TS100 Tips - Recommended Vendor?
  • clearchris
    • Dec 2013
    • 687
    I have a pinecil on the way
    https://www.pine64.org/pinecil/
    but it comes with a conical tip. Going to have to replace that with a chisel tip. Anyone have any good ali vendors for ts100 tips?
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: TS100 Tips - Recommended Vendor?
    I've used tips from aliexpress. About 5€ a piece. Finer tips were 10€/piece I think. They all work great.
    • jm1234
      Soldering tips N9-XXX for ZD-8916
      by jm1234
      I have soldering station ZD-8916 and I only see like 6 different soldering tips being offered, eg. by tme: https://www.tme.eu/ie/en/details/zd-...er-peak/n9-26/
      Very limited variety, I'm missing a chisel ones, it just doesn't exist.
      I thought to myself everything is available in china, but they don't seem to be using the same nomenclature. Searching in aliexpress or temu for N9 tip doesn't find anything.
      Is there perhaps equivalent type to N9 I should be searching for?
      Or is my soldering station that weird and I just shot myself into a foot?...
      12-02-2025, 05:45 AM
    • estabilito
      Tips geting oxidized when using wick
      by estabilito
      Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
      i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
      Temperature: 350-365celsius
      station: jbc cd-2bqe
      Wick: edsyn
      flux: warton hf rework jelly
      Do you have any tips?...
      04-12-2025, 11:55 AM
    • Shredder11
      BoardViewer Files Needed For M-Audio Ozonic Firewire Keyboard Audio Interface + Any Repair Tips
      by Shredder11
      As per title and also any tips on what to test first would be welcome on fixing this keyboard, which worked 100% and then upon the next power on, no display or response from keys, buttons, sliders, dials etc. However the Firewire audio interface section still works.
      Thanks.
      10-14-2025, 01:42 PM
    • corrize
      Quality solder iron tips and Kapton ?
      by corrize
      Hello, I have a solder iron pen (50w) with tips « 900m » (hollows ones, standard). I'm searching to replace mines because it's impossible to tin, they remain black and impossible to unsolder a mini SMD capacitor with. Bad ones.
      I'm looking to replace the iron tips but, on Amazon, Ebay… all no names, the sames. Sold by 10, 15 or more at low price and « pro » websites only one Hakko tips sold 20 dollars. I'm lost.
      Do you have brand of qually tips pls ?
      Same question for Kapton (for my other hot air iron), do you have brand or good place to buy, the true...
      05-24-2021, 11:35 PM
    • aurgathor
      Recommended replacement cap & voltage
      by aurgathor
      I have an older SFF Dell (GX620) that I want to turn into a router, but it has a few *really bad* looking electrolytic caps (4x 2200uF 6.3V & 1x 1800uF 6.3V) that need to be replaced first.
      Questions:
      1. What are some the recommended caps for these values? (I will probably order from digikey)
      2. Looks to me there is enough space for slightly bigger caps -- would I gain anything with respect to longevity by using 10V caps instead of 6.3V caps? (I guess I probably need to look at the current voltage with a scope since I do not know the nominal voltage of that r...
      08-25-2024, 05:14 PM
