Help me find the value of this mosfet. Asus FX506L Board code is: DABKXDMB8E0
  • vienzen
    • Feb 2015
    • 112
    • PHILIPPINES
    Help me find the value of this mosfet from a Laptop Asus FX506L
    Board code is: DABKXDMB8E0 REV. E Thank you
    • 21441
    Re: Help me find the value of this mosfet. Asus FX506L Board code is: DABKXDMB8E0
    F1 *** PE600BA
    https://www.badcaps.net/forum/showpo...65&postcount=4
    Datasheet https://www.badcaps.net/forum/showpo...91&postcount=4
    • vienzen
      • Feb 2015
      • 112
      • PHILIPPINES
      thank you
      • Thomas Smith
        Asus Tuf gaming fx506l no power, mosfet does not open
        by Thomas Smith
        Hello everyone, I have an ASUS FX506LI laptop that does not turn on, and I need help diagnosing the issue. Here is what I have checked so far:
        Initial Symptoms:
        • The laptop has no power at all (no LEDs, no fan spin).
        • No 3.3V or 5V present on the board.
        • The power button (NBSWON#) reacts but only changes from 0V to 0.5-0.11V.
        Power Rail Checks:
        1. Charger input (FETs PKCH2BB)
          • Drain: 20V, Source: 0V, Gate: 0V (FETs not switching).
        2. BQ24780S Charger IC:
          • VCC and ACDET are present.
          • ACN / ACP, ACDRV, BATDRV, LODRV, HIDRV, ACOK, SRN, SRP – all 0V.
          • Shunt resistor has 10Ω to ground.
        03-30-2025, 03:38 AM
      • AppleLover123
        Asus X712EA 3 volts after the first mosfet
        by AppleLover123
        Hey guys,
        i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
        I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
        Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
        I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
        Now i thought something...
        12-15-2024, 07:49 AM
      • Scotchmist
        Asus GA502D keeps blowing mosfet
        by Scotchmist
        I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
        I have removed the mosfet and can run the laptop no problem
        The MOSFET is FDPC5018SG
        Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
        08-24-2024, 02:23 PM
      • MicroSMD Lab
        ASUS ROG Zephyrus GPU Mosfet repeat failure
        by MicroSMD Lab
        The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
        I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
        01-10-2024, 06:36 AM
      • Timp74
        Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
        by Timp74
        Hi All,
        Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
        I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
        08-13-2021, 01:11 PM
