question for equivalent igbt
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    i have igbt fgd3245g2-085 can anyone to suggest me an equivalent ?because its difficult to find it and take it soon
    thanks in advance
    • Jul 2011
    • 6070
    Re: question for equivalent igbt
    You can find them here
    https://www.mouser.com/ProductDetail...fuRgBh9g%3D%3D
    Just select the country from where you live and see if they have them in stock
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      thanks a lot sir Sam just i want to buy from
      https://www.tme.eu/en/details/fgd324...istors/onsemi/
      in yours address the case is to252
      in mine is Dpac
      will i have problem in your opinion ?
      and the pins of fgb3245 are same with the pins of fgd3245 right ?
        • Jul 2011
        • 6070
        You will have to check the data sheets for both of them or you will have to make a circuit board if the pin outs are different if all other specks are the same it should work
        If the website page that you posted is the exact same part number then I would order from them if you trust the company
        • adigrf
          How can I find this chip equivalent?
          by adigrf
          Hello! I saw on my motherboard DAG77MB18C0 rec C that I have a burn chip and I also found a similar one in good shape but I am having troubles recognizing and finding it online in order to replace it.
          What I can read is: DN46AP 22cf 1000 and Gemini is telling me it is a MOSFET by On Semiconductor model NVMFD5c466n
          Do you think this is real ?
          The laptop is still starting but I dont want to use it until I replace that. Based on the images, do you think I will succed with a profesional electronic technician?
          06-22-2025, 12:37 AM
        • trepachka
          Trying to find an equivalent component Inspiron 7706
          by trepachka
          Hello, I have this Inspiron 7706 that is not starting. It flashes 5 white/3 amber combination indicating "Power rail failure".
          I found this shorted component U6601 on the motherboard with markings "53BC". Accoring to the schematics it's SY6288DAAC-GP.
          They are available in China which means a 3 week wait.
          My question is this: is there an equivalent I can get quicker which will do the job? Thanks....
          11-30-2023, 04:27 AM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • electroproz
          PS5 power supply edp-400FR repair question
          by electroproz
          Does anyone know if there is an equivalent for the DNP014? Just like the DAP053, which has the TEA2016AAT as an equivalent. I have a fault with this IC and grok seems to suggest TEA1762T/N2 as a replacement however I can't seem to find anything online in regards to that...
          11-12-2025, 10:42 AM
        • danielgerman681
          ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
          by danielgerman681
          Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
          08-27-2025, 01:17 PM
