Schematic or datasheet for Plasma TV buffer chip
  • Yanleb
    • May 2017
    • 102
    I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
    So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
    Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer. I don't really care. All I want is to learn something that will help me troubleshoot plasma TVs in general.
    I already know how to pinpoint a shorted buffer chip. Again I'm searching for technical data about buffer chips.
    Thanks.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Schematic or datasheet for Plasma TV buffer chip
    Found this on the web.
    • Yanleb
      • May 2017
      • 102
      Thank you Biruslapio. I've never seen this chip. Usually what I see are Renesas and Panasonic chips. I was not aware that TI was making them also.
      For sure it will help me to learn. Thanks again.
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        ST also has very useful datasheets, I had no luck finding any Panasonic or Renesas.
        https://category.alldatasheet.com/in...ist=150&cate=4
        • lotas
          • Jan 2016
          • 4837
          • Russia
          Panasonic - AN16021
          • Yanleb
            • May 2017
            • 102
            Thank you Biruslapio. The ST datasheets are a real gold mine of information. This is strange I never seen a ST chip in a plasma TV.
            And thank you Iotas. The Panasonic chip pinout will be useful. This is very very stange. The datasheet of the Panasonic AN16021 is an exact copy of the SN755870KPZT that Biruslapio sent.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
              Renesas H8S/2112 R4F2112 R4F2112R - 16-Bit Single-Chip Microcomputer Datasheet
              H8S Family / H8S/2100 Series
              Ordering codes:
              F2112TE25V F2112BG25V F2112LP25V
              The core of each product in the H8S/2112 Group of CISC (complex instruction set computer) microcomputers is an H8S/2000 CPU, which has an internal 16-bit architecture. The H8S/2000
              CPU provides upward-compatibility with the CPUs of other Renesas Technology-original microcomputers: H8/300, H8/300H, and H8S.
              As peripheral functions, each LSI of the group includes a serial communication...
              10-23-2024, 02:33 AM
            • macmino
              Buffer data does not match SPI chip!
              by macmino
              Hi all, after several attempt, I finally got a working CH341 Pro working USB device. Now I'm able to read dump the BIOS
              When I verify the image (800G6_EC_RCunlocked.BIN found on this forum) I receive "Buffer data does not match SPI chip!". I tried different programmer but the message is the same. Anyway, I removed the password but I see at the boot the HP Message:
              "HP Endpoint Security Controller Problem"
              When I hit OK, the boot continues and I'm able to use the computer. Did. the SPI chip not match error caused the error?
              09-08-2024, 09:52 AM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
