Grr... stupid DPAKs.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Guess what I'm trying to do with them.
    Tried a 100W gun... no dice in getting it to budge
    45W pencil with a big flat tip... no dice
    I'm not sure if I want to salvage this transistor or not at this point as I'm not sure if it's the culprit or not... hot air would do any better?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: #@&*%!dpak
    Get yourself a better iron like the Axium T3A, if that won't remove it you're doing something wrong.
    Are you adding leaded solder? Why not try it with the hot air?
    • petehall347
      • Jan 2015
      • 4440
      • United Kingdom
      Re: Grr... stupid DPAKs.
      hot air and 60/40 should shift it
        • 31214
        before i had hot air,
        desolder and slightly lift each leg
        put a bit of solder on the end of the iron and hold it on the tab.
        eventually the component will slide down and you can extract it
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          holy crap. 200W pencil iron... LOL.
          Yes, added leaded solder...hmm.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Blah, and of course the source pin has a huge pad with PTVs and a through hole capacitor right next to it... Incidentally that capacitor is a solid polymer electrolytic.
            • petehall347
              • Jan 2015
              • 4440
              • United Kingdom
              preheating the board helps
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                hmm... Tried to use my hot air gun on another (scrap) board with a dpak, came right off with no fuss.
                I don't think I'll see the same on the motherboard I want to take the mosfet off of (without damaging either -- worried about frying the other components that are right next to it!).
                BTW I wonder if I could sub a TO220 in for a dpak and not solder to the board... if the larger package is sufficient for not having board heat spreading...
                • harp
                  • Jun 2022
                  • 631
                  • Planet Earth
                  You can desolder dpak with soldering iron, just slightly lift up legs and put some baking paper behind.
                  https://m.youtube.com/watch?v=Khs6txY6iW4
                  • leotron
                    [No stupid question] Can I build an atx psu from scratch?
                    by leotron
                    I have some good spare parts of electronics and deads PSUs from good brands,it is possible to buiild from scratch a psu ? I know it's sound stupid but I take a shot just for fun. Guessing with my little electronic expertise it could work only if you maintain certacin consumption, let's see a small mining rig that consume exactly 500w and no more no less, the problems start when that consumption starts waving around. Another thing I notice it's that the more powerful the psu is it's contains more "referees" to mantain the match in order if you understand wtf i'm saying.
                    02-22-2022, 04:04 AM
                  • spleenharvester
                    Making a Handskit hot air station a bit less stupid
                    by spleenharvester
                    I bought one of these as it was the only one I could find that is compact enough to fit in my toolbox (though I've since found KSGER make a substantially safer looking one). It's one of those fan-in-handle things that has the 230V element in the handle. Quecoo briefly sold a similar unit but discontinued it.. maybe they couldn't find solutions to these problems. I'm aware these fan-in-handle things are garbage compared to a good air pump station but I only really use this for occasional QFN work etc.
                    I did not realise at the time of buying that its design is... interesting, to say...
                    05-09-2024, 09:09 AM
                  • sircastor
                    Solder not reflowing - what am I doing wrong?
                    by sircastor
                    I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                    For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                    03-03-2024, 02:44 AM
                  • Th3_uN1Qu3
                    Cooling upgrade on refrigerator. If it works, it ain't stupid!
                    by Th3_uN1Qu3
                    I had this refrigerator at my old folks which I noticed I would put my beer or soda in and take it out warmer than I'd brought it from the store.
                    Now, I don't know much about refrigerators or HVAC but to me it seemed like we have a problem. I threw a thermometer in... 20 deg C in the fridge. WHAT THE... Freezer worked fine with temperatures way below zero, as it should, and it has only one compressor for both sides so it got me scratching my head for a while.
                    Only other things that seemed a bit odd was that the heatsink on the back was barely warm and the...
                    09-03-2023, 06:29 AM
                  • DXseekerMO
                    Lg 49uf6400...leave it to lg to put in some stupid backlight connector
                    by DXseekerMO
                    LG 49UF6400....LEAVE IT TO LG TO PUT SOME STUPID BACKLIGHT CONNECTOR on the LED strips that TAKES A MENSA CERTIFIED GENIUS to figure out how to detach.
                    Can anyone tell me how these connectors detach from the LED strips?
                    Thanks for your help folks!...
                    09-29-2021, 01:23 PM
