Lenovo Thinkpad W540 no power
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    please help where the problem is or if anyone has experienced please share. On the thinkpad W540, the voltage on the VINT20 drops gradually & slowly. If R380 is removed, at point DOCK_PWR20 appears voltage 20V. inject voltage on VINT20, nothing short. has been replaced mosfet Q9 and Q36, replace the processor, flash bios. but no change.
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    Re: Lenovo Thinkpad W540 no power
    any suggestion?
    • mon2
      • Dec 2019
      • 14789
      Hi.
      1) Remove all power -> meter in resistance mode (lowest scale) -> check the resistance to ground of VINT20. What is the reading ? Also post the meter scale.
      If the meter reports '1' or 'OL' (over limit) -> switch to a higher meter scale.
      2) Check the first 2 mosfets for defects using the usual mosfet resistance checks.
      With NO power. Meter in resistance mode.
      check the resistance of each mosfet:
      source (1-2-3) & drain (5-6-7-8)
      source (1-2-3) & gate (4)
      gate (4) & drain (5-6-7-8)
      post the readings of Q9, Q36 mosfets along with the meter scale.
      3) With the power on -> meter in 20v scale -> check the voltage reading of the following pins:
      ACDC_IN_CONN
      ACDC_IN
      F2, Pin # 1
      F2, Pin # 2
      U7, ACDET pin # 4
      U7, pin # 36 (AVCC)
      U7, pin #15 (REGN)
      4) Are you using a docking station ?
      5) Are you using the official and original power adapter ? The ID pin on the adapter is being used to identify the presence of the original adapter so it must be used.
      • cyngo
        • Jun 2015
        • 219
        • Indonesia
        now the 20V voltage can enter across R340 by removing Q79 and adding R504. on the power button there is also a voltage of 3.3V. But still can't be switched on. after analysis, the -PWRSHUTDOWN signal only appears shortly after the PSU is connected, after that it disappears. does that indicate if the ThinkEngine chip is faulty? Has anyone experienced it?
        • aletec
          • Apr 2017
          • 2
          • Argentina
          I have the same laptop, with the same problem. I discovered that with the battery it turns on and stays on. The issue is that when the source is connected, it does not charge the battery. This does not turn on with the source either and the voltage drops.
          https://www.youtube.com/watch?v=b6XN7BhChA8
          • mon2
            • Dec 2019
            • 14789
            Carefully measure the voltage to ground of the following pins, with the power adapter connected. Remove the battery before testing.
            U7, ACDET pin # 4
            U7, pin # 36 (AVCC)
            U7, pin #15 (REGN)
            Post the measurements.
              Lenovo ThinkPad W540 Mobile workstation W Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad W540 Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the W540 boardview and W540 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
              09-06-2024, 05:27 AM
              Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
              09-06-2024, 11:40 AM
