3300µF 450V caps...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    3300µF 450V caps...
    Okay...
    I scored a "small" pile of 3.3mF 450VDC(525V surge) 85°C electrolytic capacitors, looks like they are "BC" branded capacitors, looks like Vishay bought them. Now...what can I do with them. Unfortunately probably not low ESR caps else making a railgun would have been something.
    ½CV² with these is no joke... with one of these on the input of a psu would have a significant hold up time.
    Do people normally short the terminals of such large capacitors during storage? Or probably the previous owner worried about the lurking of the evil charge sending one flying in a very un-technician-like manner?
    • 31125
    Re: 3300uF 450V caps...
    make an electric chair for communists - that uses a stored charge to not overload a domestic supply!
    dont forget to include inrush limiting.
    • redwire
      • Dec 2010
      • 3912
      You can do the math but the energy to lift up a person a foot off the ground, is stored in one cap. How far a commie would launch... they're full of so much hot air lol.
      I don't short electrolytics in storage, I find they do go up to a few volts at their natural half-cell potential which keeps the oxide alive.
      But dielectric absorption could mean the caps float up to HV a short time after use. You have to check, especially after reforming.
      I have oil-filled low value like 0.05uF 20kV HV caps that I store shorted because they are known to pick up stray static electricity and bite. This is common knowledge from back in the old days of radio transmitter work.
      As for an application for the caps- I've seen those values in motor drives and electro-fishers. Charge to 400VDC and discharge into fishnets to catch them.
      In tube audio amplifiers they are pretty big, 3,300uF is 5-10X what is normally used.
        • 31125
        ah yes, the self charging cap thing.
        i have noticed that, i dont think it's "static"
        you get the same effect from nimh batteries.
        what do they have in common?
        a long electrode rolled up.
        i think they are charging from either what tesla called the "ether" or from tv/radio/radar or other emmited energy
        • PeteS in CA
          • Aug 2005
          • 3581
          • USA, Unsure of Planet
          Maybe you could use them as hand weights for weight training?
          PeteS in CA
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            They do have some heft per unit but not really that much, seen bigger.
            Speaking of weight, technically they have a significant amount of aluminum in them, though the electrolyte probably contributes to total mass... Wonder what the aluminum scrap value is,...
            • redwire
              • Dec 2010
              • 3912
              In the repair shop one tech would charge caps to 400VDC in the Heathkit and toss them at you yelling "catch!". I let them fall on the ground but a few people got nailed.
                • 31125
                fuckers,
                if anybody had tried that with me i would use the same trick with pre-heated soldering tips!
                grab one with the longnose pliers and "hey dickhead - CATCH"
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  how many uF is needed to not cause damage and make a difference ?
                  I think a 3.3mF could cause significant damage... granted you have to get unlucky in one direction, most of the cap is insulated...
                  Then again ... add screws to it and have it protrude out more...
                  (hmm... speaking of these screw terminal caps, most of the ones I've dealt with use #10-32, but now these 3.3mF use ¼"-28 despite not being low ESR AFAIK.)
                    • 31125
                    last caps with threaded studs i bought used M8 metric
                      Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
                      by momaka
                      I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
                      For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
                      https://www.badcaps.net/filedata/fetch?id=3591771
                      https://www.badcaps.net/filedata/fetch?id=3591772
                      It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
                      https://www.badcaps.net/filedata/fetch?id=359177...
                      03-12-2025, 03:42 PM
                    • eryjus
                      Heathkit IO-4205 Power Supply Caps
                      by eryjus
                      First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
                      I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
                      I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
                      05-10-2023, 11:21 AM
                    • Paxman_Swede
                      Identifying caps on an old Zoom 9000
                      by Paxman_Swede
                      Hello!
                      I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
                      The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
                      I have studied the board and...
                      01-14-2025, 09:51 AM
                    • captain150
                      Help with switching power supply caps
                      by captain150
                      I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
                      I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
                      03-16-2025, 07:34 PM
                      EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                      by momaka
                      I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                      So, here is the...
                      06-06-2020, 04:39 PM
