TS1102A datasheet wanted
  • petehall347
    • Jan 2015
    • 4430
    • United Kingdom
    looking for datasheet for above mcu ic .
    • Jul 2011
    • 6057
    Re: TS1102A datasheet wanted
    Can you please post a picture of the ic chip
    • petehall347
      • Jan 2015
      • 4430
      • United Kingdom
      ts1102a
        • Jul 2011
        • 6057
        ts1102a
        I sent you a PM about this date sheet request
        I created an account to see if could find the data sheet as you can see from the terms and conditions it is not going to be available
        TS1102A is a micro controller from Renesas Technology Corp Japan
        And from I can see I do not think that this company put there data sheet available on the internet
        Unfortunately I have run into this issue with other company’s products that are made for a vendor that are not available no matter what you do to try to get it
        The chip is available from AliExpress and a couple of other vendors but no data sheet
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8286
          Renesas is notorious with this issue.
          • petehall347
            • Jan 2015
            • 4430
            • United Kingdom
            i know there isnt a datasheet but is it possible to read a good one and program a new one ?
            the old one is dead but have access to a good working one .
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8286
              That’s a very good question on how you would program it.
                • Jul 2011
                • 6057
                Well I think it would depend on whether or not you can reverse engineer the device circuit but with out data sheet I do not know if can figure out the micro controller data pins or not this to me would be the biggest problem
                • lotas
                  • Jan 2016
                  • 4708
                  • Russia
                  From the Chinese forum:
                  (Excerpt)
                  Lithium Battery Protection Board (TS1102A+N0412)
                  Circuit classification: Instruments Circuit name: Lithium battery protection board (TS1102A+N0412) Product description:
                  This circuit is based on the Renesas TS1102A microcontroller and controls the charging and discharging of the battery through the N0412. Avoid abnormal battery condition such as overcharging, overdischarging, overcurrent, short circuit, etc.
                  Main characteristics
                  TS1102A has
                  16 KB flash, 2 KB RAM
                  3 port port
                  Uart 16X16 --> 32bit, 16X16+32 --> 32bit, 32/32 --> 32bit
                  Operating voltage 1.6 ~ 5.5V, built-in high-speed generator, full temperature accuracy ±1%
                  ultra-low power consumption Timer stop interval wake up average power consumption less than 1uA
                  • petehall347
                    • Jan 2015
                    • 4430
                    • United Kingdom
                    (Excerpt)
                    TS1102A has
                    3 port port
                    interesting thanks .. wondering what the +N0412 is .
                      • Jul 2011
                      • 6057
                      (Excerpt
                      Thanks for the information
                      • lotas
                        • Jan 2016
                        • 4708
                        • Russia
                        N0412N N-CHANNEL MOSFET FOR SWITCHING
                        http://www.superfly.com.cn/cview.asp?id=22
                        • Tr0ll
                          by Tr0ll
                          Original T-con:
                          First replacement T-con:
                          10-07-2023, 07:48 PM
                        • JJAAMM
                          by JJAAMM
                          Problem
                          07-06-2023, 06:01 AM
                        • TR103
                          by TR103
                          - it keeps rebooting
                          01-22-2025, 04:12 PM
                        • Mgiffune
                          by Mgiffune
                          06-09-2024, 10:28 AM
                        • redbaron1007
                          High Power HP1-J600GD-F12S
                          by redbaron1007
                          I got a High Power HP1-J600GD-F12S on the bench today that was killed by roaches judging by the dead roaches and large brown spots in the housing next to said roaches.
                          I was able to identify all the blown smd resistors on the board aside from the one located at R69. I wasn't able to figure out what any of the marking on the resistor was supposed to be and with how little of the marking was left I wasn't able to really make any guesses about what it could be from the surrounding components. It is connected to pin 1 of Q11 (4N65SFA1K) which looks like it is the gate .In the sample...
                          09-21-2024, 07:00 PM
