Reading input and output of bridge rectifier on the same scope?
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
    When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier literally caught on fire.
    Why did it do this? And is there any way to achieve what I want to see on my scope?
    sigpic
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Reading input and output of bridge rectifier on the same scope?
    In short the reason is that the ground clip is connected to earth ground, and all of the channels of the scope share the same earth so you shorted primary to secondary...
    To measure this safely you can use two probes instead of hooking up the ground clip: you will of course need twice as many channels to make measurements (i.e. 4x channels to take two readings).
    Please watch this video: EEVblog #279 - How NOT To Blow Up Your Oscilloscope!.
      • 31281
      just as well the ground clips are sold in packs of 10 on aliexpress!
      • redwire
        • Dec 2010
        • 3912
        Fixed: just as well oscilloscopes are sold in packs of 10 on aliexpress!
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          That guy pissed me off once ... he did a video where he fried his Weller iron because he plugged it into 220 when it was rated for only 110... and in the beginning of the video, he fully admits that it was his mistake and he took full responsibility for the damage ... then as the video went on, he started bad mouthing Weller for not building in protection to the unit to avoid damage like that ... which I felt was very unprofessional.
          None-the-less, in the video you linked, his recommendation for taking readings from earth grounded equipment - was to purchase a $350+ device that isolates your scope channel so that it cant be damaged.
          What I essentially did was this here ...
          Which caught the wire between my scope clip and the rectifier on fire ... by shorting points A and B through the scope ...
          I'm lucky I didn't damage the scope.
          sigpic
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            So basically, what I ended up doing by connecting the scope the way I did, was making this circuit...
            Which means that for half of the AC cycle, I created a dead short?
            sigpic
              • 31281
              remind me again, you have 2 channels or 4 on your scope?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Yes, to get around that instead of using an isolation probe (the proper tool for the job) you can utilize two oscilloscope probes as I alluded to in my post above.
                What you do is simply hook one to positive, and the other to negative.
                Then you use the math function of the scope to subtract one from the other.
                This is also a trick you can use to look at really sensitive signals.
                But it is not without its caveats, namely that the waveform could be a bit off depending on how complex the harmonics are.
                P.S: I'm completely with Dave on how stupid it is to not have a fuse on a transformer.
                All my Weller soldering stations do, removing it is just asking for a product recall after a house fire claim from an insurance company!
                  • 31281
                  did it even have a thermal fuse in the transformer?
                  i cant remember.
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    i cant remember.
                    Not even that!
                    • redwire
                      • Dec 2010
                      • 3912
                      OP it's always good to have a fuse/1A circuit breaker because transformers can put out much more current into a short circuit.
                      Check the scope's internal ground did not melt open, I have seen that. The common BNC ground between channels can melt open because they aren't designed for many amps of current. And the internal connection to PE ground, should be OK but I did see a guy ground his scope to an old TV chassis and blow it. Just check continuity.
                      When breadboarding a bridge rectifier, it does need a little load like 10k ohm to swamp out the diode leakage currents. With no load the diode's waveforms can look weird due to their leakage currents and the scope at 1MEG input is little current. It also helps to Line trigger the scope, as the source.
                      Weller did screw up , and their safety agency too - in having no primary fuse. Funny is the double fusing on the secondary they have to thwart the standard. No, that won't stop any smoke. But who wouldn't check the label for 120/240V before plugging it in?
                      I just took apart my old Weller station and added a big red LED for power on and it has a mains fuse.
                      Class II "energy limited" power transformers, used in HVAC (furnaces, zone valves) and doorbells do have an internal 105°C thermal fuse that also pops due to high current. Then toss'em in the garbage though.
                      One old apartment building, a staple had shorted the 24VAC zone valve wiring but 15A fuse and so the wiring/building caught on fire! I made a replacement panel with circuit breakers for that. Scary.
                        • 31281
                        the BNC's on chinese scopes are mounted through tin shielding - your not burning that out!
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8706
                          LOL yes, same as Tek scopes or whatever, all probe shields are connected together through the chassis and most likely the places that will fail given typical scope probes:
                          a) most likely as OP experienced: DUT dies
                          b) probe clips melt down
                          c) BNC connector explode
                          d) probe wires fry... this is very tough as the short path is through the braid which is quite low resistance...
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            It's a 4 channel ... Siglent 1104X-E
                            sigpic
                            • EasyGoing1
                              Shock Therapist
                              • Sep 2016
                              • 977
                              The interesting thing is, that the probe wire (talking about the ground lead that's clipped onto the probe) wasn't even warm. The wire that it was clipped onto was just a thin breadboard jumper wire ... about maybe 30mm long. and it caught on fire right next to me ... when it did that I realized that there was nothing I could do about the problem cause it had already done whatever it was gonna do faster than I could blink.
                              Are you saying I should take the scope apart and check these wires?
                              Lets see ... an American Power Conversion Server class UPS unit transformer ... (about 5 lbs of transformer) ... kicking out 40 V AC rectified down to 20 volts with a 10k resistor across the output of the rectifier? And do this BEFORE looking at the signal?
                              I'll take issue with this ... I do believe that iron that he fried was an iron that is only sold in the US ... which means the likelihood that it would ever be plugged into anything larger than 110V ... is slim to none ... since the plugs aren't even compatible. That was NOT a Weller design flaw ... that was dumb-ass not paying attention and then trying to not look stupid by bad mouthing Weller - unacceptable for a professional in my opinion.
                              sigpic
                                • 31281
                                the scope groundclip was probably decent copper - your jumper may have been copper coated aluminium or steel.
                                that said, pull the rubber boot back on the groundclip and inspect where the wire joins the clip.
                                some chinese ones (owon comes to mind) are not well crimped - they should be soldered.
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  Honestly, the only reason I want to show the AC signal and the UNFILTERED rectified signal on the same screen is that I have a friend who is basically a metal forger, who is very intelligent but doesn't really have any electronics knowledge. And I was trying to explain to him how we convert AC to DC and how CAPs and other components can clean up the rectified signal, and I thought a nice visual would help him comprehend it a little more.
                                  Precision measuring in this case is by no means a requirement ... I just wanna see input and output on the same screen.
                                  I just wanted frickin laser beams on sharks ... is that too much to ask?
                                  sigpic
                                    • 31281
                                    weller (and hakko, etc.) should just make world models
                                    removeable cables and multi-tapped transformers with a selector-switch.
                                    (and a fucking fuse!)
                                    if the japanese hifi companies could do it in the 70's then why cant everybody else?
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      My cheap $125 Weller station has a fuse ... I haven't opened my newer one ... and I won't ... just to see if it has a fuse...
                                      Also, here are both ground clips with boots off ... and the cable / would-be fuse/oscilloscope guardian angel ...
                                      sigpic
                                      • bauto601
                                        KDM 480W PSU upgrade succes! (opinions?)
                                        by bauto601
                                        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                        A "nice" YoungYear unit? - Badcaps
                                        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                        12-26-2023, 03:05 PM
                                      • Steph.hen
                                        Bridge rectifier identification part number KPB305G
                                        by Steph.hen
                                        Hi all, a newby question about a bridge rectifier I'm trying to identify.
                                        I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                                        08-29-2024, 09:52 AM
                                      • FrancescoV
                                        Onkyo HT-R390 no sound output, video output ok
                                        by FrancescoV
                                        Good morning everyone,
                                        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                        The firmware reported is the following:
                                        M:1.00/11107BLP
                                        D:?.??/????????
                                        O:1.00/11107AL
                                        The DSP firmware given the question marks seems corrupt.
                                        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                        05-11-2025, 02:59 AM
                                        Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                                        by momaka
                                        This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                                        Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                                        Macron Power Technology Co. LTD.
                                        Let’s look at the PSU itself.
                                        The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                                        06-02-2021, 10:05 PM
                                        KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                        by momaka
                                        For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                        http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                        I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                        What mostly drew me into buying it is its 2x PCI-E power connectors...
                                        03-29-2022, 11:34 PM
