Honton ICS-5630 BGA Machine Users Manual
  • Ayrtec
    • Mar 2021
    • 4
    • United Kingdom
    Hi I am currently seeking help to find a copy of this operators manual for a Honton ICS-5630 Model BGA Machine , Please anyone out there that can help PLEASE PLEASE PLEASE.
    • 31281
    Re: Honton ICS-5630 BGA Machine Users Manual
    http://www.szhonton.com/page84?_l=en&product_id=54
    email Honton?
    • Xenon-Codex
      Need service manual for Salora 923N VHS machine
      by Xenon-Codex
      Does anybody have it, or does anybody know who made the unit? Toshiba and Sanyo parts inside.
      It was the upper end model in early 1990's.​ It even has the audio recording balance and volume knobs. ...
      01-13-2025, 09:38 AM
    • CG2
      Janome DC3050 Sewing Machine Pedal Resistance
      by CG2
      OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
      Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
      04-14-2023, 07:53 AM
    • Soulzink
      Samsug washing machine. Power supply DC41-00189a board issue
      by Soulzink
      Hi everyone,
      I am trying to fix a samsung washinmachine power supply main board.
      I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
      Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
      The power supply board reference is the following: DC41-00189a
      I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
      04-19-2025, 06:26 AM
    • unimatrix93
      How to stabilize AC voltage to CNC machine
      by unimatrix93
      Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
      I have a CNC machine wired to 3-phase 230V AC.
      It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
      The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
      I contacted the electricity company but they refuse to help me solve this problem.
      So I started to look around for some DIY...
      03-17-2025, 05:52 AM
    • xdever
      820-01700 not booting, 4V PP2V5_NAND_SSD0 but 2.5V when the machine is off.
      by xdever
      I got a 820-01700 of a friend that doesn't turn on. I read that a typical issue with these boards is the TPS62180 generating the NAND voltages, so this is where I started looking. Sure enough, PP2V5_NAND_SSD0 is 4V when the machine tries to turn on (I try to determine this by measuring PP2V5_NAND_SSD1, which is 2.5V as it should in this case. The PP0V9_SSD0 and PP1V8_SSD0 power supplies for the SSD are on at the same time when PP2V5_NAND_SSD0 is 4V). The extremely weird thing is that when the machine is off (PP2V5_NAND_SSD1=0, PP0V9_SSD0=0 and PP1V8_SSD0=0), PP2V5_NAND_SSD0...
      01-15-2025, 08:44 PM
