MOSFET testing question
  • Scruit
    • Apr 2022
    • 12
    I am testing an NPD603AL (N-Channel Logic Level Enhancement Mode Field Effect Transformer) from an old Comapq Proliant 1500 CPU daughterboard. Symptoms are no post / no video, with only the psu / blackplane / cpu daughterboard and CPU in place.
    First question: This is not explicitly listed in the datasheet title as a MOSFET, however in the description it states it uses D-MOS technology. I assume this means it's just a MOSFET, and the "logic level" means it only needs 5v gate-source charge instead of 10v. Is that correct?
    I am testing this because when the CPU is in the socket there is no POST but this FET get VERY hot. Within a minute the heatsink will burn your finger. With the CPU removed the FET does not get hot at all.
    When I tested the FET on the board I found drain-source was shorted with the power off. I removed it from the board to isolate. Motherboard showed no short between the empty source and drain pads after the FET was removed.
    Measuring the FET with multimeter in diode mode:
    • Source(+) and drain(-) the source I get the 0.5v diode reading as expected.
    • Source(-) and drain(+) I expect to see OL but got 1.7v.
    Follow-up resistance testing showed OL in both directions. So I'm a little confused. I would expect the drain-source to be fully shorted and read close to zero ohms.
    Second question: Could this be a partial failure? (Not fully shorted) or is this FET allowed to read 1.7v in this direction?
    Maybe it was initially reading a short on the board because the FET got so hot it shorted, and after it cooled down it is not a complete short? Or maybe there was some residual voltage at the gate? (board was out and on my desk though)
    • Jul 2011
    • 6070
    Re: MOSFET testing question
    I pretty sure that it is a mosfet because it S/D/G which mosfets have this labels for the pins
    “ Measuring the FET with multimeter in diode mode:
    Source(-) and drain(+) I expect to see OL but got 1.7v.”
    You should have no short from the source and drain pins if this were the case it would in the on state continuously which is not what you want the gate pin is what turns the device on
    Now what could have happened is that the device was still in the on position and when you removed it you might have shorted the pins together and now it is in the off position which is my guess to why you saw these readings
    • Scruit
      • Apr 2022
      • 12
      Thank you for your response.
      At this point the mosfet is on my bench, disconnected from anything. I still measure 1.7v from drain to source, even after shorting the legs.
      Another observation: If I short all the legs and then measure drain(+) and source(-) then it will count DOWN from 1.9v to 1.7v then stop. If I touch the gate with the positive probe for half a second then move it to the drain then it counts UP from 0.5v to 1.7v.
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Just a question of the part number. You are saying that you are testing a "NPD"603AL but, the data sheet is for "NDP"603AL is this just and error or are they actually different numbers?
        • icanic
          Shorted drain to source on mosfet on Lenovo Legion 5 15ARH05. Please help.
          by icanic
          Greetings!
          I am trying to fix something and I have messed it up more.
          I have shorted mosfet (QX6 from the picture) drain to source on the laptop and laptop now only powering on and off.
          can someone help me identify what I burned? The mosfet is good.
          Full schematic of the laptop is in the link.
          Thank you!
          Full schematic in attachment.
          MOD Edit: Link to schematic -> https://www.badcaps.net/forum/showthread.php?t=112937
          Reminder: rules and organization of this section -> https://...
          07-20-2023, 06:45 AM
        • Nooy
          VGA MOSfet permanently shorted and loss of MOSfet pad
          by Nooy
          Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
          I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
          02-14-2024, 02:26 AM
        • chestercc
          Alienware M18x Shorted CPU Mosfet
          by chestercc
          I've got an old Alienware M18x R1 which shorted out the charger whenever it was connected. Tracked down the short to two shorted caps and burned CPU power controller caused by a shorted mosfet on the CPU's graphic power supply.
          I've replaced the faulty mosfet, two shorted caps and the CPU Power controller (NCP6151S52MNR2G).
          Issue is now whilst there is no short if I attempt to power the system on the fans spin for a couple seconds there are no lights and no further action - the PCH is heating up but there is no CPU power coming out but there is an enable signal...
          07-16-2022, 06:05 AM
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • Jane
          How do you test MOSFET in laptops ?
          by Jane
          I tried to use this method:
          Testing an N-channel MOSFET:
          Step 1: Discharge the Gate (turn off the MOSFET)
          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
          Step 2: Charge the Gate (turn on the MOSFET)
          Now, place the red probe on the Gate (G) and the black probe on the
          09-27-2024, 03:31 AM
