What is this component? No markings whatsoever.
  • AllElectronicsRepairs
    • Feb 2020
    • 21
    Hi All,
    Could anybody please recognize this component? It has no markings and there is no designator on the board. It has no continuity, diode test shows also OL both ways.
    • 21665
    Re: What is this component? No markings whatsoever.
    Originally posted by AllElectronicsRepairs
    Hi All,
    Give more info, what PCB is it on,make/model/part number etc .
      • 31214
      interesting, it looks like ceramic
      maybe a spark gap - whats it from?
      • redwire
        • Dec 2010
        • 3912
        The part has no leads, it looks like it fits in a socket? Designed to be replaced.
        I would guess a gas discharge tube or higher power RF TX capacitor.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8331
          Originally posted by redwire
          the part has no leads, it looks like it fits in a socket? Designed to be replaced.
          I would guess a gas discharge tube or higher power rf tx capacitor.
          +1
            • Feb 2020
            • 21
            It's an Earth Bore pointer.
            • redwire
              • Dec 2010
              • 3912
              Ok that would make it a vibration or roller ball tilt switch. It must tell the MCU the tool is up or running.
              Hold it up to your ear and shake it, see if you can hear the ball/roller/spring inside. Or put a DMM on continuity and tilt/shake the sensor see if you get a closed switch reading.
                • 31214
                use a meter,
                if it uses a ball of mercury it wont make any sound
