Sony CFS-B11 Radio cassette boom box
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    I am trying to diagnose this small radio/cassette player where the audio cuts out after a few seconds - then comes back, then repeats.
    I've checked the voltage and current coming from the PS board and it seems fine.
    I've also powered it from a bench PS and the fault remains.
    All of the electrolytics on the audio board are normal with no high ESR's or bulging tops.
    Any ideas?
    I've attached the service manual for the unit.
    Many thanks.
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: Sony CFS-B11 Radio cassette boom box
    Check the headphone jack, there is a contact lock for the speakers.
    • Nevillet
      • Sep 2019
      • 272
      • United Kingdom
      It doesn't seem to be the headphone jack. I've connected directly to the outputs of the TA8229K (P3+P5) and it still happens
      • Nevillet
        • Sep 2019
        • 272
        • United Kingdom
        I've connected to the input pins (P11 + P12) same problem it cuts out.
        • lotas
          • Jan 2016
          • 4708
          • Russia
          Does the sound disappear on all functions "FM", "AM", "TAPE"?
          • Nevillet
            • Sep 2019
            • 272
            • United Kingdom
            yes it does on FM/AM/SW (the tape deck is non functional due to lack of belts).
            I've checked the supply voltage to the tuner IC (CXA1238S) (and when working the supply is 4.2V then it disapears to 0.2V when there is no audio o/p
              • 31139
              check the input to the amp i.c. - it could be cutting out from an internal fault.
              • lotas
                • Jan 2016
                • 4708
                • Russia
                If there is a bolon with liquid for cleaning contacts, then you can puff to the contact groups of the switches and click them back and forth (contact may disappear in them).
                • Nevillet
                  • Sep 2019
                  • 272
                  • United Kingdom
                  I think it might be the amplifier that is intermittantly shorting which drags the supply down.
                  • Nevillet
                    • Sep 2019
                    • 272
                    • United Kingdom
                    The switches have been disasembled and cleaned with super 10
                    • R_J
                      • Jun 2012
                      • 9579
                      The supply to IC301 should be 7.6 volts on pin 1, Pin 18 is a 4.8v output that is switched by the ic, This output controls the base of Q303 which supplies 4.1 volts to the tuner board, that's why that voltage is changing.
                      • R_J
                        • Jun 2012
                        • 9579
                        Did you have this problem before or after you disassembled the switches?
                        • mikey5791
                          Sony CFS-5000S radio cassette player no FM reception
                          by mikey5791
                          Hi forum members,
                          In the past i have had many helpful hints from generous forum members in diagnosing and solving issue related to most of my electrical things.
                          Fyi, i have been keeping this unit of Sony radio cassette player as the cassette belting has worn off but the radio has been working fine before. Recently, out of a sudden i found out i can't get any radio reception at all (no signal from FM,MW or SW band) except some buzzing warp noise from the speakers.
                          I opened the casing inside and checked for any dry solder, burned component or loose wires...
                          02-24-2023, 03:48 AM
                        • UserXP
                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                          by UserXP
                          Dear all,
                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                          My question is, do you know of this brand of capacitors and how bad are...
                          07-21-2025, 08:35 AM
                        • shelby5041
                          clock radio / radio lifespan?
                          by shelby5041
                          hi
                          ive got a modern digital clock radio approx 15yrs old
                          my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                          since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                          the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                          it uses very little power just a few watts i would imagine that may have something...
                          09-14-2024, 03:30 AM
                        • praveenramavath
                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                          by praveenramavath
                          Hello All,
                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                          https://www.hifivision.com/threads/m...-screen.98243/
                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                          04-26-2025, 09:08 AM
                        • Carlos#2003%
                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                          by Carlos#2003%
                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                          02-15-2024, 07:52 PM
