B+ Voltage rail; Lenovo Y510p VIQY1 NM-A032
  • ITworkshop
    • Feb 2022
    • 32
    • Poland
    I'm a begginer still at repairing motherboards in laptops, but I'm willing to learn.
    Its the second time I got a laptop that doesnt draw any power. For this laptop Lenovo Y510p VIQY1 NM-A032: No visual damage, no liquid damage, just doesnt turn on. No shorts on all chokes. Voltage is coming in 20V, then after second power IC after VIN (PQ302) it goes down, to 8V. I have schematics, boardview, multimeter, own regulated power supply, soldering iron and hot air station, and some free time.
    Quick question nr. 1: does the B+ Voltage rail, should have any voltage without the battery? Its the same rail for battery charging?
  • mon2
    • Dec 2019
    • 14672
    Re: B+ Voltage rail; Lenovo Y510p VIQY1 NM-A032
    Remove all power.
    Meter in resistance mode (lowest scale).
    Check the resistance of the mosfet pins to check for possible damage:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate(4) & drain (5-6-7-8)
    Post each reading, in order for PQ301 and then PQ302.
    Then, check the resistance to ground of pins 5-6-7-8 (drain) of PQ302.
    That is, red meter lead to either 5-6-7-8 pins; black meter to ground.
    What is the resistance to ground of the P3 rail ?
    • ITworkshop
      • Feb 2022
      • 32
      • Poland
      Measurements: pins on the left red probe, pins on right black probe:
      PQ 301:
      source (1-2-3) & drain (5-6-7-8): 0,48MOhms
      source (1-2-3) & gate (4): 125kOhms
      gate(4) & drain (5-6-7-8): 0,7MOhms
      PQ 302:
      source (1-2-3) & drain (5-6-7-8): 12kOhms
      gate(4) & drain (5-6-7-8): 0,5MOhms and rising to 0,9MOhms
      Ive tested PQ301 and PQ302 resistance to ground earlier, and some readings were strange. This are the readings:
      PQ301:
      Pins: 1-3: 60kOhms and rising, 96 and slowly rising; 2nd measure: 0,5MOhms
      4: 0,6MOhms 2nd measure: 118kOhms
      5-8: 135 kOhms
      Maybe im switching gates measuring so fast (no voltage is connected to the motherboard)
      PQ302:
      Pins: 1-3: 0,4MOhms
      4: 0,6MOhms
      5-8: 5kOhms rising to 10kOhms; 2nd measure 0,5MOhms falling to 0,4MOhms; this time I was measuring only 1 pin (pin 8), and 2 different measurements were showing up.
      To answer your last question resistance P3 to ground is 5-10kohms or 0,4MOhms
      • ITworkshop
        • Feb 2022
        • 32
        • Poland
        Oh, I've misstyped. Voltage VIN 20V, Voltage at PQ302 pins 5-8 is 0,8V, not 8V.
        • ITworkshop
          • Feb 2022
          • 32
          • Poland
          I've checked once more the lowest resistance on PQ302,
          Red probe source 1,2,3 , black on drain 5,6,7,8 - 12kOhms. And on the second reading, 60KOhms.
          • mon2
            • Dec 2019
            • 14672
            PQ302 has too low of a resistance and should be replaced.
            These mosfets are not expensive so recommend to also replace PQ301.
            What are the markings on each part ?
            Is it AO4423L ?
            There are many valid replacements for this mosfet.
            https://www.aliexpress.com/premium/A...psort=1&page=1
            If you wish to source from a local supplier, post back to see if we can find a drop in replacement from TI or similar.
            • ITworkshop
              • Feb 2022
              • 32
              • Poland
              Well it turns out that the PQ301 is 4423, AO company, but the PQ302 is 4483A with a B logo, or is it crossed S? And a triangle at the right - screenshot in the attachement.
              Strange, why would they use different mosfets than on the schematic?
              Should i replace both of them for the same mosfet model? 4423 is best for this application?
              I've found TC4423AVOA MICROCHIP TECHNOLOGY, at my local supplier, but its a little bit more expensive, than other mosfets that I've already ordered, and after reading datasheet for it, I think its a dual mosfet (DRMOS?).
              Couldn't find anything 8pin 30V 17A or higher... Maybe I'm searching this the wrong way. If I could ask you, for finding me a replacement for this IC, I would be grateful:-) my local supplier has this website, with all the ICs: www.tme.eu
              I could also desolder them and check the resistance to ground, if You think it would help. Also I've noticed that Resistor PR301 is lower than it should be (when measured on board it has around 138kOhms measuring on both sides, not to ground). When applying 20V, after PR301 there is 6,8V. I doubt that 6V is used on a motherboard:-)
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                The picture is si4483a mosfet.
                Regards
                • mon2
                  • Dec 2019
                  • 14672
                  Hi.
                  1) The Microchip part is not the same as the mosfets showing in the schematic so ignore that option.
                  2) The schematic shows AO4423L for both PQ301 & PQ302 so suggest this as one option - use the same for both landing pads.
                  3) Other valid options are to replace with a part such as the following:
                  < the following looks to be a better part than the original >
                  https://www.mouser.ca/ProductDetail/...ySH5KPIg%3D%3D
                  p/n SI4459BDY-T1-GE3
                  P-Channel 30 V (D-S) MOSFET
                  Supports upto 27A
                  • ITworkshop
                    • Feb 2022
                    • 32
                    • Poland
                    Ok, thank You very much for help.
                    I've ordered SI4459ADY, because B wasn't available here. Its little less resistant to pulsed drain current, but still rated above 20 Amps for continous drain current.
                    I'll write back, after replacing them, probably tommorow, or monday.
                    • ITworkshop
                      • Feb 2022
                      • 32
                      • Poland
                      I've replaced both mosfets, no changes. 0,8V After PQ302, 0A current.
                      Whats the next thing I should try/ check / measure?
                      • mon2
                        • Dec 2019
                        • 14672
                        Remove all power. Meter in resistance mode. Measure the resistance of the replaced mosfets as before.
                        Post the measurements.
                        • ITworkshop
                          • Feb 2022
                          • 32
                          • Poland
                          PQ 301:
                          source (1-2-3) & drain (5-6-7-8): 60 KOhms, on second measurement 0,4MOhms
                          source (1-2-3) & gate (4): 120kOhms
                          gate(4) & drain (5-6-7-8): 0,6MOhms
                          PQ 302:
                          source (1-2-3) & gate (4): 120 kOhms
                          PQ301 and PQ302 resistance to ground the readings:
                          PQ301:
                          Pins: 1-3: 60kOhms and rising to 90kOhms; 2nd measure: 0,45MOhms
                          4: 0,6MOhms
                          5-8: 130 kOhms
                          PQ302:
                          Pins: 1-3: 80 kOhms, then 2nd reading: 0,47MOhms
                          4: 0,6MOhms
                          Almost no difference between old mosfets
                          • mon2
                            • Dec 2019
                            • 14672
                            Yes, B+ should be ~VIN from external DC adapter, when the adapter is used. This is the priority. External adapter is selected even if the battery is attached.
                            BATT+ is a lower voltage than VIN and is used to charge the battery but the BATT+ voltage is defined by switching ON/OFF the mosfets @ PQ311 & PQ312.
                            The battery mosfet @ PQ310 will be open when the VIN from the external DC adapter is not present (ACDET signal is used to detect if the adapter is present). In this case, the BATT+ voltage will be used to power the B+ rail.
                            For these tests, remove the battery if it is attached.
                            Then take voltage measurements of the mosfet pins @ PQ301 & PQ302.
                            Also measure the voltages (carefully so no pins are shorted with the meter) of PU301.
                            Post your readings.
                            • ITworkshop
                              • Feb 2022
                              • 32
                              • Poland
                              PU301: BQ24737
                              1 ACN: 0,8V
                              2 ACP: 0,8V
                              3 CMPOUT: 0V
                              4 CMPIN: 0,185V
                              5 -ACOK: 0V
                              6 ACDET: 2,843V
                              7 IOUT: 0V
                              8 SDA: 0,032V
                              9 SCL: 0,033V
                              10 ILIM: 0,001V
                              11 -BM: 0,003V
                              12 SRN: 1,172V
                              13 SRP: 1,172V
                              14 GND ---
                              15 LODRV: 0V
                              16 REGN: 6V
                              17 BTST: 5,78V
                              18 HIDRV: 1,18V
                              19 PHASE: 1,18V
                              20 VCC: 19,5V
                              21 TP /GND---
                              power in: 20V
                              I've noticed that PC308 was partially desoldered, so I've resoldered it before measurements.
                              • mon2
                                • Dec 2019
                                • 14672
                                See a few faults starting with:
                                3 CMPOUT: 0V
                                4 CMPIN: 0,185V
                                Can you confirm these readings again ? Both should be the same reading or very very close to each other. Use the lowest scale on DC volts scale for your meter.
                                • ITworkshop
                                  • Feb 2022
                                  • 32
                                  • Poland
                                  Before PQ308, VIN is 20V, after R324, only 7V, and PAC outputs (pin 2 and 3) of PQ308 are 0V, so does the ACPRN output (pin 5) has 0V. This probably blocks the AC OK status of pin 5 in PU301? or I'm wrong?:-)
                                  • ITworkshop
                                    • Feb 2022
                                    • 32
                                    • Poland
                                    3 CMPOUT: 0V
                                    4 CMPIN: 0,185V
                                    Pin 3 is 0V
                                    Pin 4 is 0,08V and slooowly falling down
                                    Next measurement:
                                    pin 3: 0V
                                    pin 4: 0,125 and falling down. The longer the power is in, the lower Voltage it has. After reconnecting 20V, it goes up to 0,125V
                                    • mon2
                                      • Dec 2019
                                      • 14672
                                      Sorry, my bad on the comments of:
                                      3 CMPOUT: 0V
                                      4 CMPIN: 0,185V
                                      Thought it was a current sense leg on the charger IC. Ignore this.
                                      • ITworkshop
                                        • Feb 2022
                                        • 32
                                        • Poland
                                        Quick question: what does the CMP IN and OUT mean? what is CMP?
                                        • Nagy Daniel
                                          Lowest possible resistance on laptop motherboard rail - Guide Table request
                                          by Nagy Daniel
                                          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                          So, I generated a table with AI so I can...
                                          03-04-2025, 08:24 AM
                                        • Victor Moreira Silva
                                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                          by Victor Moreira Silva
                                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                          Well, my decice specs are the following:
                                          Model: Acer Nitro 5 AN517-54-55T5
                                          CPU: Intel Core i5-11400H
                                          GPU: NVIDIA GeForce GTX 1650
                                          Motherboard: GH51G LA-L181P Rev:1c
                                          The symptom:
                                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                          05-26-2025, 10:49 AM
                                        • lefetylorant
                                          Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                                          by lefetylorant
                                          Hello Everyone,
                                          Long story short, I got this unit for very cheap.
                                          I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                                          I've performed some measurements:
                                          - 20V rail perfectly...
                                          09-14-2023, 05:05 AM
                                        • bimole
                                          Weird behavior on 3.3V rail of a CORSAIR CX600
                                          by bimole
                                          A colleague gave me an apparently ill CORSAIR CX600.
                                          He told me that he heard a banging noise, and smelt the magic smoke.
                                          After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                                          I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                                          It's another story on the 3.3V rail...
                                          I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                                          02-13-2025, 04:49 AM
                                        • mkdj
                                          Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                                          by mkdj
                                          Dear all,
                                          I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                                          I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                                          Both N-Channel Mosfets: nothing odd
                                          P-Channel MOSFET number 1:
                                          source - drain : 117 kOhm
                                          source - gate: 96 Ohm
                                          gate - drain: 117 kOhm
                                          P-Channel MOSFET...
                                          08-20-2025, 06:08 AM
