hp 850 g4 slow
  • munir100
    • Dec 2018
    • 187
    • uae
    hp 850 g4 slow
    i have hp 850 g4 problem is prass power button laptop on show only - slow boot to windows i chang bios but problem is still on ssd go to windows not go m2 m2 is ok
  • futadmytro
    Asus g713qm-es94 stuck on boot bios problem
    by futadmytro
    sn^M4NRKD02753616E
    MB- g533-6050a3250201-MB-A03
    Stuck on boot after ROG logo, did not enter to bios
    In flash bios , laprop boot but have video issue
    orig bios...
    06-25-2025, 08:07 AM
  • mpower1226
    Dell optiplex 7090 boot problem
    by mpower1226
    Hi masters, need your help in solving this mystery.
    i have a dell optiplex 7090 micro that i bought from local kijiji.
    when i turn it on, error comes out saying no hard disk.
    i go to bios to check the boot option, only httpboot shows. If i try to add boot option, it only shows file search but nothing happens when i click.
    i took out the ssd and put it into old laptop and format and installed the windows 10 and put it back into the desktop. It boots up and same error again no hard disk.
    it seems as if the computer doesnt recognize the ssd...
    01-22-2024, 10:37 PM
  • eltano4i20
    [HELP] SAMSUNG NP270E4E-K01AR
    by eltano4i20
    1) Error trying to enter the BIOS
    --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
    Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
    BOOT PRIORITY ORDER (img-05)
    1- Windows Boot Manager
    2- SATA HDD
    3- NETWORK
    4- Debian
    2) Error trying to access the BOOT MENU
    --> I restarted the notebook and pressed [F10] but the BOOT...
    07-04-2025, 12:39 AM
  • jurgenkoppen
    Early 2013 15"MBP Slow boot, and 50% of the time will show question mark folder
    by jurgenkoppen
    It does boot sometimes, but only after hanging for way longer than is normal for a A1398 of this vintage to come to the logo. Half of the times I try to boot it just gives me the question mark folder! I tried the usual SMC and PRAM resets, and I ran First Aid when the machine did decide to boot, but first Aid did not repair anything on the SSD, but came back with SSD is OK. I booted of external drive, and it did boot then.I reseated the SSD, looked at the connection under the scope. Looking clean.I switched to another known good SSD blade, same issue. I tied Safe Mode, but it hangs at login screen,...
    01-03-2020, 12:45 AM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
