FCL30A015 diode reverse biased shows 35 Ohm, 0.05V forward. Is it gone?
  • caprider
    • Jan 2022
    • 24
    • Romania
    I am troubleshooting a power supply.
    When measuring a FCL30A015 diode it shows 35 Ohm when reverse biased and 0.05 forward voltage.
    See attached.
    The datasheet does say "Extremely Low Forward Voltage Drop": https://www.alldatasheet.com/datashe...FCL30A015.html
    But 0.05V seems to low.
    Is it gone?
    Should I perform some other test?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: FCL30A015 diode reverse biased shows 35 Ohm, 0.05V forward. Is it gone?
    looks shorted to me, the resistance (in resistance mode) should be very high when reverse biased, 35Ω is way too low. 0.05V forward drop not normal either, though lower currents like your DMM should show lower voltages, but something lower than ~0.15V are suspect.
    • redwire
      • Dec 2010
      • 3912
      The diode is shorted. It's just a Schottky rectifier Vf should be ~0.25V up to 0.42V at 10A.
      If you are not sure, push some current through it. Use a car light bulb and 12V power supply and see what it does.
      Many times a diode or transistor gets damaged/shorted but of course will not read like a 0 ohm short. They will still read like a bit of a diode junction is there.
      • caprider
        • Jan 2022
        • 24
        • Romania
        I am not so sure any more. I have 4 of these diodes in the PSU and all read about the same.
        If I create a circuit with my lab PSU at 32V and a 1k ohm 50W resistor (the smaller resistors that I have are too low power) with the diode in series it only conducts as it should: with minus terminal in the middle. And it does not get reverse biased - as it should.
        Maybe I am missing something about these diodes?
          • 31267
          it's your meter,
          i get this with schottky diodes too - infact i get fluctuating readings on one meter
          • caprider
            • Jan 2022
            • 24
            • Romania
            How can I test the diode then?
              • Jul 2011
              • 6070
              Simple just use an incandescent light bulb and try powering from both directions in one direction it should light the light bulb and the other direction it should not
              • PeteS in CA
                • Aug 2005
                • 3583
                • USA, Unsure of Planet
                That's a 30A, 15V Schottky. It has a very low forward drop, possibly for use as a high current or'ing rectifier. Its normal characteristics could "fool" a DMM diode checker. I'd suggest doing an in-circuit test using a 1K (or similar) resistor and a 5V or 12V source, in both polarities.
                Long, long ago, when the Soviet Union was still in existence, IR introduced a series of low reverse voltage, ultra-low low Vf Schottkys for redundant power supply configurations. More modern server Power supplies use MOSFETs to gate or un-gate outputs to the load (with current-sharing circuits). This gate or un-gate function also permits quickly disconnecting a power supply from the load in the event of a fault.
                PeteS in CA
                • caprider
                  • Jan 2022
                  • 24
                  • Romania
                  It's a PSU from a Supermicro server that has 3 hot swap power supplies (n+1). It might be a FSP PSU, IIRC, I'm away now and can't check. So nothing Russian in there.
                  Server is over 10 years old.
                  • redwire
                    • Dec 2010
                    • 3912
                    OP I changed my mind because the datasheet specs say these are normally quite leaky diodes.
                    (Nihon Inter Electronics Corporation) FCL30A015 shows 15V 30A rating with Irm max. 15mA leakage at 15V. Compare with say a MBR3040CT 30V 30A the spec is 0.5mA, some companies say 0.1mA, but those have much higher Vf 0.84V vs 0.42V which means much more heat 2x compared to FCL30A015. It's a tradeoff.
                    High power Schottky diodes have high leakage currents, but these ones are really high? And they can be made by small, dirty semi companies lol.
                    So in reverse bias, up to 15mA leakage. They'll act like a good diode but with a low value resistor across them which will not read good with a multimeter which usually use around only 1mA test current in Ohms/Diode-test mode. The reverse leakage is more like a constant current if I remember right, and goes way up with temperature.
                    I would say you need to test them with higher current, like you did 1k resistor and 15V max.
                    • caprider
                      • Jan 2022
                      • 24
                      • Romania
                      I did test them with a 1k resistor and 32V from a lab power supply.
                      According to the PSU they take about 0.03 A when forward biased and 0.0 A when reverse biased.
                      So according to this test, they are working ok.
                      • PeteS in CA
                        • Aug 2005
                        • 3583
                        It's more likely to be made by Compuware, Delta, or Samsung.
                        PeteS in CA
                        • caprider
                          • Jan 2022
                          • 24
                          • Romania
                          So with a 21W load (car light bulb) on 12V the diode only passes the right way. With zero Amps leaked when reverse biased.
                          I think the multimeter is misleaded because it leaks some current on low Amps when reversed biased.
                          Also, on 12V with a 1K resistor it actually leaks 0.01 A when reverse biased. It's not zero Amps like I've written before. Above I mistakenly tested another component.
                          So the FCL30A015 look ok and seem to be used as ORing for hot swap.
                          This diodes design idea was probably to be highly efficient on high Amps and they disregarded any leakage on low Amps.
                          • Baste
                            MBR3045CT and SR3045LCT Schottky diode testing help.
                            by Baste
                            Hello experts,
                            Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                            Aneng ST182 Meter.
                            Diode mode.
                            MBR3045CT:
                            Diode mode
                            Pin 2-1 - 0.150v
                            Pin 2-3 - 0.150v ...
                            10-21-2025, 06:14 AM
                          • bpjl
                            Dell E7450 LA -A961P - diagnostics after flooding and damaged PD817, PD5 diodes
                            by bpjl
                            I have La-A961P Rev: 1.0 (A00) from a flooded laptop on the table. The computer was flooded with tea and at the same time the power supply was disconnected, the battery was removed immediately and the laptop was turned upside down.
                            I looked at the mainboard, but I don't see any marks of water damage. Maybe the liquid did not reach MB, or maybe I just don't see it.
                            During the inspection, I noticed a burned (charred on one side) double diode PD817.
                            Voltage drops during PD817 measurements:
                            - PIN1-PIN3 forward biased = 0.137V...
                            01-27-2025, 03:01 PM
                          • jezzaaaa
                            Identify replacement diode
                            by jezzaaaa
                            I'm trying to find a replacement diode for one that has gone short.
                            I have a generic USB charger that went short circuit to ground on 5V. I found that one of a pair of identical diodes in parallel (and in series with transformer secondary winding) has gone short in both directions, so I suspect it's bad. The marking is CSRS1045, which I believe is a low barrier Schottky with max current 10A and max reverse 45V. I found a spec sheet for CSRS1045-A that has same specs and also says 350mV drop when forward biased.
                            I can't find the exact part number for sale. Similar...
                            05-09-2023, 11:26 PM
                          • SuperAman
                            PNP transistor symbol?
                            by SuperAman
                            I have a question about PNP transistor symbol. Usually the emitter arrow pointing in the direction of the base is at top where the collector would be. I got asked on a test where the arrow is pointing toward the base but was in the spot of the collector. The answer choices was PNP or NPN and forward biased or reverse biased. So is it a PNP that is forward biased or reverse biased? Usually on the schematics for PNP the Emitter is on the top and collector is on the bottom....
                            04-14-2025, 06:11 PM
                          • quickname
                            Cyberpower 1500AVR UPS repair
                            by quickname
                            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                            Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                            I decided to verify that the batteries were...
                            11-12-2023, 09:57 AM
