Identifying capacitor type (Laserdisc PSU)
  • LeBeauLuc
    • May 2021
    • 5
    I am trying to figure out what type of capacitors those could be, the picture attached is coming from a laserdisc power supply from the late 90's. I have accessed to the service manual and it is lacking the info for the 20 capacitors and doesn't specify the type either. Looking at the value, those seems to match ceramic type, are those ceramic?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: Identifying capacitor type (Laserdisc PSU)
    caps that look like that are usually polystyrene. If there are that many of them, they probably chose cheapest and other plastic caps will work just fine...
    ...though they usually don't fail...
    • LeBeauLuc
      • May 2021
      • 5
      Thank you very much for the info, eccerr0r.
      Also, I wanted to know if it is normal that the one I circled red to look that dark compare to the one circled green, I am thinking that it might be toasted.
      • redwire
        • Dec 2010
        • 3912
        To me they look like polyester mylar film capacitors similar to Nichicon QXY. I would replace with Panasonic ECQB (although obsolete) or anything with the same lead spacing and ratings. Polystyrene is always tubular shaped and they don't look like that to me.
        They should be yellow coloured, so the darker brown/red parts have been affected (cooked) by the nearby power resistors' heat. I would replace them.
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          The brownish cap is between a heatsink and a power transformer, both sources of heat, and possibly impeding airflow or convection, and as redwire noted, there are two 1 watt resistors near the cap.
          FWIW, the first picture has what I think is a Shindengen logo in the PCB silkscreen. Power supplies tend to have mostly polyester film capacitors, with some polypropylene parts in important places.
          PeteS in CA
          • LeBeauLuc
            • May 2021
            • 5
            Thanks all for that valuable info, looking on the interwebs, they do appear to be polyester film capacitors, knowing that I will be able to replace the burned ones.
            • chth96
              Is it possible to test small ceramic disc capacitor with analogue meter?
              by chth96
              I read EBOOK of Testing Electronic Component and found that
              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
              Is it really possible to test small ceramic disc capacitor with analogue...
              03-09-2024, 10:03 PM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
              Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
              This specification for the Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51T-50DY+ USB Type-C Dock boardview and X514-51T-50DY+ USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
              09-06-2024, 09:10 PM
              Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
              This specification for the Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-54PC+USB Type-C Dock boardview and X514-51-54PC+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
              This specification for the Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-59AD+USB Type-C Dock boardview and X514-51-59AD+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
