Dell password for Hynix SC210
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    I've had no success with a couple of Dell password generators, both originating from HPGL, Russia
    Trying the right 11 characters of SC210's serial number, and also the code given by Dell's lock message
    Also no success with BIOS_PW.ORG, using first 7 characters of Dell's lock message
    FWIW, BIOS_PW generates same codes when I input same as for HPGL
    Could someone please supply a password, or advise what I'm doing wrong above
  • bachir2004
    • Feb 2015
    • 439
    • maroc
    Re: Dell password for Hynix SC210
    1l38lch8
    7l31hgft
    hCRBdj44et6NAibG
    s90b12lt
    ytwDIoKDLh87bXeG
    t3OOq2ZP7J9Y2Ii0
    rKbm2CtV52CcHSVB
    try some of these ones must work.better start from bottom to top;
    • anhbanxoi
      • Sep 2021
      • 180
      • VN
      Originally posted by bachir2004
      1l38lch8
      7l31hgft
      hCRBdj44et6NAibG
      s90b12lt
      ytwDIoKDLh87bXeG
      t3OOq2ZP7J9Y2Ii0
      rKbm2CtV52CcHSVB
      Pls help me generate some passwords for this code TNBRHCO4311-2A7B/TNBRHC04311-2A7B
      • hoaca388
        Badcaps
        • Jan 2022
        • 12422
        Have you tried entering the password using an external keyboard, US layout, USB 2.0 interface?
        ​https://www.badcaps.net/donate
        • pfrcom
          Oldbie
          • Jun 2006
          • 1230
          1l38lch8
          7l31hgft
          hCRBdj44et6NAibG
          s90b12lt
          ytwDIoKDLh87bXeG
          t3OOq2ZP7J9Y2Ii0
          rKbm2CtV52CcHSVB
          @hoaca388 I've now tried it, after reading your suggestion
          @bachir2004 Thank you for the effort
          Regretfully none of them work, trying both notebook keyboard and external keyboard
          • imranromi
            • Jan 2015
            • 1290
            • Pakistan
            Mostly Ssd password accept when ssd lock same bios.If this Ssd lock same model then can unlock.
            If ssd lock other laptop and you want try dell other model
            i dont think its work.
            • anhbanxoi
              • Sep 2021
              • 180
              • VN
              Do you have any idea on how to erase those drive? I heard that this device can erase password protected drive but not sure if it's worth to try.
              StarTech USB 3.0 Hard Drive Eraser Dock for 2.5" & 3.5" SATA SSD HDD + 4Kn Drive - LCD/ RS232 - Secure Erase HDD Wiper Docking Station (SDOCK1EU3P2)
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Thank you to everyone who participated
                I am making progress
                Now have generated a password using https://beta.bios-pw.org/ (thanks SMDFlea) which is accepted with Ctrl&Enter from notebook keyboard
                But even though I see "Secure Erase in Progress", the Lock message returns when it reboots
                Noting imramromi's advice, tomorrow I'll put the SSD back in its original E7250, try again, and report back
                • bachir2004
                  • Feb 2015
                  • 439
                  • maroc
                  tomorrow I'll put the SSD back in its original E7250, try again, and report back[/QUOTE]
                  to unlock the ssd it must be in the original machine where the password has been created.
                  • pfrcom
                    Oldbie
                    • Jun 2006
                    • 1230
                    I did restore SC210 into original E7250
                    A bit disconcerting that suffix of lock message had changed from 2A7B to 1F66
                    Anyway I generated another password using https://beta.bios-pw.org/
                    This too was accepted with Ctrl&Enter from notebook keyboard, but unlike when SSD was in E6330, "Secure Erase in Progress" took two or three minutes
                    And when E7250 was rebooted, there was no error message and Dell BIOS Security showed Primary disk: No password set
                    Thanks again to everyone who participated
                    • Bowline
                      by Bowline
                      06-11-2025, 10:13 AM
                    • Akhlz001
                      Dell Pro 13 Plus PB13250 Bios Unlock
                      by Akhlz001
                      Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                      09-20-2025, 07:15 PM
                    • master3112
                      Dell Inspiron 5590 Board 18778-1 no charging, charging not possible
                      by master3112
                      I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
                      Alert! The AC power adapter wattage and Type cannot be determined. The battery may not change. The System will adjust the performace to match the power available.
                      The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...
                      07-29-2025, 01:55 PM
                      Dell Thunderbolt Firmware
                      by SMDFlea
                      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                      The SKU is in brackets (****)
                      EDIT: NVM65...
                      01-26-2025, 06:22 AM
                    • dell_sadness
                      Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                      by dell_sadness
                      BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                      Have extracted the BIN and want to know how to rebuild a clean BIOS
                      I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                      I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                      Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                      11-12-2025, 02:54 PM
