42LM670TZA , picture freezing , then powers off , or hanging on LG logo .
  • zen
    • 511
    Hi all
    Issue seems to be slightly tap sensitive , although that might be a complete coincidence .
    Main board problem none the less .
    Can anyone advise .
    I'm leaning toward re-balling the main BGA processor chip .
    Have the correct stencil in stock , therefore must have re-balled one of these chips in the distant past .
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: 42LM670TZA , picture freezing , then powers off , or hanging on LG logo .
    All signs point to BGA, I have one of these boards from a 42LM6400, after reflowing the main chip it lasted for 2 years, then further reflow attempts failed to make the TV last even 1 minute powered on.
    But the TV should not freeze, it should power off immediately or not even get out of standby when it's the main chip.
    • zen
      • 511
      Thanks for the input .
      I don't tend to re - flow any more , as it doesn't seem to be reliable .
      Will re - ball & report back
      • zen
        • 511
        On removal & inspection of BGA , may have worked out issue .
        part of track , which looks to be a through hole point seems to have been exposed , by heat from the a capacitor that sits directly under it .
        Could try some solder mask to insulate point then fit chip back .
        Although it looks like it from picture it's not a pad .
        • zen
          • 511
          Re-ball seems to have gone really well , & solder mask to took exposed track .
          • zen
            • 511
            Well i'm genuinely surprised .
            Set powers & now working on a test .
            Lets see how it behaves , or not a the case may be .
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              Nice job on the reballing process, hope it fixes it.
              • zen
                • 511
                Thanks again
                • dskall
                  • Oct 2016
                  • 2905
                  • usa
                  Reballed a Vizio a couple years ago. Still working in the living room.
                  • zen
                    • 511
                    Nice one, yes re-balling rather than re-flowing seems to be the way to go for me .
                    Have been experimenting for a few years now & have quite a reliable technique with the equipment i use .
                    Many re-balling videos on You Tube .
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      I think leaded solder is superior to the brittle unleaded. Military still uses leaded solder for reliability.
                      • zen
                        • 511
                        Most definitely .
                        Aviation also , & quite possibly medical equipment .
                        More work for us i suppose
                        • csmith
                          Vizio D50u-D1 Powers up no picture
                          by csmith
                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                          issue. Set will power up with remote but not power off....
                          07-11-2025, 11:52 AM
                        • sergio_av
                          Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                          by sergio_av
                          Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                          Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                          When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                          Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                          01-01-2025, 05:27 PM
                        • KYBOSH
                          Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                          by KYBOSH
                          Saved this beast from the landfill this weekend.
                          Manfactured July 2013 in Mexico.
                          I love working on plasma TVs.
                          Its been a while but I was lucky enough to find 2 this week.
                          The TV powers on and stays on but no picture. Havent checked for sound yet.
                          No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                          Will start troubleshooting tonight.
                          10-17-2024, 01:17 PM
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
