Asus tp550ld randomly shutdown
  • khelane
    • Apr 2015
    • 172
    • xxxx
    Hello
    The ASUS TP550LD has a sudden shutdown problem.
    This device did not turn on before this problem was fixed by replacing the MOSFET PQ8802, but before the I / O heat given by another repairman, I checked the I / O bases completely, there is no problem, but now the device turns off sometimes after replacing the MOSFET or some Sometimes it turns off and on several times in a row.
    Another problem with the device is that the battery charge light is always on, even when the battery is not connected.
    I also tested the battery-related pins up to IC I.O and IC charging for ohmicity and connectivity, and had no problems with the resistors being the right amount.
    The replaced MOSFET is exactly the same as the previous model.
    The motherboard has no problems in terms of appearance and temperature.
    The device is now on for 55 minutes and a full HD movie is playing, but the battery light is on while the battery is not connected at all.
    Battery pins
    12 volts
    3.3
    3.3
    'GND
    ALL are present
    Why is the charging light always on?
    ASUS TP550LD REV:2.0
    TNX
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus tp550ld randomly shutdown
    What is the voltage on ACDET pin?? Which chargging IC is in use here??
    • khelane
      • Apr 2015
      • 172
      • xxxx
      2.6 v
      BQ24735 CHARGER IC
      charger ic voltages :
      1: 19.5
      2: 19.5
      3: 18.77
      4: 24.17
      5: 2.78
      6: 2.6
      7: 0
      8: 3.2
      9: 3.2
      10: 11.25
      11: 11.7
      12: 12.56
      13: 12.56
      14: 0
      15: 0
      16: 6
      17: 17.36
      18: 12:67
      19: 12.56
      20: 19V
      in last i don't programmed laptop
      • mon2
        • Dec 2019
        • 14786
        Pin 10 is the wrong value for ILIM. Check this voltage again.
        This pin may be shorting with pin 11.
        Remove all power, meter in resistance mode.
        Check the resistance between the pins 10 and 11.
        Reading?
        • khelane
          • Apr 2015
          • 172
          • xxxx
          Reading?
          When I connect the charger to the laptop, the basic voltage is sometimes 1.5 and sometimes 0.8 volts, and after a second it reaches 11 volts.
          resistance pin 10 -11 is 4.5mega ohm
          • mon2
            • Dec 2019
            • 14786
            According to the datasheet, pin 10 should be a fraction of the 3v3 rail and is configured by 2 resistors acting as a voltage divider.
            The voltage of pin 10 is way too high and may indicate a defective charger IC.
            Review the area to locate the resistors that define this reference voltage. Higher the voltage, higher the ILIM threshold. Check against the datasheet on how this pin functions.
            The external resistors on this pin should also be inspected to confirm they are not the root cause of this voltage spike.
            Believe it should be replaced. Good idea to purchase spares.
            Update..see table 7.1 of the datasheet. Max voltage is 7 volts for ILIM. This charger IC is now defective.
            • khelane
              • Apr 2015
              • 172
              • xxxx
              pr8819 and pr8820 are resistors connected to pin 10. Both values are correct. According to the IC datasheet, there should be 3.3 on this point, but instead it is 11 volts!
              Thank you for your advice dear
              After replacing the IC, the result will be announced
              Is similar to this IC available?
              • mon2
                • Dec 2019
                • 14786
                If you remove PR8820, do you see 11 volts where it is marked '+3VA' in the boardview file ?
                Trying to determine if the 11 volt is from the charger IC that is now very likely to be defective or the external '+3VA' rail that probably has a shorted high side mosfet and the DCIN of that mosfet has yielded the 11 volts where it should have been +3VA.
                Many widgets use this +3VA rail including the EC and the 11 volts would have killed these devices but continue the investigation.
                • khelane
                  • Apr 2015
                  • 172
                  • xxxx
                  I took PR8820, IC side 0v and 3VA side 3VOLT
                  After attaching the PR8820 resistor, I measured the voltage again, the IC side goes up and down from 0.8 to 2.1, but sometimes it is 1.5 volts, and the 3.3VA side is 3.290.
                  one question
                  If there is a problem with +3VA, how does the system turn on and how many hours does it work sometimes?
                  • mon2
                    • Dec 2019
                    • 14786
                    Can you confirm that your meter has fresh batteries ? Perhaps replace them and then review the voltage readings again. The measurements may be off due to the accuracy of the multimeter.
                    • khelane
                      • Apr 2015
                      • 172
                      • xxxx
                      i Checked it and try new batteries .
                      voltage before start is 0.8 and after start 1.5volt come slow rise to 1.6 and 1.7 then few range betwen 1.5-1.7
                      • mon2
                        • Dec 2019
                        • 14786
                        Ok.
                        1) fresh batteries on the meter are now reporting the proper voltages.
                        2) to save time, identify the parts you have reviewed. What the battery connector label on this logic board ?
                        Which mosfet is linked to the battery mosfet ?
                        3) Using resistance mode (remove ALL power), you should review each mosfet starting with:
                        ACFET (I think you have said that it has been replaced)
                        RBFET (reverse blocking fet)
                        high side mosfet for the battery charging
                        low side mosfet fort the battery charging
                        battery mosfet that enables when the logic board is powered from the battery
                        Once you share the battery connector details -> review the location of a potential SMBUS / I2C ESD diode. Often this is a faulty component.
                        • mon2
                          • Dec 2019
                          • 14786
                          Found the requested details.
                          1) J6003 = Battery connector.
                          2) See attached. Do you have this ESD diode array on your logic board ?
                          PD6001 = ESD diode array used to protect the battery interface.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Acok(pin5) seems bit low.Should be 3.3V. Check acok voltage divide resistors.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              Try Replacing R2 in the ac det voltage divider,even if the value is correct.If that don't help, try lowering the value of R2 resistor a bit(say 5% less value).But don't try value which is way below specified, only 5% difference,not more than that.
                              • khelane
                                • Apr 2015
                                • 172
                                • xxxx
                                Sorry, I could not answer in time
                                Yes PD6001 available
                                I will do the mentioned tests for you tomorrow
                                • mon2
                                  • Dec 2019
                                  • 14786
                                  Remove PD6001 and test to see if it makes a difference on your logic board.
                                  • khelane
                                    • Apr 2015
                                    • 172
                                    • xxxx
                                    I removed the PD6001 but nothing happened
                                    try again charger ic voltages :
                                    1: 19.5
                                    2: 19.5
                                    3: 18.77
                                    4: 24.17
                                    5: 2.78
                                    6: 2.6
                                    7: 0
                                    8: 3.2
                                    9: 3.2
                                    10: 1.6 -1.7 (few rang)
                                    11: 11.7
                                    12: 12.56
                                    13: 12.56
                                    14: 0
                                    15: 0
                                    16: 6
                                    17: 17.36
                                    18: 12:67
                                    19: 12.56
                                    20: 19V
                                    • khelane
                                      • Apr 2015
                                      • 172
                                      • xxxx
                                      Inside the ic data sheet on page 3, the required voltage of acdet is 2.4 to 3.15. The read voltage is 2.6 (I don't think there is a problem)
                                      • khelane
                                        • Apr 2015
                                        • 172
                                        • xxxx
                                        1: 19.5
                                        2: 19.5
                                        3: 18.77
                                        4: 24.17
                                        5: 2.78
                                        6: 2.6
                                        7: 0
                                        8: 3.2
                                        9: 3.2
                                        11: 11.7
                                        12: 12.56
                                        13: 12.56
                                        14: 0
                                        15: 0
                                        16: 6
                                        17: 17.36
                                        18: 12:67
                                        19: 12.56
                                        20: 19V
                                        I already replaced the PQ8802
                                        Ohm check mosfet's:
                                        PQ8803 == D--S :275K G--S :6MEGAOHM G---D :5.6MEGA
                                        D---GND :98K S---GND :460K GATE----GND :OL
                                        PQ8804== D--S :480K G---S :171K G----D :600K
                                        D---GND :270K S---GND=0HM GATE--GND : 172K
                                        PQ8805 == D--S :480K G---D=600K G---S: 200K
                                        D---GND : 98K S---GND :270K GATE----GND:600K
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
                                        • Scotchmist
                                          Asus GA502D keeps blowing mosfet
                                          by Scotchmist
                                          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                          I have removed the mosfet and can run the laptop no problem
                                          The MOSFET is FDPC5018SG
                                          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                          08-24-2024, 02:23 PM
                                        • MicroSMD Lab
                                          ASUS ROG Zephyrus GPU Mosfet repeat failure
                                          by MicroSMD Lab
                                          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
                                          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                          01-10-2024, 06:36 AM
                                        • someonenotyou
                                          ASUS G513R - cannot remove MOSFET
                                          by someonenotyou
                                          Hi.
                                          I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
                                          I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
                                          Of course, I did not force it, but tried to lift it up with tweezers.
                                          Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
                                          10-10-2025, 11:05 AM
                                        • kacangpolo
                                          Asus X415EA Auto start when shutdown ( Laptop cannot shutdown with baterai only )
                                          by kacangpolo
                                          I have problem with my laptop, with code board X415EA 2.0,
                                          laptop cannot shutdown with baterai only, if i plug the adaptor, laptop can shutdown, but when the adaptor was unplug, laptop wake up
                                          I did :
                                          1. Flash Bios
                                          2. RTC_RST 3.3V
                                          3. LID_SW 3.3V
                                          4. WLAN_WAKE# 3.3V
                                          08-26-2025, 04:42 AM
