Jenn Air Wall Oven Dim LCD
  • asuwish824
    • May 2022
    • 3
    I recently purchased a Jenn Air Wall Oven model number jjs2730ws00. It functions properly except that the lcd display is rather dim. No adjustment in the settings seems to improve or even change the dimming/brightness of the display. My hope is I can repair the current display instead of purchasing a new or used unit to replace. I prefer to fix at the lowest point for the joy of the repair. Also throwing out what would otherwise be a perfectly good part just because perhaps a capacitor or other small part is bad seems obviously wasteful. Any guidance would be appreciated.
    PS It should be stated that a visual inspection of the part has not taken place yet, but should be done by the weekend.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Jenn Air Wall Oven Dim LCD
    My sister has the same problem with her microwave oven. Her's is a Frigidaire. I looked on the internet an found many people have this problem. These people who have repaired them claim that they are bad capacitors from China.
    • redwire
      • Dec 2010
      • 3906
      OP you seem to have a wrong model number, it should be JJW2730 for 30" wall oven. It's like a space ship, lots of electronics.
      A dim fluorescent VFD display on older oven control boards is usually caused by bad capacitors. But this wall oven uses a LCD touch display.
      Not sure what kind of backlight it is using, if LED or CCFL.
      Jenn Air PS11752046 Oven Control Board (is a SMPS power supply) cross ref. to Whirlpool WPW10286791 (AP6018743), W10286791, 1874905, W10176142. seems to be used in a few microwave ovens.
      Jenn Air PS11752182 Mega control board (17 relays!) cross ref. to Whirlpool WPW10292568 (AP6018878), 1552917, W10175823, W10289532.
      Could not find info on the display board, which is where I'd go to first.
      • asuwish824
        • May 2022
        • 3
        I apologize for the model number error.
        Yeah, I'll have to open it up this weekend. Does ccfl stand for compact fluorescent? Can't imagine it being backlit by that but I'm just a noob. I was also thinking it must be the backlighting.
        I'll post some pics in the coming days.
          • Jul 2011
          • 6033
          Use caution when you work around a LCD display to NOT bend twist the glass screen because it is easily cracked if it glued to the face plate it might have a LED for the backlight which probably connects the circuit board with two wires if this is the case and you can get to the wires from the main controller board just remove them and if you have an adjustable power supply start at 1.5 volts and very slowly increase the voltage to the minimum brightness that you require but be careful not to over drive the LEDs because the backlight assembly is not going to have a current limiting resistor you have to know what the voltage that drives the LEDs at minimum brightness that you need to see the display
          Ones you have the voltage that is need for the LEDs post this information and we recommended your opinion
          I research this a little bit and appertaining there some capacitors on the timer console a 68uf@50 volts if I remember correctly and a 470uf I do not remember the voltage I would do this frist
          Here is something that might help you
          https://www.fixya.com/support/t31375...l_not_light_up
          • Fsufan1391
            LG Oven model LREL6325F
            by Fsufan1391
            Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
            04-23-2025, 05:42 AM
          • bpjl
            SEF 551.10 - Error starting the reflow oven.
            by bpjl
            When starting the SEF 551.10 reflow oven, the following problem occurs:
            It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
            PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
            10-17-2024, 06:30 AM
          • goodpsusearch
            Daewoo microwave oven repair
            by goodpsusearch
            One day my microwave oven stopped heating.
            It would turn on and rotate the plate but no heat.
            I removed the cover and checked components with digital multimeter.
            Found that the high voltage fuse was blown.
            This is not the AC fuse, if the AC fuse was blown then the oven would appear totally dead.
            Then I tried to find replacement fuse on local electronic parts stores and this specific value was not available so I got the closest I could find.
            I replaced fuse and tried to heat up a glass of water.
            Strange noise...
            01-24-2021, 03:56 PM
          • KYBOSH
            Trying to Revive - Eufy Security Wired Wall Light Cam S100 - No Power
            by KYBOSH
            This found its way to my workbench this week.
            The buyer thought he got a great deal but it turns out it was likely dead and the seller tried to get anything they could for it by passing it off on an unsuspecting buyer.
            Rather than tossing it in the bin he gave it to me to play with as he knows how much I love to try to solve problems like these.
            The camera portion of this device worked fine when powered via USB but when on the mains it would not work at all.
            This reminded me of the eufy floodlight...
            09-06-2024, 09:09 PM
          • TahoeEd
            GE Wall Oven, Dim display capacitor repair
            by TahoeEd
            My GE Profile dual wall oven display had become dim over time, to the point where you could barely read the display by cupping your hands around it. Some googling suggested bad caps could be the issue, so I decided to recap the control board. The display is now bright and back to normal. Here's the summary of my repair.
            1. Turn off power to the oven.
            2. Remove the control panel. Take LOTS of pictures of the wiring before you start unplugging wires from the control panel.
            3. Measure all the capacitors, put oven back together.
            4. Order caps and wait.
            5. Do the full repair. Reinstall carefull
            12-17-2017, 02:24 PM
