Backlight Tester procurement
  • captainKKK
    • Sep 2018
    • 287
    Please choose between these two LED testers, and reason of your preference. Thanks
    Number 1:
    https://www.aliexpress.com/item/1005003908772726.html
    Input Voltage: AC85V-265V
    Output Voltage: 0-320V
    Output current:0-35mA
    or
    Number 2:
    [url]https://www.aliexpress.com/item/1005002687350880.html
    Output Voltage: 0-300V
    Output current:40-60mA
    • Jul 2011
    • 6070
    Re: Backlight Tester procurement
    Me personally I would want one that you can adjust the current more important than the voltage but do not get me wrong the voltage is also important as well if you can adjust the voltage and current you have the best of both worlds
    I am not a real fan of automatic voltage/current self adjustable devices
    I have one of these led back light testers and I personally do not like using it because it claims that it is automatically adjusts it self but it can not do single LEDs either so it not much use to me
    I prefer to use an 0 to 80 volt adjustable voltage that has a 0 to 3 amp current limit switching power supply for this purpose but that just me
    But you are asking for me to pick one it would be the first one but the description of the second one says 0 to 30 milliamperes but you have it as 40 to 60 milliamperes unless I read it wrong
    • captainKKK
      • Sep 2018
      • 287
      Thanks Sam, from your criteria, I found this one, but it's only 0-230 volts, and may only work with 220 v AC? https://m.aliexpress.com/item/400026...mend-recommend
      Or
      https://m.aliexpress.com/item/329951...mend-recommend
      Or, watch video on this one...seems to have more function:
      • captainKKK
        • Sep 2018
        • 287
        Found and purchased this one. Hope all is ok. https://www.ebay.com/itm/202442894494
        • captainKKK
          • Sep 2018
          • 287
          Nothing here
            • Jul 2011
            • 6070
            Originally posted by captainKKK
            Nothing here
            Thank you for posting this one this is somewhat what I have been looking for
            This is okay however it is semi automatic / automatic it might be better than the one i have now
            • captainKKK
              • Sep 2018
              • 287
              I wonder, the seller raised the price from my $35.99 to $45.99, since yesterday. Aliexpress, Amazon uses cookies to raise prices and now I am wondering about EBay.....?? For this one, it States: "Note: The current adjustment switch is disabled during the test. It does not have the protection of a ramp-up voltage, it can damage your LED bead. You can stop the test area to adjust it." But not a problem, as start low, if not lit, cease lead contact, increase current....Maybe a little tedious, but I can at least use this for other tests.
              • captainKKK
                • Sep 2018
                • 287
                Maybe this one is for you:
                https://www.aliexpress.com/item/3285...mend-recommend
                • captainKKK
                  • Sep 2018
                  • 287
                  • dellxps15
                    • Feb 2014
                    • 1598
                    • italy
                    i have repaired till now 6 tv with backlight problem. one was lg and was much easier to replace whole led kit for like 50€ because diffuser never get glued back well again and the others was able to replace just 1-2 led. in any of that repair i never had the need to use a led tester. each led stripe had positive and negative, so my lab psu was more then enought for them...
                    • clearchris
                      • Dec 2013
                      • 687
                      Don't these leds have pretty similar rated life? Seems like something where you would want to replace them all while you had it out...
                      • captainKKK
                        • Sep 2018
                        • 287
                        Maybe, probably. But I use them to tell IF the BL are working when I have a "dead" set. There is no use for me to troublshoot the PS or MB if the BL are out or the screen is broken. If so, then I might test the PS voltages and strip the boards for resale.
                        The tester I bought has the capability to also test the BL driver so this just saved me lots of time on my last when the driver board and BL were good. A "dead" set ended up being fixed for a $0.14 schottky diode replacement. The "PROS" may have lots of test gear and a varible DC power supply they can test the BL with but I still like my dedicated BL tester.
                        • redwire
                          • Dec 2010
                          • 3912
                          I'm seeing where 1/4 of the backlight LED's are damaged, what happens is a cascade failure where one LED goes open/blinking and the PSU overdrives the other strips and damages those LEDs.
                          So you have to power up a strip and tap and poke to flush out the weak LED's and if you miss one you have to repeat the disassemble/glue/assembly thing again.
                          Are you seeing that, it's not one or two bad LED's but a bunch are in terrible shape so it's best to swap out the entire strip.
                          • captainKKK
                            • Sep 2018
                            • 287
                            What do you think of this procedure beginning at 4:40 of THIS?
                            Although I got good test results testing a 65" set, I am quite sure if the number of leds per circuit get too many, the tester will not be able to drive them at full brightness.
                              • Jul 2011
                              • 6070
                              Thank you for posting this link How To Use This Device has convenient me to buy one for testing LED strips but I would use different hookup wires for testing different styles of connectors
                              • redwire
                                • Dec 2010
                                • 3912
                                The difficult part is LED's going intermittent. Blinking and cutting out - this is due to heating causing expansion and an open-circuit (in the cracked die, or bonding wires, or substrate glue) after which the LED then cools off and the connection is made again. Blink blink blink.
                                I haven't done the math how many watts is a typical LCD TV backlight, but testing at low currents does not always make enough heat in them to flush out bad connections in the LED. So people tap them, or use a heat gun to stress them.
                                I don't know how many watts that LED backlight tester can put out. They said 30-300VDC at 1mA or adjustable to 50mA? I don't see it putting out 15W.
                                • captainKKK
                                  • Sep 2018
                                  • 287
                                  Backlight LED Testing Methods
                                  Default factory setting: Output Voltage 330V, Output Current 30mA. You can test the backlight of TV with any size at this default settings.
                                  1. Self-testing: Plug in, turn the power switch on. The voltage is around 330V, current is 0; Contact the probes together, voltage changes to 0 and current changes to around 50mA, then testing can be started.
                                  2. In testing:
                                  Voltage = ‘0’, SHORT CIRCUIT.
                                  Voltage = ‘330V’, OPEN CIRCUIT.
                                  3. Testing single LED bead (Set voltage around to 20V and the current switch to 1mA):
                                  A. With right polarity: the voltage shows on the tester of a normal LED bead is about 80% of the rated voltage, for example, the operating voltage of the LED bead is 2.4V if its rated voltage is 3V;
                                  B. With wrong polarity: Voltage display the open circuit voltage.
                                  4. Testing LED strips: Set the voltage to around 200V, change the current if need adjust brightness.
                                  Introductions of the Additional Function
                                  Voltage Test of Electrolytic capacitor:
                                  Connect the black pen with the cathode of the electrolytic capacitor and the red pen with the anode. The voltage value displayed in the voltmeter will rise fast at the beginning. When reaching a certain point, the rising velocity will slow noticeably. At this time the voltage value displayed is the actual withstand voltage of the tested electrolytic capacitor. (The capacitors are qualified if the actual voltage value is higher than the indicated voltage value )
                                  Notice: Avoid to break the capacitor, the testing time should not be too long.
                                  1. Set the voltage around 20V and the current to 1mA when testing the voltage references of diodes, triodes, MOS tube and IC.
                                  2. Set the voltage around 330V and the current to 1mA when testing the breakdown voltage of capacitors, stabilivolts, piezoresistors and TVS.
                                  I have NOT tried the capacitor tests in this published LED tester guide.
                                  • cheeky2
                                    Anyone know how to take apart a Fluke T100 Voltage Tester without damaging it?
                                    by cheeky2
                                    See attached picture. I have a Fluke T100 Voltage Tester that the resistance and diode measurement isn't working (it's not the batteries (as I have already checked them and put decent Duracell 1.5V AAA batteries inside it).
                                    I have looked on the web for any information and on youtube without any results for this model.
                                    There are no screws visible or anything obvious. So I am hoping someone here has the solution to take it apart?
                                    The only way I can see is underneath the yellow rubber handle area, however I don't wish to damage it if it isn't the case!...
                                    06-04-2024, 07:21 AM
                                    Is there a way to modify a IMAX b6 battery tester version 2 to only monitor voltage
                                    by sam_sam_sam
                                    I am still looking for a solution to problem using the BMS balancing protection board that for most part good but have the issue with batteries not having the same exact charging and discharging curves
                                    Also is there a way to make the battery voltage monitoring system to correctly report the exact battery voltage instead of estimating the voltage between battery cells
                                    I do not want the IMAX b6 to charge them I just want to able to monitor the battery voltage on each battery cell and use my own BMS balancing protection board that I am going to use on this battery pack...
                                    07-31-2021, 08:07 AM
                                  • Fernon@Repair
                                    Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                    by Fernon@Repair
                                    i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                    VCCIO voltage ok
                                    VCCSA Voltage OK
                                    VCCPLL Voltage OK
                                    Ram Voltage ok
                                    RamVTT OK
                                    VPP 2.5 OK
                                    But No Core Voltage
                                    and i want to this vrm ic datasheet or pinout (ISL69269)
                                    anyone have this ic pinout voltages?...
                                    06-25-2025, 07:19 AM
                                    Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                    by sam_sam_sam
                                    I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                    The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                    Now...
                                    06-09-2024, 10:57 AM
                                  • electron_jj
                                    Panasonic TH-L42D25A checking the PSU output voltage
                                    by electron_jj
                                    Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                    I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                    08-29-2021, 08:13 AM
