Seiki SE42UMT, Standby Light, No power On
  • TheDuDe06
    • Aug 2020
    • 4
    Hi, I have a Seiki SE42UMT that don't power on anymore.
    The standby red LED will stay lit but nothing else.
    I can hear a constant high pitched sound from the power supply board.
    I already have replaced the power supply but the problem still persist so, we can rule out that the power supply board is good.
    I also inspected visually every boards and I can't see anything that could have burnt or blown capacitors.
    Here are attached few pictures of the 3 boards.
    Thank you !
  • TheDuDe06
    • Aug 2020
    • 4
    Re: Seiki SE42UMT, Standby Light, No power On
    Nobody have a hint where I need to look ?
    If I need to give more infos or more tests let me know !
    Thanks !
    • neilc6
      • Nov 2015
      • 1550
      If you have standby light and standby voltage and the TV doesn't turn on, the main board is suspect. Could be eeprom but don't see it in your pics. If you can find the eeprom, you can try freezing it within upside down can of duster before plugging in.
      Squealing can be caused by shorted caps on the main board. See if it stops when you unplug it and measure for shorts on the supply rails on the main.
      • dskall
        • Oct 2016
        • 2905
        • usa
        I would start unplugging things on the power board until high pitch sound stops and then narrow down which board is loading power supply.
        • TheDuDe06
          • Aug 2020
          • 4
          Thanks guys now I have something to work on. I'll let you know my results.
          • nomoresonys
            • 12283
            • U.S.
            looks like the caps are not holding up, if I wanted to do the least, I would replace the what is it 4 1000 uf 25 volt caps, with 1000 uf 50 volt and see what happens, I suspect they were using cheap caps. hold up on the (I just got a new board) ALL the boards will be old, might not solve the problem but it's the simple place I would start at.
            • nomoresonys
              • 12283
              • U.S.
              and check all the solder joints, they are prolly old too.
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
              • shovenose
                Christmas Light Power Supply Question
                by shovenose
                I have a cheap rainbow christmas light set off Amazon which has this little power supply that has a button to change modes. I had a white set with the same power supply that I returned but I can't find any other rainbow themed ones that don't use this setup.
                Anyway, the problem is every time you unplug them and then plug them in it reverts back to "Combination" mode which cycles through all these annoying tacky effects instead of going back to what you had selected or at least defaulting to "Steady on" which is what I want. So I'm thinking I can just...
                12-08-2023, 09:59 AM
