Apple Macbook Pro A1990 15" - T203 or CH341 with Mina ?
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Hello to all,
    After i got in my hands a liquid damaged (heavily) , i managed to repair it.
    But, it has a "cloud lock i believe". The person that gave it to me, doesn't have anything from the particular laptop , because it was a lost cause (for him).
    Now my big question even though i searched around the globe (google) ,and on forum and read a lot of threads, i managed to narrow it down to 2 situations.
    1. Is checkm8 with 70$ for software unlock (jailbreak)
    2. Stephen / Hardware unlock with guide T203.
    So my question on year 2022, which is the best solution to make it happen ? 70$ or 300$ from China with hardware method ?
    The incline to the 2nd question is that ,if you have the CH341A programmer (modded that you can read/solder chip on it even if it's smaller) , with the files from Mina that i found online (badcaps FTW) would it be , successfull or you particulary need the "special" tool of T203 with the assistant that it provides?
    Thanks a lot , and if anyone has a suggestion or better a solution let me know
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Re: Apple Macbook Pro A1990 15" - T203 or CH341 with Mina ?
    Noone ?
    • Acnologia
      • Dec 2016
      • 421
      • Poland
      That's strange that noone has the knowledge, or any kind of help up to date (2022)...
      • .::iRizwan::.
        Banned
        • Apr 2016
        • 63
        • Pakistan
        Both hardware method and software method possible only if it is with Old BridgeOS.
        See the Post https://www.badcaps.net/forum/showpo...&postcount=646
        • .::iRizwan::.
          Banned
          • Apr 2016
          • 63
          • Pakistan
          Also DM me the SN of the device so i can check if it is activation lock or not.
          • .::iRizwan::.
            Banned
            • Apr 2016
            • 63
            • Pakistan
            you can use CH341A but you will need a 1.8v convertor board to read T2 chip.
            Else you will fry the chip.
            • Petrakis
              • Feb 2022
              • 4
              • Spain
              But what do you need to do with the CH341A? On non T2 usually you change SN or reset EFI Lock.
              But given you have the CH341A and a 1.8v board (And Mina files) what do you need to look for?
              • .::iRizwan::.
                Banned
                • Apr 2016
                • 63
                • Pakistan
                All these modification will work only if you can jailbreak the MacBook.
                and that is possible only if you have Old BridgeOS compatible for jailbreak.
                • .::iRizwan::.
                  Banned
                  • Apr 2016
                  • 63
                  • Pakistan
                  If you have EFi lock too besides activation lock that is another story.
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 667
                    Caught whiff of this post. EFI can be removed with my tutorial, I will not say or not say use the Mina Serial on checkm8 but....I will leave that for people to explore.
                    sigpic
                    MEOWING IN THE IMPOSSIBLE UNIVERSE!
                    • Acnologia
                      • Dec 2016
                      • 421
                      • Poland
                      Why not ? I mean , if you have previous experience, your experience would be the best result on that
                      Noone i think is going to blabe you for not working etc.
                      I just need / want , someone to give me advice on the matter , even if i have to pay for it
                      I don't know which of the 2 would be the "best" solution.
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 667
                        The reason why I’m not saying anything is because we don’t want a serial to be banned on checkm8…
                        sigpic
                        • Acnologia
                          • Dec 2016
                          • 421
                          • Poland
                          The reason why I'm not saying anything is because we don't want a serial to be banned on checkm8…
                          What does that mean ? Can you explain in simple words?
                          From my understanding if i get it right, is that in case i use the checkm8 and doesn't work ,my Serial would be banned?
                          • .::iRizwan::.
                            Banned
                            • Apr 2016
                            • 63
                            • Pakistan
                            no you didn't understand what he said.
                            • .::iRizwan::.
                              Banned
                              • Apr 2016
                              • 63
                              • Pakistan
                              "Model: MacBook Pro 2.6 GHz Core i7 2.6 GHz 512GB SSD 16G Space Gray
                              Serial: C02X661TXXXX
                              Find My Mac : ON"
                              • sonquan
                                • Nov 2017
                                • 2
                                • vietnam
                                at the present time, does the T203 tool still work?
                                • .::iRizwan::.
                                  Banned
                                  • Apr 2016
                                  • 63
                                  • Pakistan
                                  Yes if MacBook has old BridgeOS.
                                  • curiositymaster
                                    • Apr 2021
                                    • 45
                                    • Nigeria
                                    Find My Mac : ON"
                                    Was this check free or paid?
                                    • erson1997
                                      • Oct 2020
                                      • 0
                                      • Prague
                                      hello pin I would like to load my chip at25sl321 I have a ch341a and a 1.8v converter from another thread I read that version asprogrammer 1.4 supports this chip which in my case is not true do you have anyone link to download the asprogrammer which supports this chip?
                                      • peste
                                        • Dec 2016
                                        • 12601
                                        • ROMANIA
                                        https://www.badcaps.net/forum/showpo...6&postcount=10
                                        https://www.badcaps.net/forum/showpo...04&postcount=7
                                        • RWS93
                                          Apple A1990 / Board number: 820-01041
                                          by RWS93
                                          Brand: Apple
                                          Model: A1990
                                          Problem: I am not an Apple kind of guy to start with. But I am quite experienced with motherboard repairs in general. So the laptop is stuck with 5v 0.250A and does not negotiate 20v. Same symptom on all 4 USB C ports. When charger is plugged the amps start at around 0.060 then go trough: 0.100 - 0.180 - 0.230 - 0.244 and stay like this. Laptop responds to the power button: once I hold it long enough current goes down to 0.060A and then up to previous levels.
                                          Board clean, no liquid damage, no corrosion....
                                          04-11-2024, 03:43 PM
                                        • a_p3rson
                                          Apple Watch Charging Controller Schematics / Boardview - 820-02601
                                          by a_p3rson
                                          Hi there,
                                          I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
                                          You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
                                          This daughterboard uses an interesting...
                                          04-21-2025, 11:41 PM
                                          HP ProDesk 600 G5 + Apple AirPods ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + Apple AirPods can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Apple AirPods boardview and ProDesk 600 G5 + Apple AirPods schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          09-12-2024, 02:30 PM
                                          HP ProBook 430 G7 + Apple AirPods Pro Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G7 + Apple AirPods Pro Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Apple AirPods Pro boardview and 430 G7 + Apple AirPods Pro schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 07:50 PM
