Lenovo X1 Yoga Gen 5 - Supervisor Password Removal
  • czue
    • Mar 2021
    • 4
    • South Africa
    Can I please ask anyone to assist with a patch to remove the supervisor password from the below bios dump.
    Lenovo ThinkPad X1 Yoga Gen 5
    S/N: PF2WLEZB
    Thank you in advance for your time.
  • couillu76
    • Jan 2022
    • 39
    • United Kingdom
    Re: Lenovo X1 Yoga Gen 5 - Supervisor Password Removal
    hi try tha
    • d3nni
      • Jul 2022
      • 1
      Did this work?
      I also got an locked ThinkPad X1 Yoga Gen 5.
      It's possible to get it unlocked?
      • kulinBan
        • Feb 2021
        • 4
        • Serbia
        Hi.
        Can somebody share the location of bios chip? Thanks
        • DZ-Developer
          • Nov 2022
          • 28
          • Algeria
          Bios Locked
          Is there a possibility to Remove the bios code ?
          all donations are welcome,
          see the donate button below, at the bottom of the page, or
          >>>>> click on this link to donate via PayPal. <<<<<
          Doctrina est fructus dulcis, radicis amarae
          • greymind
            • Feb 2023
            • 12
            • New Zealand
            Hi, I'm new to this. I've the same laptop and I want to remove the Supervisor Password from the laptop. From what I read from the guide, it says I may need EC Flashing instead of Bios? So do I still need the BIOS dump?
            Also, what type of chip does this laptop has for BIOS or EC? I don't have a programmer yet, RT809H is quite expensive. Do you think RT809F will do the job? Thanks.
            • farouk_1994
              • Mar 2021
              • 393
              • algeria
              Please unlock this bios
              • splus11
                • May 2016
                • 74
                • Poland
                Hi
                Please cleered my bin password Lenovo X1 Yoga.
                • mazoot
                  iFixit
                  • Jan 2019
                  • 41
                  • Moldova
                  No Patch for this model only JTAG with RT809h or Vertianov JIG
                  Kill the state in yourself and you will be free like a wind...
                  • Markus1741
                    • Sep 2020
                    • 868
                    • N/A
                    Originally posted by splus11
                    Hi
                    Try your own patched file ...
                    • splus11
                      • May 2016
                      • 74
                      • Poland
                      Thank you for your help . Password removed
                      • Markus1741
                        • Sep 2020
                        • 868
                        • N/A
                        Good to hear. 😁
                        • greymind
                          • Feb 2023
                          • 12
                          • New Zealand
                          May I know if this is the BIOS dump? I thought we need to use EC flashing to remove the password for Thinkpad X1 Yoga Gen 5? Thanks for the clarification!
                          • ajbernasko
                            • Mar 2022
                            • 229
                            • ghana
                            Lenovo Yoga gen 5 password removed. EC bios can be copied from the main bios from A00020 - A4001F; just erase the EC firmware and flash with the data from the copied data from the main bios in the offset as mentioned and attached is the configuration to use with RT809H.
                            0. GND 1. TMS 2. CLK 3. TDO 4. TDI 5. RST.
                            I do hope this one helps the forum or whoever has been trying to unlock the yoga series.
                            • greymind
                              • Feb 2023
                              • 12
                              • New Zealand
                              Where can I find the information about copying the EC Bios from the main bios from A00020 - A4001F? Thanks.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Read the rules before posting:
                                BIOS guides, methods, resources and tools
                                Password removal by laptop brand
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                • greymind
                                  • Feb 2023
                                  • 12
                                  • New Zealand
                                  I've already read posts about reading/writing the EC by the programmer and bought the RT809F to try and do that. However, I haven't come across the A00020 - A4001F part, I thought that's new information that I missed?
                                  Anyway, I attempted to remove the 10k resistors and accidentally knocked off some other resistors while doing that. I'd be grateful if anybody can help me identify the size of the resistors labelled 1 and 2? Also, what is the IC labelled 3? I moved it as well, not sure if need replacement? Thanks for your help!
                                  • waqas85
                                    • Jun 2023
                                    • 1
                                    • Pakistan
                                    labeled 1 is 1K, Labeled 2 is Zero Ohm (Jumper)
                                    • greymind
                                      • Feb 2023
                                      • 12
                                      • New Zealand
                                      Thanks for the info. I made it worse and moved more resistors. I'm going to see if someone can help me to do it instead. However, I need to know the components labelled in the photo. Can anyone please help?
                                      Also, may I know how did you find out what components those are? Can I have the schematic as well? Thanks. I've one for T490s and X1 Yoga Gen 6. Please point me to the right page, if they are compatible. Thanks a lot!
                                        • 21394
                                        Schematic requests, if you hadn`t noticed, are in a seperate sub forum. Use the forum search, it might be posted already.
                                        • AppleLover123
                                          Lenovo Yoga X380 22LH Supervisor Password removal
                                          by AppleLover123
                                          Hey guys,
                                          have a laptop here that has a supervisor Password (dump in Attachements).
                                          Before i write the Serial NR.etc i wanted to say that strangely after flashing with 3 different Bios dumps and one from lenovos site
                                          the laptop works but everytime it wants me to type a supervisor password i never set.
                                          I thought the supervisor password is stuck in the ec bios but no it isn't either because after replacing the ec chip from one of another board it still has the supervisor password.
                                          Anyway i wanted to ask what of the two chips is the ec bios because on the left...
                                          04-17-2025, 03:42 PM
                                        • baaligoga
                                          Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                          by baaligoga
                                          Good day, everyone!
                                          I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                          I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                          05-20-2023, 09:48 AM
                                          Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                          09-07-2024, 05:00 AM
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
                                          This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
