Dell XPS 9360 (LA-F051P rev 1.0) BIOS needed
  • jacobtc
    • Apr 2016
    • 274
    • Denmark
    Does anyone have a working BIOS for this laptop? I read the original BIOS, and have attached in.
    Symptoms can be read in my other thread: https://www.badcaps.net/forum/showthread.php?t=107907
  • hoaca388
    Badcaps
    • Jan 2022
    • 12426
    Re: Dell XPS 9360 (LA-F051P rev 1.0) BIOS needed
    Xps 13 9360
    • jacobtc
      • Apr 2016
      • 274
      • Denmark
      Originally posted by hoaca388
      Xps 13 9360
      Thanks, I will give it a go.
      • jacobtc
        • Apr 2016
        • 274
        • Denmark
        Weird, I now get a 5 white, 2 amber error code, this means "invalid memory installed" according to Dell... The machine has soldered RAM. The power button lights up now, but turns off again after a couple seconds, and the error described shows up.
          • 22209
          Try this one.Give it a few minutes. If it eventually boots up ok you can update to the latest from dell support to update all the other firmware
          • jacobtc
            • Apr 2016
            • 274
            • Denmark
            Sadly it gives me the same memory error.
            EDIT: https://www.dell.com/support/manuals...b5a&lang=en-us
            Weird that it gives me the "Invalid memory installed" error, and not the "Memory or RAM failure"... Could this mean that the memory is okay?
            • phamduy221
              • Jan 2021
              • 55
              • vietnam
              i need ut5 and ut6 bios of la-f051p can someone help me, thanks
              • ngovanchung
                • Apr 2022
                • 15
                • vietnam
                Please help me, the screen does not display, the lights are flashing 2 yellow - 1 white.
                • peste
                  • Dec 2016
                  • 13865
                  • ROMANIA
                  post S/T, full name and model, motherboard model, ,etc.
                  • ngovanchung
                    • Apr 2022
                    • 15
                    • vietnam
                    Dell xps 9360
                    CAZ70 LA-F051P
                    REV: 1.0 (A00) 2017-06-29
                    S/T : lost the old casing, cannot retrieve it
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
                    • mikeybass
                      Dell 9010 MT BIOS Update Always Fails
                      by mikeybass
                      Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                      04-23-2025, 04:30 PM
                    • capoplays
                      Help with BIOS update on Dell G15 5515 after chip replacement
                      by capoplays
                      Hey everyone,
                      I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                      The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                      When I check the BIOS using the F12 menu Flash...
                      10-24-2025, 06:53 AM
                    • Akhlz001
                      Dell Pro 13 Plus PB13250 Bios Unlock
                      by Akhlz001
                      Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                      09-20-2025, 07:15 PM
                    • 417731
                      BIOS needed for Dell Vostro 3405
                      by 417731
                      Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                      Model: Dell Vostro 3405
                      Tag:F0B1YF3
                      CPU:Ryzen 3500U
                      Thanks in advance
                      07-06-2025, 06:48 PM
