Need new part for microwave
  • Welchs101
    • Sep 2008
    • 979
    Hi, my microwave quit working today after my daughter made something and i think i found the problem. i am enclosing a few pics of what i "THINK" is a thermal fuse.......it has "KSD1" .....and "160/" on the front of it....but i am not sure what this means or where to buy it.
    when i measure across this device it measures an "open" so i and i think it should be a short......
    thoughts on where i can get a replacement device?
    thoughts on if this is thermal fuse and should measure a short?
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Need new part for microwave
    It's a bimetal thermal switch. It should open up if what it's mounted on gets too hot. It should close again when what it's mounted on cools.
    On eBay, https://www.ebay.com/sch/i.html?_nkw...22aefafcdb677e
    PeteS in CA
    • lotas
      • Jan 2016
      • 4708
      • Russia
      Bimetal thermostat type KSD
      Response temperature: 160 +/- 5 °С
      Temperature : release -130 +/- 15 °С
      Switching scheme : SPST NC - normally closed contact
      Working voltage : 250V
      Rated current : 10 A
      • R_J
        • Jun 2012
        • 9579
        You should be able to find one at an appliance repair shop, or on line KSD1-160
        It should reset but is likely defective, for a temporary fix, try taping the silver part with a screwdriver handle or similar, then check if it reset, this might get it going until you get a new part.
        • Welchs101
          • Sep 2008
          • 979
          think its ok to buy this used one?
          https://www.ebay.com/itm/15493592052...IAAOSwKOdiTayW
          • R_J
            • Jun 2012
            • 9579
            Originally posted by Welchs101
            Why buy a used part, here
            https://www.buyspares.com/thermostat...pl?pid=1906318 about $9.00 for the part, and $9.00 shipping
            I'm sure there are lots of other sources, check locally, it should be a common part
            • Welchs101
              • Sep 2008
              • 979
              i checked this morning at my local appliance parts store and they said they dont sell that particular part so i am going to have to order it online.
              ?SHould i do as someone suggested where i short out the current bad part just to make sure that the microwave will turn on?
              Thoughts?
                • Jul 2011
                • 6057
                You could do this BUT I would not recommend that you run it in the bypass mode other than just for testing it
                • Welchs101
                  • Sep 2008
                  • 979
                  ok so i shorted the thermal switch and power returned to microwave........so thats the good news.
                  so now i am trying find the part. i prefer not to use ebay just because its ebay and i have had issues with it in the past. i have also had really good experiences but when they are bad its hard to get money back. anyway, i was wondering if its possible to identify the manufacturer for the KSD1 160 part?
                  Any ideas?
                  • Welchs101
                    • Sep 2008
                    • 979
                    quick question for you all.
                    Do you think the "/" in the 160/ is important. The reason i ask is i have found some replacements where what is shown on the "lid" has the 160 but no "/"
                    i finally found the actual part number and its WB27X11210
                    https://www.geapplianceparts.com/sto...pec/WB27X11210
                    if you go on ge's web site and sure enough this part , which is kinda expensive relative to how much a new machine costs, has the "/" .......so i am just wondering if the parts that have 160 but no "/" if they will really work or not
                    thoughts?
                    • R_J
                      • Jun 2012
                      • 9579
                      The / is not important, KSD1 is the series 160 is the temperature rating. Do you really want to pay $50.00 + s&h for it?
                      Some are listed kds1.160, kds1/160, kds1-160
                      • Welchs101
                        • Sep 2008
                        • 979
                        no i dont want to pay ~ $50 for the "/" part since i can buy a brand new microwave for ~ $150.........
                        But paying say $15 for a part and seeing if this works is fine.......so i may do this but only if the "non /" part is the same as the one that has the "/"..........
                        any idea why it has the "/" on some parts and not on others?
                        • R_J
                          • Jun 2012
                          • 9579
                          I do not know why some put a slash on the end, normally it is between the ksd1/160 to separate the part series from the temperature rating, that's all.
                          If it was made in China or some other country like it, they sometimes mark things different,
                          • edugimeno
                            Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                            by edugimeno
                            Hi There!
                            I'm trying to help my friend who owns a restaurant be just bought.
                            He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                            It's stuck using, I guess, the 2 sided tape that comes with the strip
                            The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                            09-05-2024, 09:34 AM
                          • G-Sting
                            iPad Pro A1876 SHORT Part Identify Help Needed
                            by G-Sting
                            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                            SO My main concern is what part should i order what should i search the name for ?
                            on Ipad...
                            05-15-2025, 09:30 AM
                          • Yanleb
                            Panasonic part number in service manuals
                            by Yanleb
                            In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                            This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                            For an example, look at the attached PDF.
                            Do you have a way to cross reference the Panasonic part number with the actual part number?
                            Thanks....
                            07-03-2023, 08:16 PM
                          • FreakyMex
                            Trouble to identify part (Lunii screen) for replacement
                            by FreakyMex
                            Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                            I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                            02-17-2025, 01:16 AM
                          • esinior
                            Smd code to part number
                            by esinior
                            Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                            I've attached pics of this part
                            Thanks...
                            08-20-2024, 02:50 AM
