Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connected
  • grimacelord
    • Jan 2017
    • 380
    Hello.
    Working on an Apple iPad Pro 3rd Generation 12.9" that has a weird issue. When the display is NOT connected, the iPad will charge and power on normally. I know it's on because I can hear notification sounds and the charging notification sound.
    If I connect a brand new display to the logic board, the iPad will not turn on at all. When I connect the iPad to an 18W wall charger and a USB-C ammeter, I can see that the iPad is attempting to charge, but constantly "resets" after just a moment or two.
    For example, when I connect the iPad to the ammeter and 18W charger, the ammeter's display will initially read 5V and about 0.90A. The amps will move up to about 1.2A and then the entire ammeter's display goes blank (as if I unplugged it from the wall) and then the entire process starts over in an endless loop.
    When the screen is not connected, the charging behavior appears completely normal for this model which is 8.93V and 1.87A holding steady.
    I have experimented with the 4 display connectors to see which connector seems to be the culprit by removing one of the 4 cables at a time and retesting after each one. I found that the LCD connector (labeled Connector 1 in my image below) is the one that seems to be at fault. When I have the ribbon cable attached to that connector, the iPad will not power or charge. When I disconnect that cable, but still leave all 3 of the others, the iPad will power and charge normally (but of course I cannot see anything on the screen because that connector is for the LCD)
    I have tried two different displays and they both behave the same way.
    I then thought I would see if there are any diode mode readings of the pins for the LCD connector. I found some online, but my readings seem to be quite a bit different than what is shown on the image I found. I have taken measurements and edited a photo to show what my measurements read versus what I found on the logi.wiki website here. My measurements are the ones in red whereas the original photo's measurements are in white. If I haven't put a red measurement next to the white one, it is because I am reading the same. The only red ones is if I am reading a different measurement than what the original photo listed.
    EDIT: And just as a side note, my measurements more closely resemble the listed measurements on logi.wiki for the iPad Pro 4th gen. ZXW does have part/circuit names listed for the 4th gen, but not the 3rd. It seems like I could likely use the 4th gen boardview to help me with my 3rd gen.
  • grimacelord
    • Jan 2017
    • 380
    Re: Apple iPad Pro 3rd Generation 12.9" (A1876) No Power/Charge When Screen Is Connec
    So it looks like Pins 29 and 27 are the I2C data lines for the display connector. I2C_TCON_SCL_1V8_CONN and I2C_TCON_SDA_1V8_CONN, respectively.
    Pin 29 (I2C_TCON_SCL_1V8_CONN) connects to C4565 and R4561. The other side of R4561 (I2C5_SCL_1V8) connects to R0760 and BE47 pad underneath the SOC.
    Pin 27 (I2C_TCON_SDA_1V8_CONN) connects to C4575 and R4571. The other side of R4571 connects to R0761 and BC47 pad underneath the SOC.
    I have measured each resistor in both circuits and all of them are normal. There are no short to ground in either circuit. I am getting 1.8V on both circuits.
    Am I looking at a SOC (CPU) problem here?
    • mon2
      • Dec 2019
      • 14503
      What is the 820-xxxx part # on your logic board ?
      Is it possible that the LCDs you are testing are incompatible for your logic board?
      What is the part # for the LCD you are testing that causes the logic board to not boot ?
      • grimacelord
        • Jan 2017
        • 380
        820-01435-A is the logic board part number.
        No. The iPad Pro 12.9" 3rd Gen shares the same display assembly with an iPad Pro 12.9" 4th Gen. I have purchased 2 different screens from a reputable vendor that I always use for mobile device repair. The only thing that has remained the same is the LCD flex cables you have to swap from the original display to the new one. Perhaps these cables are faulty? I can't really understand how a flex cable like that would cause this particular issue, but I suppose it's an idea to explore. I can order some new flex cables and just see. I don't have any in stock anyway, so it won't hurt to order some.
        I have tried an OEM refurbished display (OEM Apple LCD with new digitizer) and I have tried a 3rd party display, so neither one of them carry the original Apple part number. The refurbished one might, but I am sure they've covered up the part number with some tape or something. I will have to check on Monday.
        • novafix
          • Aug 2022
          • 3
          Hey Guys, working on iPad Pro 12.9' 3-Gen that Water Damage, need identify component. its tiny power switch i guess. 12EI 95I CG7E. Please help!!!
          • a_p3rson
            Apple Watch Charging Controller Schematics / Boardview - 820-02601
            by a_p3rson
            Hi there,
            I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
            You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
            This daughterboard uses an interesting...
            04-21-2025, 11:41 PM
          • G-Sting
            iPad Pro A1876 SHORT Part Identify Help Needed
            by G-Sting
            So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
            So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
            i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
            SO My main concern is what part should i order what should i search the name for ?
            on Ipad...
            05-15-2025, 09:30 AM
          • Grandoni Manuel
            iPad Pro 11 3th no charge no power
            by Grandoni Manuel
            Hello experts ! Have big problem and not understand with iPad Pro 11 3th gen.
            So with power supply work perfectly but if I connect usbc not power on !
            first under thermal can find a short near CD3217 on the 3v3 ACE line ! Take off it then stuck at 5v and 0 amps !
            then I try to change CD3217 with other one from MacBook but the iPad now shout down also the tool for see voltage and amps 😅
            ok then I want try to take one directly to donor working board and also the eprom for safety but stuck again 5v 0amps !!!!
            incredible 😳
            mom then I tried to...
            04-26-2025, 02:03 AM
          • GeirAndersen
            iPad .pcb file collection
            by GeirAndersen
            I tried searching the forum for whether this has been uploaded already, but couldn't find them (as a collection).
            Here's a dump of a bunch of iPads, I've split into 2 archives to get under file limit
            IPAD COLLECTION 1
            +---iPad mini1 820-3400(A1432) 820-3243(A1454?A1455)
            +---iPad mini2 820-3683(A1489) 820-3684(A1490?A1491)
            +---iPad mini3 820-00008(A1599) 820-00002(A1600)
            +---iPad mini4 820-00180(A1538) 820-00177(A1550)
            +---iPad mini5 820-01591(A2133) 820-01495(A2124?A2125?A2126)
            +---iPad Pro 12.9-4-820-01797(A2229) 820-01798(A2069?A2232?A2233)...
            12-09-2024, 09:28 AM
            Apple iPad 4th Generation 820-3249 Boardview and Schematic
            Apple iPad 4th Generation 820-3249 Boardview and Schematic...
            11-01-2024, 02:45 PM
