Hi All, I am working on a MacBook Air A1932 (2018) No Display, motherboard 820-01521-A. It is totally clean & no sign of any liquid spill on it, like new. I notice that this notebook is going easily into DFU mode & while trying to restore, it give me the error, please check photos. In the background all seems to be working, CPU gets hot & the trackpad vibrates & the fans moves too. What can be the problem, any help would be greatly appreciated. Thanks
MacBook Air A1932 No Display
Re: MacBook Air A1932 No Display
Error 21 resolution is posted here:
https://logi.wiki/index.php/DFU_Mode...roubleshooting
The T2 rom dump is available here:
https://www.badcaps.net/forum/showthread.php?t=104860
But note that a special socket will be required to host this tiny and flash device.
Even more important...the flash operates at 1v8.
Be sure to confirm if your programmer can support this low voltage and flash part number.Last edited by mon2; 05-21-2022, 07:50 PM. -
Thanks "mon2", really appreciate. I had a feeling it has something to do with the T2 Rom Chip. Thanks for all the information. I saw the programmer unit for these chip, they are costly! Will the ordinanry SPI programmer not work to program these chips if I change the programming voltage to 1.8v???Comment
Which programmer do you own?
My concern is that while the Vcc (power) may be 1v8, the spi interface lines from the bus master (programmer) must also be swinging at the same levels.
To handle this properly, logic level translators must be used or the programmer interface should have its Vio rail operate at 1v8. Then, the flash will see the safe logic levels and can be powered at 1v8.Comment
In a correction to my earlier post - I linked the CD3215/3217 ROM dump. Such rom dumps are used to correct the power delivery firmware used by the ACE controller.
Respectively, if I understand the wiki page correctly, you require the T2 ROM dump for your logic board. No experience with this topic yet but assuming that the best approach is to find a dump from a logic board of the same.
On Tuesday - will check if we have this model which I believe we may at the office.Comment
I am using the Universal Programmer RT809H Serial ISP Programmer & the T2 chipsets W25Q80D & AT25SL321(ISP) description is there in the programmer software. Now I think I just need this socket "A1989 Rom Socket Assistant U2890 Notebook Chip W25Q80DVUXIE Adapter USON 2x3 0.5" available on eBay. Maybe I can give it a try, never know might have a solution in hand.Comment
Hi. Yes, the linked adapter should work for your use.
The schematic shows U2890 as W25Q80DVUXIE. Datasheet is attached.
Upon review of the schematic, the Vcc for this flash device is 3v3 and not 1v8 as originally thought.
It should work as noted.
Comment: We may be indexing the wrong flash device - this the THUNDERBOLT flash which is used to hold the firmware for the ACE controllers (CD3215).
The T2 rom I have read is 1v8 so for that we DO require a level translation IC to convert your 3v3 signals to 1v8 else the flash device can be killed.
Will search some more...
Update: you require a 3x4mm socket like this one:
https://hklrf.com/T2-Rom-EFI-Socket-...pter_4519.html
BUT - big BUT again, there are no logic level translators on this passive PCB. So if your programmer shoots out 3v3 signals - it will kill your flash device !!
You will need to check if your programmer can support 1v8 target flash devices before proceeding.Last edited by mon2; 05-22-2022, 12:17 PM.Comment
mon2 your SURPERB knowhow & knowledge makes me crazy at times... You really put a lot of thinking & reading in all this, you really are an ASSET for Badcaps. Anyway I have read all what you send me & am going to order some W25Q80DV rom chips which is listed on 820-01521-A schematics, infact I will order both, the "MX" series too. Trying would not hurt, & in this way if this works everyone in the forum will know how to do it next. Thanks for all the help., really appreciate you helping me.Last edited by mferna14; 05-22-2022, 07:46 PM.Comment
by sauliniHello guys...
I bought MacBook from a garage sale the owner told me that the MacBook was dead and it did not display nothing, at first I thought it was related to a t2 problem so I did the bride OS with my other MacBook I was able to revive it but it did display the apple logo but on the apple configurator the lock symbol was there upon further inspection the MacBook did make the chime sound every time I disconnected the power cable but still it did not show any display also the caps key was able to light up, with nothing else to do i remove the motherboard and found the following... -
by ledbylightHi all!
This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more
, and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
11-04-2024, 06:36 PM -
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
- Loading...
- No more items.
