainly seems to read the eprom if I tell it to ignore the ID check
              • 31219
              maybe the replacement sofware has more devices?
              https://gitlab.com/DavidGriffith/minipro/
              • megaraider
                • Jul 2015
                • 307
                • Portugal
                When compared the only difference seems to be that GD25Q21B is able to do Quad SPI, which isn't relevant when programming. Other details as programmable page size (256-bytes), Sector/Block size, and of course 2M-bit size do match. So imo go ahead...!
                Originally posted by stj
                maybe the replacement software has more devices?
                Checked, might have for other ICs, but doesn't support GD25Q21B either (not even any 'GigaDevice' ICs).
                Side Note:
                Thanks to the moderator for deleting my previous empty reply. I must be blind because i couldn't find the option to delete (only edit, within a time frame) or it doesn't exists
                • jehardyiii
                  • Mar 2022
                  • 1
                  I have this exact same issue. I also tried the WL analog but didn't have luck. Did you figure it out?
