BAUN - UVST - 0617,Can anybody Identify these Please?
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Hi there
    Is anybody able to Identify these 2 Components Please?
    I am Looking for Tech info alsp Please as its for a BAUHN Portable Record Deck
    Model Number - BAUN - UVST - 0617
    I have another IC on the Unit, that is Suspect, but the Markings have been Scraped off, or wernt on it to start with
  • Ritchie_Uk
    Prawnography
    • Mar 2021
    • 185
    • Uk
    Re: BAUN - UVST - 0617,Can anybody Identify these Please?
    No Replies?
    • R_J
      • Jun 2012
      • 9608
      The diode is easy, Schottky diode 40v 1 amp.
      Can you clean off the ic with something like alcohol so the logo shows up better?
      • Ritchie_Uk
        Prawnography
        • Mar 2021
        • 185
        • Uk
        Hi R_J
        The IC has had the markings taken off, and when I spoke to the manufacturer, they said, " We dont give repair info"
        Do you have any idea what the Component is with the number 54, or how I can ID it please?
        • Ritchie_Uk
          Prawnography
          • Mar 2021
          • 185
          • Uk
          Any Idea what the Manufacturer Logo is on the MOSFET looking Component?
          • R_J
            • Jun 2012
            • 9608
            The board marking suggests it is a ic not a mosfet, What is wrong with it? how can you know the part is bad if you don't know what it is.
            Can you provide a couple pictures of the complete board, both sides?
            • Ritchie_Uk
              Prawnography
              • Mar 2021
              • 185
              • Uk
              Hi R_J
              The 2nd component has shorted, and started to melt
              The IC with many legs possibly is Ok
              • Ritchie_Uk
                Prawnography
                • Mar 2021
                • 185
                • Uk
                The Board isnt shorted now, that I have removed the 5 legged Chip.
                I cant seem to ID the Manufacturer, and it seems to say HK 54 on it
                • R_J
                  • Jun 2012
                  • 9608
                  But where is it in the circuit? Is it part of the power supply circuit, this might help to identify it.
                  • Ritchie_Uk
                    Prawnography
                    • Mar 2021
                    • 185
                    • Uk
                    Hi R_J
                    There are only 2 boards
                    The Simple board, is basically just an input, where the Power comes in from the Power adapter.
                    We can ignore this, as it's just a wire connecting it to the main board
                    The Populated board as you can see, has quite a few components on.
                    I have removed the shorted components, which was dragging the whole unit down.
                    The Left silver knob is the Power switch
                    The right is the Tone
                    The unit has an internal battery, that is dead, but I charged it manually, and the whole unit works
                    So it's not charging due to that component
                    That is all I seem to know
                    I hope this helps?
                    • R_J
                      • Jun 2012
                      • 9608
                      Then is likely has to do with charging the battery, trace out the circuit as I can't tell where the traces connect to based on the picture.
                      There are lithium battery charge ic's like the Tp4054, this may be similar made by some odd manufacture
                      The TP4054 might be close, check the datasheet and see if the pins line up. It looks close from what I can see.
                      • Ritchie_Uk
                        Prawnography
                        • Mar 2021
                        • 185
                        • Uk
                        Thankyou
                        I have emailed a couple of component suppliers, to see if they can sell me equivalents.
                        I will keep you updated.
                          • 31255
                          logo looks close
                          http://www.microne.com.cn/
                          • Ritchie_Uk
                            Prawnography
                            • Mar 2021
                            • 185
                            • Uk
                            His TJ
                            Great detective work.
                            What do you think the component is?
                            • petehall347
                              • Jan 2015
                              • 4440
                              • United Kingdom
                              what is the black socket on the right for ? u1 looks like it may connect to it
                                • 31255
                                is it related to a lithium battery?
                                ME4054?
                                http://www.microne.com.cn/ProductDetail.aspx?id=100
                                • Ritchie_Uk
                                  Prawnography
                                  • Mar 2021
                                  • 185
                                  • Uk
                                  Hi Folks - Just got back
                                  Thanks for your responses
                                  The component companies haven’t got a clue what it could be
                                  This is the product
                                  https://www.whathifi.com/news/aldi-r...able-just-ps30
                                  • Ritchie_Uk
                                    Prawnography
                                    • Mar 2021
                                    • 185
                                    • Uk
                                    Here
                                    • R_J
                                      • Jun 2012
                                      • 9608
                                      Here is a photo of the MicrOne version, the logo and markings are different, but I suspect the operation will be the same.
                                      I asked if you traced out the pins to see if this is the same ic, For example, pin 3 seems to connect to CON3, is this where the battery connects???
                                      • noppa
                                        • 41
                                        from here
                                        https://www.s-manuals.com/smd/54
                                        found this
                                        https://cdn.badcaps-static.com/pdfs/...27c931373b.pdf
                                        • thesame
                                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                          by thesame
                                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                          02-27-2024, 04:31 AM
                                        • silver60618
                                          Lenovo Legion 7 - Help Identify IC
                                          by silver60618
                                          Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                                          I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                                          Any help would be appreciated...
                                          07-02-2025, 12:16 PM
                                        • chth96
                                          How can I identify varistor which have been blew up?
                                          by chth96
                                          I mistakely pluged 100v japanese retro game console to 220v outlet.
                                          So It seems that glass fuse and varistor have been blew up.
                                          I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                                          Is there any way to identify varistor type in my sega saturn PSU?
                                          Any reply would be appreciated.
                                          EDIT:
                                          It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                                          11-26-2023, 08:52 AM
                                        • freakorio
                                          Need Help To Identify Component on Ymain LJ41-05120A
                                          by freakorio
                                          Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
                                          05-21-2024, 02:32 AM
                                        • baiceanu_stefan
                                          nm-f251 Schematic, boardview or help identify componente
                                          by baiceanu_stefan
                                          Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
                                          04-24-2024, 12:49 AM
