Component tester which one is worth the money from it capability to test and identify
    • Jul 2011
    • 6070
    I am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
    Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
    There are so many versions of this type of device and I do not have enough information to make a good decision at this point
    When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise ( also school training as well )
    I have some experience with testing component with multi meter but this type of testing is very limited
    The reason I am having this post is because I going to try to fix a semi truck computer that has issues with parking lighting circuit and I want to attempt to fix the one that is in a parts truck first to get my feet wet so to speak
    I know that this version of this truck has many issues with the parking lights not working correctly anymore after welding on the frame and other mishaps I do not know what the actual history of this truck that my son bought and the parts truck ( this was a package deal for both trucks and was a good price that we got on both )
    Yes I have the wiring diagram for this truck already and gone through it so I have some type of idea of how to tackle the issues with this truck
    I know how to bypass the computer controller issue but I would like to repair it if possible before I just make it a permanent bypass of the computer ( he has to make money with this truck to pay for buying this investment and how he going to make a living with it ) ( the cost of used semi truck before DEF restrictions became in forced and made mandatory have dropped in price recently which is why my son has made the decision about buying this late model truck because some of his friends that are also owner operators have bought or lease a newer model truck and have nothing but issues with there trucks )
    One note this computer has two different circuits on the parking lights one is for the front of the truck and this circuit still works however the one for the back of the truck is the circuit that is completely dead so I just tapped of the circuit that still works and use a power relay to power the back of the truck parking lights )
    The dash board lighting the on and off switch the dimmer function is also controlled by the computer ( which function correctly as of now )
    The power windows motor and it controls circuit is also controlled by the computer which also does not work either however someone has tried to fix this issue and could not figure out what wrong with it which is my next thing to work on when the truck is not being used
    The cost of a used computer that you have no idea about it history and if all of the functions work correctly
    start at $300.00 to over a $1000.00 used I might have to go this route and take my chances and hope for the best
    A reconditioned computer starts at over $1000.00 to over $7000.00
    My guess to what is wrong with this computer issue is that some type of mosfet or some type or some type transistor failure on the parking light circuit
    I have seen on several occasions someone attempting to fix a problem on automotive type of computers sometimes they have been able to fix the issue and I am hoping to do the same with some luck
    I have on several occasions have successfully repaired computer controlled machine before so I hope I can do this with type of issues here
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Component tester which one is worth the money from it capability to test and iden
    There is a nice document here that has a comparison:
    But the basic thing is that they are all pretty much the same so long as they have the same processor.
    And the venerable Atmega328 is really maxed out so you can't enable all features.
    So a version based on the Atmega 644 was released with more memory.
    This is the one I would recommend for home bench use.
    Here is a picture of one: https://www.eevblog.com/forum/testge...10/#msg2530110
      • 31264
      644 or 1284
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8342
        There is decent money in ecu repair… I’ve done a few of them. Some successful, others not. If not successful, most of the time it boils down to some sort of parts issue unless you got donors. If you don’t have donor boards your chances are going down quick.
        Here are a few tips that I picked up. Look at capacitors, large wattage SMD resistors and corrosion. Had a truck with blinker issues. When I took the ecu apart, I found out that they were using mosfets as switches. As long as the gate drive to turn on the gate of the mosfet is working, the rest should be ezpz.
        As for the component tester, I use one from Peak.
          • Jul 2011
          • 6070
          There is decent money in ecu repair… I've done a few of them. Some successful, others not. If not successful, most of the time it boils down to some sort of parts issue unless you got donors. If you don't have donor boards your chances are going down quick.
          Thanks for the information
            • Jul 2011
            • 6070
              • Jul 2011
              • 6070
              Originally posted by stj
              644 or 1284
                • Jul 2011
                • 6070
                Well here is what the issue turn out to be with the parking lights
                The parking lights / brake light / turn signal lights / reverse lights module enclosure was not wired correctly after figuring out what was not wired correctly I now have the cab brake lights / turn signal lights / parking lights now working correctly
                To get the wiring pins in the correct position I broke a few pin tabs and had to hot glue the pins in place for good measure to make sure that would not push out of the connector hot glue is real good for this
                The parking lights were not working correctly for trailers pig tail which turns out to be that the relay does not get power to the coil which I still do not know where it get power from to power the relay but I have an external relay hot wired to parking lights in the front of the truck cab for now and he can drive down the road legally with out getting stopped
                When I have more time and my son is not using the truck I will do some more troubleshooting on this issue as well
                But when I have more money to spend I will probably buy the peak component tester
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8342
                  That is an excellent component tester. Never let me down so far.
                    • Jul 2011
                    • 6070
                    Thanks for your feedback
                    • Crystaleyes
                      • Sep 2021
                      • 493
                      • Brazil
                      I've had one of the T7 testers for a few months now, which seems ok. The main gripe I have is that the clamp pins lose their grip a bit from constantly removing and inserting the test leads, so it would be a great improvement if it had individual sockets and pins for the three test leads. A mod which I'll probably end up doing.
                      Another observation is that there are at least two completely different testers on the market within identical casings, as can be seen in the photos. The 2nd one seems to be a better build, but how you can tell just from the front (pic 3) I couldn't tell you.
                      • howardc64
                        Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                        by howardc64
                        Samsung have been using this style LED connector for few years now
                        Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                        The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                        10-12-2025, 08:13 PM
                      • Lifeisfun
                        Trying to troubleshoot DDR4 SODIMM slot with slot tester
                        by Lifeisfun
                        Hi folks!
                        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                        Eventually I discovered that it was related to moving the laptop.
                        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                        I removed the board got one of those memory slot testers...
                        06-04-2025, 02:26 PM
                      • spleenharvester
                        Reverse engineering of 18650 4-channel tester
                        by spleenharvester
                        Hi friends
                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                        05-04-2025, 02:43 AM
                        FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                        by sam_sam_sam
                        https://www.ebay.com/itm/405035016711
                        I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                        I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                        04-13-2025, 08:17 PM
                        Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
                        by sam_sam_sam
                        When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
                        This switching power supply was really fun to recap the quality of the board was very good...
                        02-25-2024, 08:55 PM
