Synology DS218Play
  • osman68i
    • May 2015
    • 351
    • The Netherlands
    Synology DS218Play
    Hi ,
    is it possible to change the serial and mac adres of this unit?
    i can find the serial, i change a few numbers,
    synology assistant recognize the unit but serial is empty.
    when I rollback the original serial assistant recognizing the unit and the serial.
    • 31254
    Re: Synology DS218Play
    the MAC may be in a 93' series eeprom next to the ethernet controller
    • SluggerB
      • Aug 2020
      • 747
      • US
      Originally posted by osman68i
      Hi ,
      I had a Synology router, and you need to use the Assistant software to view/change anything, AND the correct version of that software for the unit you have.
      I had to email Synology support the S/N of my unit (which I got off the sticker) and they sent me a link to the correct download.
      • chipmaster86
        • Dec 2013
        • 7
        MAC and Serial are located on the daughter board. That little tiny board with the standoffs on it. Copy the checksum too, or it won't boot.
        • chipmaster86
          • Dec 2013
          • 7
          OOps. Almost forgot. As its been awhile since I had a play in shop. If yours doesn't have the daughter board, then its in the bios. Just extract the bios, and search for term "SN=". Mac address too is right next to it. Also copy the CHKSM over as well. Should be like 3 digits.
          • bruce35
            HP 600 G3 MT serial number change please
            by bruce35
            HP 600 G3 MT
            SERIAL NUMBER MXL8301K1C Serial number in the file in bios
            SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
            Thank you very much...
            09-24-2025, 02:32 AM
          • ngml
            Repair of an LG split AC system indoor unit PCB
            by ngml
            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
            This indicates an error in the communication between the outdoor and the indoor unit.
            The outdoor unit is fine, so the problem is the indoor PCB.
            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
            Does anybody have the schematics of this board,...
            02-01-2025, 12:55 PM
          • Dannyx
            UART (serial ?) splitter ?
            by Dannyx
            Good day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
            The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
            The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter...
            08-18-2023, 03:21 PM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • DrDos
            Unit runs but no speaker output kenwood KR-6030
            by DrDos
            I have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...
            09-14-2025, 09:57 PM
