resistors in parallel ?
  • littlejohn
    • Mar 2022
    • 26
    I need a 1.5 k 2watt resistor , can I use 2 1 watt resistors in parallel for testing purposes while waiting for a 2 watt to arrive?
    • Jul 2011
    • 6070
    Re: resistors in parallel ?
    You can use two 3k ohm resistor @ 1 watt in parallel to get 1.5k @ 2 watt that you are looking for
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      And two 750Ω 1W resistors in series would also result in a 1.5KΩ 2W resistance.
        • Jul 2011
        • 6070
        Are you sure about this because I thought that if one was 1 watt total because it would just add more resistance but I could be wrong
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8716
          Do the math.
          BTW, should always do the math. You can even do funny things with nonmatching resistors but yeah it gets complicated when they don't match as the power dissipated will be different if resistances are different.
          • redwire
            • Dec 2010
            • 3912
            The heat to be dissipated would be shared over two parts, each one dissipates a ratio of the value a single part would. Regardless of whether the two are in series or parallel.
            50-50 split so 1W each using two 750Ω series or 3kΩ parts parallel.
            If you used a 2.2kΩ and 4.7kΩ in parallel, each see about 1.36W and 0.64W - the same ratio as their resistances.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8716
              Then you'll need a 1.5W 2k2 resistor which rounds up to 2W, and why not buy a 3k 2W resistor to begin with
              With dissimilar resistors, probably only for last resort or if you have other values to burn... I was trying to do this with a 10R 2W and a 40R 10W in series for a 50R load, now need to calculate the system max sustained wattage... Then realize that inductance in the pair was too high for VHF frequencies...
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                Do the math.
                Here's the math if anyone is interested or ever will be interested ...
                What I find particularly interesting about this thought exercise, is that like sam, my knee-jerk reaction to the statement was to pause and question it. And I think that is because we are used to thinking about net values - where resistors are concerned anyways - differently depending on whether the resistors are in series or parallel ... so I think naturally the brain wants to continue that pattern of thought even if the value in question is wattage dissipation. Which as it turns out, does not care if the resistors are in series or parallel, wattage dissipation adds up linearly.
                sigpic
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8716
                  I think the main reason to answer the way sam did is he was thinking about batteries and considering amps and not watts.
                  two 12V 1Ah batteries in series will give you 24V but still only 1Ah.
                  Now the rhetorical question: if you change the question to two 12V 1Wh batteries in series, how many watt hours do you get out of the system?
                    • Jul 2011
                    • 6070
                    This is what I was thinking about but after I saw the math that EasyGoing did it cleared up the confusion about this thanks to both of you
                      • Jul 2011
                      • 6070
                      I will run this test and give you a definite answer to this question over the weekend by doing an actual test I think I know the answer to this question but I want to know for sure that I am right because I have a way to do this test
                      • redwire
                        • Dec 2010
                        • 3912
                        It's the difference between power and energy. Resistors are only concerned with power they dissipate, regardless of the time, how long they've been doing it.
                        Batteries are limited - if each battery has X watt-hours of energy, then two batteries gives you... well 2X. The energy available just adds up.
                        • petehall347
                          • Jan 2015
                          • 4452
                          • United Kingdom
                          only if in parallel . otherwise its the same as the lowest value .
                          resistors in series are the wattage of the lowest wattage one .
                          example .. 2 watts and 1 watts in series = 1 watt .
                          • redwire
                            • Dec 2010
                            • 3912
                            In parallel you get double the Ah, in series you get double the voltage. So two batteries will always give the energy of... well... two batteries. Not one.
                            Where is the confusion on this I wonder.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8716
                              in this case power and energy don't really matter, just take a fixed amount of time and the math works out.
                              This confusion is because some people equate amps (or amp hours) with, or as a proxy for watts (or watt hours), and then extrapolate to resistors, leading to improper conclusions.
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                I can't help but notice that this is similar to capacitors ... parallel ADDS values and series become some ratio of the total ... though this makes sense since a battery is just a pre-charged capacitor I suppose ... mathematically speaking ... or at least in some loose way they are.
                                sigpic
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  I struggle with these MAh ratings on these batteries ... so for example, a battery is rated at being capable of sustaining 3,000 MAh ... which says to me that it can continuously provide 3 amps for an hour ... but that never seems to be the observed reality ... in any specific case from what I remember back when I was trying to make sense of all that stuff.
                                  I wanted to make an arduino based LiIon charger at one point and I specifically remember struggling with the actual HOW in calculating how many MAh were going into the battery as it charged.
                                  sigpic
                                  • brownharris561
                                    • Sep 2022
                                    • 5
                                    Nice Explained!
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8716
                                      Not sure why or perhaps I forgot to, but to make it crystal clear, these conclusions are using the watt and amp confusion alluded to earlier, leading to unexpected and improper solutions.
                                      While as rule of thumb using "lowest wattage" = "system wattage" works to be safe, it's more nuanced and potentially significantly pessimistic. You have to calculate dissipation individually to know system dissipation. For that example of the 50 ohm dummy load that I created with those 40 ohm 10W and 10 ohm 2W resistors. What is the system power limit? In this case it would actually be 10 watts if my math is right.
                                      Now for batteries this is a problem because we have to deal with dead batteries. Dead batteries cause problems when in series, so yes, if you have a 120Wh battery in series with a 12Wh battery, you end up with some unknown watt hour system capacity that can't be computed without also knowing each battery's voltage and their characteristics, acceptable or not, when dead. If the battery voltages were both 12V then system power capability would be at least 24Wh; more if you can deal with consequences.
                                      So yes there is a kind of geometric mean when dealing with series devices. Calculating it requires some care as well as understanding the consequences of such. This also includes the series capacitor issue.
                                      Most of the times the mAh ratings are due to "marketing exaggeration" if not for internal resistance issues. What you found is what you found (and correct for your situation), and the number printed is simply ... wrong.
                                      • chth96
                                        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                        by chth96
                                        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                        Since then, This AC/DC adaptor have been out of order.
                                        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                        And Is there any possibility that it will suddenly explode as well as to be out...
                                        12-03-2023, 04:40 AM
                                        KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                        by momaka
                                        For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                        http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                        I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                        What mostly drew me into buying it is its 2x PCI-E power connectors...
                                        03-29-2022, 11:34 PM
                                      • youpla
                                        PowerColor rx 5700xt dual fan : current sense resistor
                                        by youpla
                                        Hi everyone,
                                        I’m repairing a PowerColor RX 5700 XT Dual Fan (not the Red Devil or Red Dragon model) with a burnt pin 5 on its 6-pin PCIe connector.
                                        The previous owner had it repaired by a shop. They soldered an enameled wire to reconnect pin 5 to the current sense resistor (shunt).
                                        The card wasn’t displaying anything after this fix.
                                        When I inspected their work, I found that the sense resistor had fallen off after reheating the solder joint (likely due to damaged pads from resistor).
                                        I tried to resolder it with a hot air station, but the resistor wouldn’t...
                                        12-01-2025, 07:52 AM
                                      • Crystaleyes
                                        Calculating resistor values in parallel with Caps
                                        by Crystaleyes
                                        Hi all.
                                        I recently picked up a dead car amplifier from the flea market, with the intention of learning some more in the area of audio repair.
                                        It has a stereo output with an added mono woofer output. The stereo channels are on one board, whilst the woofer section is on a separate board. There are also three large (ish) transformers.
                                        Apart from the fact that it was seriously dirty inside, it seems to be essentially complete with the only clearly damaged component being a toasted 1/4 watt resistor on the woofer board and it is this which I am wondering...
                                        05-21-2023, 07:35 PM
                                      • mikey5791
                                        Need help to replace burned resistor in 350w atx psu
                                        by mikey5791
                                        Hi to all forum members,
                                        Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                        The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                        Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                        Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                        12-26-2024, 04:55 AM
