A question about PWM IC's
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Hi all.
    Do PWM chips usually start triggering with only the +ve and -ve connected or do they need other signals before they start working?
    I am particularly asking this for the following chip
    https://cdn.badcaps-static.com/pdfs/...2d6a23c015.pdf
    Is the VDD needed or should the Vin and Gnd be enough?
  • R_J
    • Jun 2012
    • 9609
    Re: A question about PWM IC's
    It usually needs the other signals like CS and feedback, otherwise it will likely shut down.
    Why do you ask...
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      On page 3 of your attached pfd files it explains what each pin is used for. Then if you go to page 4 it gives you an internal block diagram of the chip. Inside the block diagram are abbreviations, for each part of the block. On page 5 is the electrical characteristics of the block with the abbreviations and definitions. There is a big "and" gate in the middle which means all signals have to be high in order to get a high out otherwise they are low. The output of the "and" gate goes to the "reset pin" of a flip flop. The other pin of the flip flop is the "set pin" that is connected to the internal oscillator. A flip flop circuit does just that it flips the output Q and Qnot high and low. So, whatever state is high on Q or Qnot it goes low when the reset pin is pulsed. The data sheet has a simple clear to set on these pins which means this is mono state flip flop so the Qnot is high with a high going pulse on set. Then when the reset is triggered most likely a high going pulse then Qnot goes low. Anyway, the data sheet can be broken down for a very good understanding of what the chip is going to need to work.
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Why do you ask...
        Hi R_J.
        I'm learning about SMPS's and am needing a deeper understanding of the control circuitry.
        I have a small lighting PSU which has one of these IC's and it has ~5v on the Vin pin yet is not 'chopping'.
        Therefore there is nothing happening on the primary or secondary of the transformer, and therefore no feedback signal, nor current flow for the FB and CS pins to detect.
        That is why I asked
          • Jul 2011
          • 6070
          Lot of power on pins need a PWM signal for it to work correctly
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            Originally posted by keeney123
            On page 3 of your attached pfd files it explains what each pin is used for. Then if you go to page 4........
            Obviously I had been looking at all the pages, trying to understand how the chip worked, but reading again, it appears that that the VDD is needed too, so I'll check that out when I get indoors.
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              But there must be a 'basic' state in which the PWM chip turns on, no?
                • Jul 2011
                • 6070
                This something like a micro controller of some type or on some devices you can just not use it or you have either make it high or low depending on the device data sheet
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  So let me see if I am understanding this correctly...
                  Voltage applied between Vin, VDD and Gnd sends the chip 'high' on the output (Trig) which turns on the FET, allowing current to flow, which signals the 'SENSE' pin, causing the chip to go 'low', whilst at the same time, a signal is detected across the output by the 431 which in turn varies the opto-coupler resistance to signal the 'FB' pin, ultimately affecting the 'TRIG' signal frequency.
                  The chip then goes high again due to the Vin, VDD and Gnd and the process repeats at many KHz
                  Forgetting any other pin for now, is it essentially something like that?
                  EDIT
                  I'm a bit confused...
                  Looking at the datasheet and the 'Typical Application', the VDD pin connects to an electrolytic, a resistor, a diode, an inductor, and then straight to Gnd.
                  On the 'Terminal Assignments' however, it has VDD as 'DC Power Supply pin.' I had assumed that had meant 5v or so, but clearly not.
                  Therefore this chip should need 5v in the Vin, compared to 0v on the Gnd and VDD.
                  That is what I am measuring anyway.
                  • PeteS in CA
                    • Aug 2005
                    • 3583
                    • USA, Unsure of Planet
                    Start-up current comes from "VIN" (also, line voltage sense). After it has started, house-keeping power for the IC comes from "VDD".
                    It is a current mode regulator, so it needs the output voltage sense signal at "FB" and the sensed primary current at "SENSE" to regulate. "RI" sets the switch frequency, and "RT" is for over-temperature protection.
                    The block diagram shows flyback topology, in which the "transformer" is actually a coupled inductor, in which the "primary" functions as the output inductor.
                    PeteS in CA
                    • R_J
                      • Jun 2012
                      • 9609
                      Hi R_J.
                      That is why I asked
                      I suspect your ic is damaged, The Vin should be higher than 5v, I suspect it should be around 20v at least to provide around 15 volts on the vdd line for startup. The datasheet doesn't show it but there is likely an internal startup circuit that takes the Vin and provides about 15v to the vdd line to charges the startup cap and start the ic, once it starts the vdd voltage is supplied by a feedback winding from the transformer
                      I would check the mosfet and source resistor, if they are ok I would replace the ic
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        Vin is a current sensing device that is passing through and external resistor. This then develops a voltage on the internal operational amplifier. The same internal amplifier has the input from the sense current that develops a voltage across another external resistor which is called the leading-edge blanking pulse. This internal operational amplifier is labeled OC. Which is listed in the electrical characteristics as I_V_DD Operation called operational current. This is the current regulator which then controls the amount of voltage on the top pin of the external primary winding of the transformer.
                        The other internal Operational Amplifier in for the modulation of the Pulse Width.
                        When one considers start up then they have to consider all these factors. One has to have current sensing to regulate. Internal oscillation with sense current input trigger for slope compensation, (Ri) for reference voltage. The Gate voltage is an output of the IC. RT is an output current in the electrical characteristics listed as for temperature protection which give minimum and maximum voltage which will shut down the IC.
                        As a technician I would first look at the outputs of the chip to see if it is working. I would then look at VDD and see if there is a DC supply. Then look at Vin on both sides of the external resistor. If the primary of the transformer has the supplied voltage on it but is not pulsing, then there could be a problem with Gate, the sense, or any other pin of the IC. Most likely the Vin will be good however one can check this by disconnecting the Vin External resistor.
                        • R_J
                          • Jun 2012
                          • 9609
                          If you disconnect the Vin resistor the ic will not work at all, where do you think the ic gets it's voltage to operate? I would first make sure the Vin resistor is not open, If there is 165vdc on one side and 5v on the other either the resistor is close to open, or the ic is bad.
                          • Crystaleyes
                            • Sep 2021
                            • 493
                            • Brazil
                            There are two 470K resistors in series before the Vin, which both measure very close to 470KΩ, so the Vin resistor is NOT open.
                            The voltage here (Brazil) is 116v which means that after the bridge, and at the first resistor, we have 168v, followed by 82v inbetween, and then the 5.4v which is on the Vin pin.
                            When connected up to a 230V supply, the Vin voltage only went up to 6.3v
                            After having individually tested all the other components, it really only leaves the controller.
                            I'll order one online and we'll see,
                            • Crystaleyes
                              • Sep 2021
                              • 493
                              • Brazil
                              The FET and Source resistor are both fine so I'll order an IC and let you all know.
                              Even though some of these fascinating devices can be quite complexed, the pieces are definitely starting to fall into place regarding a basic enough comprehension of SMPS design to feel comfortable performing some repairs. My goal is to do this professionally, so just have to keep practicing.
                              The chopper and feedback circuits are finally becoming clear, so just wanted to say a big thank you for all the input everyone has given.
                              It is truly appreciated.
                              • R_J
                                • Jun 2012
                                • 9609
                                I would order a couple just in case, Sometimes a voltage spike comes down the a/c line and since the ic Vin is connected directly via the two resistors, the ic gets damaged, Hopefully that's all that it needs.
                                Without seeing the board, I would also replace the Vdd electrolytic capacitor, these have a tendency to get weak over time, and testing it usually does not work, I would just replace it.
                                • Crystaleyes
                                  • Sep 2021
                                  • 493
                                  • Brazil
                                  Thanks for the heads-up.
                                  I shall follow your suggestions.
                                  It'll be switched-on through a voltage stabiliser and dimbulb, so hopefully that'll protect it enough.
                                  Pretty sure that the original damage came from a power surge of some kind. I'm in Rio at the moment and power surges/cuts/failures are very common.
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    The lifting of the resistor is to illuminate the IC and concentrate on the other parts of the circuit. While the IC is being powered it can affect the other parts of the circuit. Such as a shorted IC or faulty internal components. I would then be looking for a rippled DC level on the top of the transformer. There would be a little ripple because the regulating circuit in the IC would not be working. However, it would not have a lot of ripple. That might indicate a bad capacitor on the output of the Bridge rectifier. If I received a pulsating DC I would suspect a bad diode in the bridge rectifier. If I received the DC ripple at the appropriate voltage I then would believe the bridge rectifier and capacitor was alright. With the FET turned off I would be then looking for this voltage on the top leg of the FET. One would have to know the voltage level the bridge rectifier is putting out.
                                    In the process of troubleshooting a problem one has to eliminate portions of the circuit that may interfere with other portions. If You read my #12 post again you will see a process of troubleshooting. At the point where the V in is wrong one has to eliminate the chip.
                                    • keeney123
                                      Lauren
                                      • Sep 2014
                                      • 2536
                                      If you have a desire to learn and study, you will become a very good technician. I was an electronic technician for 15 years. I went to two schools for this. One was Pinellas Vocational Technical Institute. The other one was Springfield Technical Community College. I really did not desire to become an electrical/electronic technician. It was something my father wanted me to do. I am at heart a drawing & painting artist. You need not go to school to learn all this stuff. Some people learn better by doing. When problems come up they learn. Good Luck to You.
                                      • Crystaleyes
                                        • Sep 2021
                                        • 493
                                        • Brazil
                                        Hi.
                                        Excuse the delay.
                                        I lifted a leg of the resistor and had a poke around measuring in both DC and AC for any ripple.
                                        There's no working scope here so the testing was done with the DMM and revealed nothing on the DC although did appear to show some AC ripple when measuring across the filter caps and transformer primary.
                                        It shouldn't be the caps as they are new replacements
                                        If I'm honest, I'm not really sure what signs I should be looking for other than low voltages, but perhaps someone can enlighten me?
                                        • ductranvinh
                                          Graphics card repair, Basic Measurements
                                          by ductranvinh
                                          Hi everyone!
                                          The preface to this article is for those who are new to graphics card repair. I'm not as talented as mods or admins either.
                                          But in this article, I will guide you through the most basic things to quickly recognize the disease in each block, so that you can make a foundation as well as form a habit.
                                          Note! This article may or may not be true.
                                          Measurement: (must have boardview of course)
                                          Adjust the impedance scale
                                          12v block
                                          Measure the 12v fuses, see if they burn out.
                                          If the fuse blows, the risk of burning the pcb is...
                                          06-29-2022, 05:12 PM
                                          Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                                          by sam_sam_sam
                                          I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                                          I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                                          I tested the battery cells there are installed right now and they are testing good with no issues that I...
                                          02-04-2025, 08:08 PM
                                        • YellowJacket
                                          Dell P2416DB - no picture
                                          by YellowJacket
                                          Hi friends,
                                          I am here for asking for a little help with this monitor. It reacts to pressing the power button, but the only thing I get is working back light, with no picture. I was measuring all power voltages, you can see them in attached picture. There is 3.3V on the SPI ROM chip, and I can see healthy-looking communication on it ( pin 1 is changing ) after powering on. I can see nice clock signal on both crystals. I am even able to measure some low voltage data signals on LDVDS cable. So I believe, my issue in on the panel itself. I proved it by measuring VGH1 signal on a test...
                                          01-16-2024, 07:45 AM
                                        • DynaxSC
                                          Extreme High Current & Low Voltage Short Killer ??
                                          by DynaxSC
                                          Hi Folks
                                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                          After taking off the socket, the shorts dissappear again.
                                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                          10-15-2024, 10:13 AM
                                          MTFC2GMDEA-0MWT MTFC4GLDEA-0MWT MTFC4GMDEA-1MWT MTFC8GLDEA-1MWT MTFC16GJDEC-2MWT MTFC32GJDED-3MWT MTFC64GJDDN-3MWT Datasheet
                                          Micron MTFC2GMDEA-0MWT, MTFC4GLDEA-0MWT, MTFC4GMDEA-1MWT, MTFC8GLDEA-1MWT, MTFC16GJDEC-2MWT, MTFC32GJDED-3MWT, MTFC64GJDDN-3MWT are a communication and mass data storage device that includes a Multi Media Card (MMC) interface, a NAND Flash component, and a controller on an advanced 11-signal bus, which is compliant with the MMC system specification. Its low cost, small size, Flash technology independence, and high data throughput make eMMC ideal for embedded applications like set-top boxes, digital cameras/camcorders, digital TVs, and a variety other consumer products.
                                          The nonvolatile...
                                          10-07-2024, 04:55 AM
