For the benefit of those who need it ms-16k21 rev 2.1 .BIN
  • mohammed mohan
    • Nov 2017
    • 200
    • z
    Mohammed Mohan
  • mohammed mohan
    For the benefit of those who need it Apple MacBook Pro A1278 2012
    by mohammed mohan
    Apple MacBook Pro A1278 2012...
    06-25-2022, 05:55 AM
  • harp
    how to organise your scrap pcb?
    by harp
    I just love any pcb populated with components, there is no help. I dont know if there is all be usefull, but I collect em all... In some point, realize that, if I cant find fast some components what I need, it is no efficient to store pcb in this way. Whatching others who desoldering few usefull components, and all other throw away, is no sense to me, because, many time I found that just specific components I need and will be happy when I have it. I try to desolder almost all common component and place it in small bins, but too many components do mess and bin not practical anymore, and many time...
    09-13-2025, 07:17 AM
    ISL84521IBZ ISL84521IVZ ISL84522IBZ ISL84522IVZ ISL84523IBZ ISL84524IUZ-T ISL84523IVZ ISL84524IUZ-T Datasheet
    Low-Voltage, Single and Dual Supply, Quad SPST, Analog Switches
    The Intersil ISL84521, ISL84523, ISL84523 devices are
    CMOS, precision, quad analog switches designed to operate
    from a single +2V to +12V supply or from a +2V to +6V supply.
    Targeted applications include battery powered equipment that
    benefit from the devices' low power consumption (<1uW), low
    leakage currents (1nA max), and fast switching speeds
    (tON = 45ns,...
    11-05-2024, 03:35 PM
    Surface Mount Fuses Fundamentals Datasheet
    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
    10-07-2024, 06:07 AM
    Multifix 425-01 and 450-01 Rework Flux Datasheet
    REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
    - No Clean Formulations
    - Low residue
    - Range of activity to deal with different component solderability
    - Halide free
    - Suitable for dispensing
    - Compatible with solder coatings and/or No Clean flux cored solder wire product range
    Both products are supplied in syringes or cartridges for application by dispensing....
    10-07-2024, 06:02 AM
