Digihome PTDR32FHDS5 (Vestel) 32" LED Smart TV
  • John McGivern
    • Dec 2013
    • 195
    • uk
    Above TV, power on, 8 flashes tested all diodes and electrolytic caps ok
    voltages shown on attached photo's. LEDs tested all but one was open so I bridged open LED all light but very dim. Shining torch I can see text on screen but voltage low on led connector. I dont have a remote yet. Any help would be appreciated.
    Many thanks.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vestel 32" LED Smart TV
    Need to remove power board and look at the pins for leds for cracked joints. Common problem.
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      my guess a failed led dragging led voltage down.
      • John McGivern
        • Dec 2013
        • 195
        • uk
        All but one of leds light this was open so I bridged it and all work but very dim would the single bridged led prevent the Pwm from working I wanted to see if the tv was working I would then buy new led strips.
        • neilc6
          • Nov 2015
          • 1550
          Most models (Samsung an exception) will shut down the LEDs if the voltage across the array is lower than expected (indicating shorted LEDs). If you want to test, put in a used LED module with same voltage drop.
          • John McGivern
            • Dec 2013
            • 195
            • uk
            Hi guys sorry for late reply checked board no apparent dry joints.
            Can I use a resistor in place of bridged open led to correct voltages.
            If so what would be the resistance I assume these are 3v leds cannot find specs anywhere regarding voltages just says 3v or 6v nothing on strips.
            I have read that it may be a firmware problem. This is a Digihome 32" Smart TV.
            Vestel boards as shown in photos. 2 Led strips 11 on each strip wired in series.
            Many thanks.
              • 22073
              Many thanks.
              Put make and model number in thread title ! ! !
              https://www.badcaps.net/forum/showthread.php?t=24661
              • John McGivern
                • Dec 2013
                • 195
                • uk
                Re: Digihome PTDR32FHDS5 VES315UNDB-2D-N21
                Main board and power board numbers shown in attached photos. Cheers.
                  • 22073
                  The TV model number.Can`t add a picture into the thread title
                  • John McGivern
                    • Dec 2013
                    • 195
                    • uk
                    Sorry gents been away for a week.
                    SMDFlea Digihome Model~: PTDR32FHDS5 Made in Turkey.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      i doubt if its a firmware issue if the tv is turning on and backlights work too a point what is printed on the led stips also what lcd panel type is used in this set.
                      • John McGivern
                        • Dec 2013
                        • 195
                        • uk
                        Re: Digihome PTDR32FHDS5 (Vestel) 32" LED Smart TV
                        Hi. LED number = VES315UNDB-2D-N21.
                        No LCD NUMBER I can see.
                        • John McGivern
                          • Dec 2013
                          • 195
                          • uk
                          Sorry for late reply sent to China for 2 new strips all lit but all dim.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            what voltage is on the led connector on the power supply did you get led strips that was 3v leds
                            • John McGivern
                              • Dec 2013
                              • 195
                              • uk
                              Hi, yes 3volt leds black wire 53.77vdc, red wire 1.68vdc
                              • arizanotlari
                                • Nov 2014
                                • 158
                                • Turkiye
                                Connect a video source to tv (hdmi or dvbt).
                                • yokoono
                                  • Apr 2010
                                  • 510
                                  54V/ 3V = 18 leds.
                                  • John McGivern
                                    • Dec 2013
                                    • 195
                                    • uk
                                    Hi ther are 2 strips each strip has 11 Leds -22Leds = 66volts as previously said all lit but very dim.
                                    • yokoono
                                      • Apr 2010
                                      • 510
                                      Is the power source original? If it is original, replace the circled capacitor.
                                      L.E.
                                      For backlight control, the processor commands the BL / ON pin. For intensity the processor commands the DIM pin, Measure on the dim pin if you find any voltage.
                                      • John McGivern
                                        • Dec 2013
                                        • 195
                                        • uk
                                        No replaced power supply same symptom.
                                        No voltage on Dim pin.
