RCA RLCDV3282A-B LCD power off and on every few minutes
  • rookiecap
    • May 2022
    • 6
    I have a LCD combo tv model RCA RLCDV3282A-B, and it broke down. The symptoms were
    [1] very low volume
    [2] flickerring image proportional to sound and brightness
    [3] the power turns off and on every few minutes
    So I took it apart and looked at the power board. I found some swollen capacitors. So I replaced all electrolytic capacitors (14 of them) according to their original specs.
    Unfortunately it did not fixed all problems. I have a the volume and no more flickering (good image). However, the power turns off and on every few minutes randomly.
    What I am missing? What are my next steps?
    Last edited by SMDFlea; 05-16-2022, 12:42 PM. Reason: Added "RCA RLCDV3282A-B" to thread title
  • nomoresonys
    • 12323
    • U.S.
    Re: RCA RLCDV3282A-B LCD power off and on every few minutes
    might be a solder joint problem, recheck your work and check all other solder joints.
    • nomoresonys
      • 12323
      • U.S.
      some examples of bad joints: https://www.google.com/search?q=bad+...ih=607&dpr=1.5
      • dskall
        • Oct 2016
        • 2905
        • usa
        Next step is pictures
        • rookiecap
          • May 2022
          • 6
          For all of the replies, thank you. I am attaching pcb board images. I accept criticism with no hard feelings.
          • dskall
            • Oct 2016
            • 2905
            • usa
            Can't see your connector pin out. Need to check your voltages on connector to mainboard.
            • nomoresonys
              • 12323
              • U.S.
              recheck your work and make sure that and ALL the other solder joints are good.
