Firmware wanted (?) Telefunken D49U472R4CWH - 17MB130s
  • der-Lorax
    • Apr 2022
    • 2
    Hi everybody,
    This is a quick story of me, trying to fix a mainboard for the first time. Maby you can help me, but maby you can have a little laugh also
    First off, numbers:
    Telefunken UHD TV D49U472R4CWH
    Vestel 17MB130
    Panel: 49_VESQNDLN11_2D_UHD_D_XDF0_V_130_2372611_272611.xls - V2.18
    Serial number: 101120064
    Some months ago, I had a funny bug occurring on my TV: the mainboard received a "down" signal, which wouldn't stop resulting in an ongoing lowering of volume.
    As I was able to counter the signal by pushing the 3-way switch upwards, I deduced, that the switch (which is directly soldered to the mb) must somehow be broken.
    As I don't know to solder, I took a heat-gun and just vanished the whole switch. The rest of the mb seemed undamaged (aside the already broken aux-output, which melted a bit) and so I built everything back together.
    The good news: the TV still awakes and seems to work fine
    The bad news: the bug still occurs and the false signal is still lowering the volume!
    At this point, I can no longer hide, that I am a complete novice.
    I didn't know what else to do, so I ordered an "refurbished" 17MB130s from ebay. BUT it now seems, that it has not the right software installed. My first idea was to desolder and swap the component, that holds the firmware. Than I learned, that it should be possible to flash the 17MB130s via USB. I think, this procedure would be much saver (for me and the components ).
    Where can I find the suitable software? Or is the old board still any good?
    I really hope somebody can help me with my mess. Furthermore I'm really looking forward to learn something from you Let me know, if you have any questions or need further information.
    All the best
    Lorax
  • flez1966
    • Mar 2017
    • 2
    • United Kingdom
    Re: Firmware wanted (?) Telefunken D49U472R4CWH - 17MB130s
    WOW someone else with a similar issue!
    I have this 'ghost' down signal, I thought it was the IR from the remote, nothing, I thought it was IR in the home from somewhere so moved the tv outside, still the same...
    while the tv was outside we decided to tidy up the usual place the tv lives so it was about 15 minutes till we brought it back in, it was fixed! for about 5 mins then started again, this means its thermal....
    i have tried this again by un-powering the mains and sure enough the next morning i get a few minutes of perfect behavior.
    I tried contacting toshiba who provided a download of firmware, no change, then said thats all we can do and we provided the link as a courtesy but as your just out of warrenty, have a nice day. thanks toshiba....
    i tried changing the psu, no improvement, i put back old psu and a replacemt mainboard, that fixed it, so it really is a main board issue, i went back to the old board and better thermal paste on the heatsink, didnt help.
    oh mines not doing volume down, its only doing the down in the 'input selection' menu so it scrolls hdmi1 hdmi2 etc, to select what you want its like playing whack-a-mole. but on really hot days, the fault can 'creep' into other menus... its weird...
    • flez1966
      • Mar 2017
      • 2
      • United Kingdom
      i should add mine is a 50'' toshiba 4k, but still a 17mb130 main board, with 'alexa built in'' and the not included but expensive 'usb microphone' which i think is a toshiba con for not including...
      • Diah
        • Feb 2013
        • 6564
        Firmware 17MB130S panel VES490QNDL-2D-N11 on MEGA
        • dizdra
          • Dec 2022
          • 2
          • switzerland
          Hello to all
          I have similiar issue but differen Telefunken TV. My story...
          I have a TV Telefunken model D43F550G1CW and it does not work. When it turns on it shows a blue screen and says load software and reaches 1% and then the screen goes black. A white light shines from behind.
          The motherboard is: VESTEL 17MB181TC, and the PSU: VESTEL 17IPS62.
          And there's this:
          Model: VES430UNDP-2D-N43
          Barcode: 285608260903
          and: 23689890
          Now I don't know if it's the software and where to download it, so the firmware for D43F550G1CW or if it's the hardware you have as I see in the picture.
          I need an advice.
          • belto003
            • Nov 2019
            • 2
            • سورية
            The motherboard is: VESTEL 17MB181TC /Model: 32h7510t
            • piernov
              Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
              by piernov
              Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
              I suspect corrupt firmware but I haven't been able to find anything for this TV.
              TV model: Finlux 65-FUC-8060
              Mainboard: Vestel 17MB130S 23473048
              Panel: VES650QNTS-2D-U11
              At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
              06-01-2024, 12:57 PM
            • PNI E.
              firmware hitachi 50hk6000 mainboard 17mb130s
              by PNI E.
              hi guys, can you help me to find a firmware for my hitachi 50hk6000. the tv turns on but no screen, im sure it s a firmware problem because i bought a new main board from ebay but they gave me an other version of the mainbord mine finish in s the board they gav me finish in p, and have 3 hdmi, but the tv with that board turns on but says dont signal and doesnt respond to the remote control. so someon can give me the firmaware for 50hk6000 main board 17mb130s so i can flash the eprom thansk guys
              02-14-2025, 02:06 PM
            • zklgfs
              Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
              by zklgfs
              I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
              08-11-2025, 02:14 PM
            • TheUser
              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
              by TheUser
              Hello to everyone ,
              This is my first post here, and i would like to share with you a small story in case you can help me.
              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
              02-10-2024, 02:07 PM
            • gurj1979
              Ubiquiti firmware help. US-8-150W POE
              by gurj1979
              Hi guys.
              I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
              Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
              So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
              Got New chip and writes good.
              THE PROBLEM...
              It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
              Does anyone have a Good Firmware I can have?...
              07-22-2024, 05:13 PM
