NEC VK26MB-F laptop
  • String2016
    • Nov 2015
    • 2238
    • philippines
    NEC VK26MB-F laptop
    I need a working dump on this laptop please attached is the original file
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: NEC VK26MB-F laptop
    Anyone can fix this please or have a working bios on this model please
      • 22109
      Have you tried cleaning the ME firmware https://www.badcaps.net/forum/showpo...41&postcount=3
      • String2016
        • Nov 2015
        • 2238
        • philippines
        no can you please help posted the clean me please
          • 22109
          Havn`t you tried cleaning the ME firmware yourself before ?
          • hoaca388
            Badcaps
            • Jan 2022
            • 12419
            Try this
            • String2016
              • Nov 2015
              • 2238
              • philippines
              thanks but the bios still no display
              • hoaca388
                Badcaps
                • Jan 2022
                • 12419
                Clear ME file :
                • EbrahimSiami
                  Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                  by EbrahimSiami
                  I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                  **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                  **What I have tried so far:**
                  1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                  07-02-2025, 02:31 PM
                • bondminer009
                  Need Bios for Latitude 7650 (No Original / dump bios file)
                  by bondminer009
                  Good Evening,
                  Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                  Thank You
                  Salam,
                  Three
                  11-12-2024, 07:48 AM
                • joshAU
                  BIOS file for N550JK (original dump attached)
                  by joshAU
                  Hi all.
                  I'm looking for a BIOS file for an Asus N550JK.
                  I have a Asus R552J, which I believe is identical to the Asus N550JK.
                  I downloaded the latest BIOS (210) for the R552.
                  It is named N550JKAS.210.
                  The BIOS file is however only 6mb in size.
                  I've read the chip with a CH341A programmer and verified the file.
                  That file is actually 8mb in size.
                  I'm wanting to remove the BIOS password from this unit.
                  It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                  08-09-2022, 08:06 PM
                • adelage
                  Merge ECS Z77-H2 bios cap file with original dump
                  by adelage
                  I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                  03-11-2025, 03:07 AM
                • Curtissimo
                  HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                  by Curtissimo
                  Hi everyone.
                  I have a HP Elitebook 850 G8.
                  Serial: 5CG2324XM0
                  ProdID 6L8D5EC#ABA
                  It has a Winbond W25Q256JVEN Chip.
                  I need to remove BIOS Password.
                  I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                  Attached my dump.
                  I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                  I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                  What I did:...
                  08-26-2025, 04:42 AM
