Seasonic dead after wrong SATA power cable
  • ViktorMS
    • May 2022
    • 3
    • Iceland
    Hey I am wondering if anyone has tips to repair a completely dead Seasonic SGX 650.
    I plugged in a Thermaltake modular cable by accident and the PSU died. Everything else survived.
    The first image (with molex pinouts) is the Seasonic PSU. The second one is the faulty Tt cable.
    I measured the resistance of 12V 5V 3V3 and they keep rising until I get an OL reading.
    Any tips?
    Thanks.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Seasonic dead after wrong SATA power cable
    Do you have any 5VSB on the 24pin molex connector?
    If not have you checked the basics like the fuse?
    • ViktorMS
      • May 2022
      • 3
      • Iceland
      I checked the main 240V fuse and it is not blown.
      I jump started the PSU and get 0V on 5VSB and everything else, 12V=0V, 5V=0V and 3V3=0V.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        I did the same thing and I made a thread about it. In my case it blew the protection diodes in the HDD. It shut the psu down instantly. Anyway… with everything unplugged from the PSU, just plug it into power mains, short the green wire to the black wire on the molex connector and it should fire up. Those things have over current and over voltage protection to save the PSU and prevent a major event. So depending on what you had plugged into the wrong cable, it can stop the computer from working.
        https://www.badcaps.net/forum/showthread.php?t=58320
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Ok, if you do not even have 5v standby working you will have to start from the beginning: measure the voltage on the big main filter capacitor.
          It should be around 325v DC with 230v AC input.
          If you have a "shaver socket" or something like that providing low current 120VAC that is safer to use, then the voltage should be around 170VDC.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8352
            See if PSon voltage is present between the green wire and a black wire. Measure it with your DMM, you should have something like 2.5V there.
            • coinwizx
              Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
              by coinwizx
              Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
              09-09-2025, 03:11 PM
            • DynaxSC
              GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
              by DynaxSC
              I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
              There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
              The board is generally working now, all PCIe ports are working, Windows installs normally.
              However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
              The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
              03-10-2025, 12:27 PM
            • fweonea
              HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
              by fweonea
              While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
              I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
              01-16-2024, 11:35 AM
            • playit
              ps/2 port keyboard dead ? p5ql pro / ethernet cable light
              by playit
              my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
              my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
              few years back ps2 mouse stopped working, but ps2...
              12-23-2024, 06:05 AM
            • Loli Popu
              DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
              by Loli Popu
              Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
              12-13-2024, 03:28 AM
