TCL 40S325-CA backlights, sound, no picture
  • lapse
    • Jun 2022
    • 21
    Hello, another TV found on the sidewalk here.
    I have a TCL 40S325-CA ROKU LED TV. The backlights turn on, I can hear the typical Roku click sound when pressing the power button (no remote unfortunately) but nothing is displayed on the screen.
    Power supply:
    Main board goes into standby, so no reason to suspect anything here. Backlights turn on, etc..
    Driver boards:
    I have 12V going on both sides of the fuse on the panel driver boards.
    VGH and VGL are around 1V when powered on.
    No shorts to GND on any of the test pads or any of the caps on the driver boards.
    Main board:
    See pictures - a number of the caps seem shorted, however they're about 90Ohms to GND. In diode mode, red probe on GND, black probe on non-GND side of the caps then I get about 0.05V.
    With the TV turned on, there's about 1V on the caps.
    My FLIR doesn't show any excessive hot spots on the board except for the main processor.
    Thoughts? Main board toast?
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: TCL 40S325-CA backlights, sound, no picture
    Vgh and Vgl are both bad.
    • nomoresonys
      • 12117
      • U.S.
      ^^^ I agree, very bad.
      • lotas
        • Jan 2016
        • 4555
        • Russia
        90 Ohm is a normal resistance, it can be even lower, and 1 volt is the power supply of the processor core (there is always low resistance on this bus).
        • nomoresonys
          • 12117
          • U.S.
          vgh should be 20-30, vgl -5 to -12.
          • lapse
            • Jun 2022
            • 21
            Ugh ok, I'll track down why VGH and VGL are gone.
            • lapse
              • Jun 2022
              • 21
              This is very good information. Thank you!
              • dskall
                • Oct 2016
                • 2905
                • usa
                Might try unhooking one side of panel board and see if voltages come up. Some good pictures of panel boards would help.
                • lapse
                  • Jun 2022
                  • 21
                  Okay, I did a bit of troubleshooting. Of the two FPC cables that join the two driver boards, I found where VGH/VGL are and disconnected that ribbon cable.
                  I turned on the TV but VGH/VGL is still missing, so it's not the secondary (left-side) driver board.
                  Since this is a trash TV, I had nothing to lose so I found where VGH was going to to the COF flex on right-side driver board and cut the trace. I turned on the TV and got VGH=23V and VGL=-7.98V. A bit of success!
                  But still no picture.
                  CKV=1.6V
                  STV=0V
                  • lapse
                    • Jun 2022
                    • 21
                    Attached are some more pictures of the panel driver board that I've been poking at.
                    Apologies, but the last two pictures seem to have been uploaded and rotated 180!
                    Last edited by lapse; 07-01-2022, 09:51 AM. Reason: Noticed last two pics are 180 out
                    • nomoresonys
                      • 12117
                      • U.S.
                      hmm, well if it's a shorted panel, maybe the tape cu-off method will work?
                      • lapse
                        • Jun 2022
                        • 21
                        I don't think it will... there's no dedicated TCON board. The signals seem to be passed-through one driver board to the other.
                        I think the tape cut off method _might_ work if the problem were on the panel driver board that's daisy chained off the main panel driver board (see first set of pics). However, the VGH trace that I severed is on the "main" panel driver board that has the LVDS connector going to it from the mainboard.
                        • dskall
                          • Oct 2016
                          • 2905
                          • usa
                          Probably need to inspect panel traces for short. And look at side cofs. If panel short you can jumper around it
                          • lapse
                            • Jun 2022
                            • 21
                            Any YouTube videos, or previous posts that I can use to help educate myself about doing this?
                            • nomoresonys
                              • 12117
                              • U.S.
                              there's one of many videos, you might even find one in English but it might take some looking, why youtube doesn't have a choice to search for a preferred language is a mystery: https://www.youtube.com/watch?v=wQA02AvViRE
                              • lapse
                                • Jun 2022
                                • 21
                                Okay, I jumpered VGH to the side COF and got picture. Unfortunately huge horizontal lines are running across the screen. Spent enough time on this one, so I’ll scrap it for parts and take the rest to the dump!
                                RIP!
                                • TR103
                                  by TR103
                                  - it keeps rebooting
                                  01-22-2025, 04:12 PM
                                • Mgiffune
                                  by Mgiffune
                                  06-09-2024, 10:28 AM
                                • Ierwin
                                  by Ierwin
                                  05-13-2025, 03:31 PM
                                • jchang
                                  Samsung UN70NU6900F no picture and no sound
                                  by jchang
                                  Hi all
                                  I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                  Symptom:
                                  No picture no sound.
                                  When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                  No sound at all.
                                  What I tried:
                                  1. I tried unplugging the left or right ribbon...
                                  01-09-2023, 06:28 PM
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
