lg 42lc55 7 times blinking and after goes out
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    i have the above model lcd tv
    the problem is like the title blinking the green led 7 times after is steady green for 30 seconds i can see picture without backlight used a lens and after i hear something like sound from the speaker i think and the green led goes out with the image of course
    thanks in advance
  • nomoresonys
    • 12306
    • U.S.
    Re: lg 42lc55 7 times blinking and after goes out
    need good straight on pictures of every board and one of the whole back as to see how everything is connected and a clear closeup of the map/legend of the powerboard.
    • Xristakis795
      • Mar 2021
      • 162
      • Greece
      ok sir
      i have take some pictures
      • dskall
        • Oct 2016
        • 2905
        • usa
        Need to test backlights.
        https://www.badcaps.net/forum/showth...er+testing+cfl
        • Xristakis795
          • Mar 2021
          • 162
          • Greece
          thanks for the answer sir
          and i believe maby its backlight problem
          in my case if you notice from the foto i have two plugs go to the ccfl lights
          , but each plug has one wire
          how can i connect external a ccfl light for testing the inverter ?
          one or two lamp must i connect ?
          • Xristakis795
            • Mar 2021
            • 162
            • Greece
            sir
            just to be sure
            i can test it with one lamp ccfl right ?
            • dskall
              • Oct 2016
              • 2905
              • usa
              Looks like 2 circuits. Test one at a time. Appears ground is chassis. Also high voltage.
              • Xristakis795
                • Mar 2021
                • 162
                • Greece
                i understood
                close circuit with ground of chassis
                so you tell me to test only one ccfl with one edge to the plug and the other to chassis of tv
                or can i use two ccfl with common edge the chassis ?
                • Xristakis795
                  • Mar 2021
                  • 162
                  • Greece
                  can i do bypass on the ic backlight so to pass the fault with backlight so i can convert it to led ?
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    https://www.youtube.com/watch?v=q4C_...l=MackoyTechPh
                    • Xristakis795
                      • Mar 2021
                      • 162
                      • Greece
                      thanks one more time for your quick answer
                      in my case the problem is green led blinking 7 times stabilizing for 10 seconds
                      almost in this duration i can see picture without backlight with the help of a lens
                      and after the led goes out and the picture tv goes to protect mode
                      my question is how can avoid this problem and tv doesnt go to protect mode
                      if i fix this i can convert it to led i have done again in other tv
                      is there someone ic responsible for the backlight and to do it bypass ?
                      i have done in a philips tv lcd and work in lg tv is possible in my case ?
                      • Xristakis795
                        • Mar 2021
                        • 162
                        • Greece
                        hi again in my case the responsible inverter ic is oz9965gn
                        i read ho can i do bypass but i cant understand because there isn t schematic
                        (OZ9925GN Protection Remove
                        We solder the LED on the 13th leg. Protection is disabled. The first element with 13 legs is a capacitor. Here we solder it in parallel.)
                        can anybody with more experience to help me ?
                        • lotas
                          • Jan 2016
                          • 4787
                          • Russia
                          parallel capacitor.
                          • Xristakis795
                            • Mar 2021
                            • 162
                            • Greece
                            and what type led must i use ? i mean characterestic volts ?
                            the tv isn led is lcd with ccfl lamps
                            • lotas
                              • Jan 2016
                              • 4787
                              • Russia
                              Regular red LED
                              • Xristakis795
                                • Mar 2021
                                • 162
                                • Greece
                                do you know voltage ?
                                • Xristakis795
                                  • Mar 2021
                                  • 162
                                  • Greece
                                  sir dskall
                                  i found the the schematic of power supply in electrotanya and i have confuse and i wanted from your experience little more help
                                  i thinking to use 2 lamps ccfl T5 for the simulation in the same time and no one each time
                                  my problem is from the plan where i connect the connectors of the lamps
                                  the first lamp the one connector on the plug p401 and the other connector on the capacitor c404 wich connected on the ground with the symbol P or on the trimmer v302 wich connected with the ground
                                  similar the second lamp must i connected between the plug p402 and capacitor c409 or trimmer v302 ?
                                  thanks in advance
                                  • Xristakis795
                                    • Mar 2021
                                    • 162
                                    • Greece
                                    sorry i want to correct something
                                    the problem finally is the tv at the start is standby
                                    when press the power on blinking the green led 7 times after is steady the green led for 10 seconds approximately
                                    you can see with the help of lens display without backlight and after the tv goes in stand by again
                                    it doesnt goes out as i had tell at the start
                                    does anybody of you similar experience ??
                                    • Xristakis795
                                      • Mar 2021
                                      • 162
                                      • Greece
                                      Hi to all
                                      I'm coming back to the above TV because I thought the problem was the backlight, but since I don't have ccfl lamps or a tester, I wanted to make a bypass inverter, the specific TV has the ic oz9925gn, I found it on the internet, since it doesn't have an operating manual, I keep the capacitor on pin 13 which is already connected and in parallel I connect a normal LED 2.5-3.5 volt
                                      I connected it and the LED doesn't light up, is this normal?
                                      Please, has anyone done this ic bypass?
                                      because I made the connections as Mr. Lotas advised me from here but the LED didn't light up and the result is the same when I press the power button the green LED flashes 7 times then it stays solid green for a few seconds i can see image with a torch because the backlight missing and then it goes into standby mode the red light turns on lent
                                      can someone help me with this problem?
                                      • ahmarzo
                                        Hp 15-cs laptop 5 times dc jack blinking white
                                        by ahmarzo
                                        I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
                                        First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
                                        Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
                                        But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
                                        12-28-2024, 04:46 AM
                                      • YasaCh
                                        Sony kdl 40p5500 red light keeps blinking 3 times
                                        by YasaCh
                                        Hello...
                                        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                        i opened the back cover no sign of damage on the powery suply or motherboard
                                        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                        07-07-2025, 11:53 AM
                                      • shahnld
                                        Sony kdl 65xg9505 green amber blinking
                                        by shahnld
                                        Good Day.
                                        I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                        i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                        green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                        01-03-2024, 03:05 PM
                                      • jxrepman
                                        Asus X453MA won't turn on and green led light blinking
                                        by jxrepman
                                        Hi there,
                                        I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                        I have checked the charger and it is giving 19+ V
                                        I have disconnected the battery and pressed power button for 30 seconds.
                                        I tried another RAM stick.
                                        Tried disconnecting the keyboard and touchpad.
                                        Tried disconnecting the HDD and the wifi adapter.
                                        The problem persists.
                                        Hope you could help me out on this one. Thank you.
                                        12-14-2024, 06:40 AM
                                      • NConstantinou
                                        DELL INSPIRON P66F BLINKING AMBER 3 TIMES AND WHITE LIGHT 5 TIMES
                                        by NConstantinou
                                        I REMOVED INTERNAL BATTERIES AND I SUBSTITUTE RAM BUT STILL THE SAME.
                                        WHEN I PLUGIN CHAGER I DO HAVE 3.3,5 AND 1.8 V. AND ON PL700 I GET 0.27V.
                                        BIIOS PINS 7,8 I HAVE 3.3V
                                        IS THE PROBLEM ON MOTHERBOARD OR BIOS.
                                        08-21-2025, 03:23 AM
