Panasonic PBX shuts off at random
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I wasn't too sure whether I should start this discussion just yet, because I feel I haven't dug deep enough, which I can't do until Monday at work, but I eventually thought I'd just go for it so by the time people start joining in, I'll hopefully be able to complete my measurements.
    TL;DR - Panasonic KX-NS500 PBX sometimes dies - PSU issue (schematic attached). 41v rail drops to 25v and 15v rail goes off entirely. Often, even a power cycle doesn't restore it - main cap (C4) needs to be "manually" discharged for it go gain.
    Details: to keep it as short as possible, there are a couple of things I noticed so far, since it's all random AF:
    Schematic is on page 14 and HOLLY BALL$$ this board is complicated ! SO MUCH stuff going on ! They have the courtesy to explain some of it in the first pages, but it doesn't help all that much. Granted, most of it has to do with protections and signaling and stuff, since at the end of the day, it's just a SMPS producing a 41v output which is then stepped down to 15v by U7. When it works - it works: both rails operate normally and I get all the readings indicated by the manual on the test points - no problems.
    First thing I noticed: C4 keeps its charge for what I'd call an insane amount of time ! I swear it was still charged to 300+ V after 2-3 days ! HOW ??? I even pulled it off to check it and it measured fine, so that's a bit weird....
    Second: getting it to actually crash is a gamble and I wasn't able to find any connection as to why it happens. Sometimes it works, other times it doesn't start at all and other times (like right now) it just dies after operating for a while. It'd start up fine, give me the correct output, the PBX itself boots, then I'd flip the power switch off and back on a second later and it doesn't start again, though not always and this is not always repeatable ! Once it happens though, you can flick that power switch all you want, but it's not waking it up again ! This is why I mentioned the main cap holding a crazy charge, because normally in such cases, you'd unplug it and plug it back in and it'd get it going a second time, enough to figure out what happened, but because the cap stays charged, you'd have to leave it unplugged for like.....a week for this to happen...
    Third: I WAS able to get it to crash a couple of times using the power switch trick and quickly took some measurements while it was dead: the 41v rail before Q15 remains stable, but the output (after Q15) is now only 25v (random AF !). U7 was not operating either, so no 15v on the output. I then wanted to measure the FB pin (pin 4) of U7 and guess what: touching my red probe to pin 4 caused the board to spring back to life right there ! What gives ? I tried it a second time after another crash and the same thing happened ! Once it DOES run, pin 4 reads around 1.6, which is normal according to plot 33. I checked R64 and R65 and they're OK. I also touched up the area with some solder, thinking perhaps me touching the pin is enough to make contact between some weak joints and I was just about ready to pack it up and call it a day, thinking that was it, since it didn't happen again after that, but just as I was relishing in my success, the power LED went off again ! DAMN !
    Those are my findings so far...
    I'm not entirely sure why Q15 just decides to turn off....it doesn't explain why there's still 25v there. Any doubt that it's residual charge from the caps is debunked by the fact that all these tests were performed with the PSU actually connected to the PBX, so the load should cause that to drain, which is not happening - it's "leaking" from somewhere. Even so, it's not clear what's going on with U7, which is too expensive to replace on its own just to test, since that was my original assumption. Even if it were bad, it shouldn't affect Q15 and the 41v output...unless someone sees some connection.
    I'll definitely want to measure pin 5 of U7 during a "blackout" to see if it's still "ON", but not running, or if something in the protection circuit triggered somehow.....
    Wattevah...
  • R_J
    • Jun 2012
    • 9602
    Re: Panasonic PBX shuts off at random
    As usual I would check or better yet replace C32, vcc for U2 and C13 or at least check the vcc voltage of U2 to be sure its not going into burst mode due to low vcc
    Check if your +41v at CN100 is there all the time, also if the +15 disappears, the whole secondary circuit will likely not operate so Q15 would likely turn off.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      I already replaced those, which leads me to this:
      Yes, it is - up to Q15, so point 19 gives me the correct voltage all the time. Point 20 doesn't.
      Yes, that's what I'm expecting, but point 20 still shows 25v somehow. I'm not entirely sure what the power sequence is: does the 15v rail ultimately turn on Q15 ?
      I'm trying to work out that mess on the gate of Q15...I see 15v coming in on the gate of Q32 (below the connector), so when that goes high, Q32 pulls the anode of Z14 to GND, completing the circuit, which causes 24v to show up on Z17 which is now forward biased and just passes DC like a regular diode, minus some drop. Z18 is facing the other way, which means it clamps this whole rail to 24v ?.....which seems pretty high for the gate of a FET :| I THINK R106 and R109 act as a divider and drop this down to an acceptable value and the zeners are there for clamping purposes, which STILL seems a bit high too me and it doesn't make sense why there's two of them back to back there - would've probably chose 18v zeners, but heck, they know better...
      With Q33 now finally on, I get stuck: anode of D16 gets pulled to GND and then what ???
      I also see that 60v rail there which is also generated by an additional winding on L3 driven by U7, so if that dies, Q15 probably turns off. This makes a bit more sense: 60v comes in through R99 and R104 (no idea why they chose two in series), goes through D16 and finally is clamped to 15v by Z11, which is again kinda confusing, since its cathode doesn't go to GND...what a weird circuit. I remember measuring the gate of Q15 and seeing 57v and freaking out, but then I referred to point 21 and that's actually correct ! I'm assuming it's because D15 is referenced to the 41v rail as opposed to GND, so the G-S voltage on Q15 is not ACTUALLY 57v (as "seen" by the gate) - that is what the meter reads referenced to GND, but G to S must somehow still be within the 20v rating...although 41v-15v=26v which is too high still, unless R66 and R74 act as a voltage divider there yet again.....whew...:|
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Here's the situation: I left the PBX running on my desk on Friday over the weekend and when I came back to it this Monday morning it was dead again, with the same symptoms: no 15v output and only a faint 15v on the 41v output. This time however, it wouldn't power back up, no matter what I tried, so something finally died for good, which is good for the sake of the repair, since I don't have to guess anymore. Touching my probe to pin 4 of U7 this time does nothing.
        I figure U7 finally packed it for good because it has 41v on pin 1, 0v on pin 5 (SD) yet it just sits there doing nothing. I checked for shorts, didn't find any, and also checked C12 and it measured fine, so I decided to replace it and hope for the best...
        Wattevah...
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          Replaced U7 and it fired up right away and it's been working for around 7 hours now....here's hoping it lasts :|
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Second day of operation and it'd been fine, so I think that was it: U7 sometimes felt like taking a break....
            Wattevah...
              • Jul 2011
              • 6069
              Have you torch tested it yet other than just letting it run idle mode
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                Not much I could do with it myself, plus I don't imagine it's doing any major work when in operation anyway, so I just let it run on my desk however it pleased. It doesn't matter in this case, because the guy who brought it in said it'd shut off anyway after around 8 hours or so, no matter what it was doing, so I think we're good.
                Wattevah...
                  • Jul 2011
                  • 6069
                  Then if this is the case then it sounds like you might have fixed it
                  • Nagy Daniel
                    Lowest possible resistance on laptop motherboard rail - Guide Table request
                    by Nagy Daniel
                    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                    So, I generated a table with AI so I can...
                    03-04-2025, 08:24 AM
                  • APOPAP
                    Panasonic National NV-M3 VHS Camera shuts down after some seconds
                    by APOPAP
                    Hello everybody,
                    First post here. I have been reading posts here for some time now, but today I made my first account and post.
                    The same question is also posted on another site, here it is:
                    Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                    I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                    08-25-2025, 10:12 AM
                  • jaroslav.psenicka
                    Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                    by jaroslav.psenicka
                    I have a Lenovo Yoga 13 Panasonic here, when powered
                    • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                    • most voltage rails seem OK (see image below, red labels)
                    • resistnace to ground mostly seem OK as well (blue labels)
                    the only suspicious is the 0.0V rail (2nd from left, top row)
                    • the resistance to ground is rather low (1.9ohm)
                    • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                    also tried new BIOS, no change
                    I can't find a schematics for the board - can some of you gurus look at the voltages?...
                    05-02-2024, 05:59 AM
                  • Victor Moreira Silva
                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                    by Victor Moreira Silva
                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                    Well, my decice specs are the following:
                    Model: Acer Nitro 5 AN517-54-55T5
                    CPU: Intel Core i5-11400H
                    GPU: NVIDIA GeForce GTX 1650
                    Motherboard: GH51G LA-L181P Rev:1c
                    The symptom:
                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                    05-26-2025, 10:49 AM
                  • lefetylorant
                    Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                    by lefetylorant
                    Hello Everyone,
                    Long story short, I got this unit for very cheap.
                    I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                    I've performed some measurements:
                    - 20V rail perfectly...
                    09-14-2023, 05:05 AM
