PF43hd6 no standby
  • sordids999
    • May 2013
    • 2161
    • uk
    PF43hd6 no standby
    Hi
    This is a tv monitor which has no standby
    Fuses look also good so I need a bit of help please
    Voltages
    Con5
    Gnd
    Gnd
    +5v =5.0v
    +5v =5.0v
    Ps/on =4.1v
    +5vsb = 5.0v
    +5v =5.0v
    +5v =5.0v
    Gnd
    Gnd
    Gnd
    +12v =13.3v
    +12v =13.3v
    Con3
    +12v =13.3v
    +12v =13.3v
    On/off =0.00v
    Adj=5.0v
    Led backlight voltage
    +76.1v -0.00
    +76.1v -0.00
    Main cap is 323v
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: PF43hd6 no standby
    No standby or no backlights?
    • sordids999
      • May 2013
      • 2161
      • uk
      Sorry no standby light or backlights
      TV just seems totally dead
      • sordids999
        • May 2013
        • 2161
        • uk
        If I jump ps/on and 5v I get voltages
        +12v go to 11.8v
        Ps/on goes to 4.8v
        • dskall
          • Oct 2016
          • 2905
          • usa
          So mainboard not sending signal to turn on.
          • sordids999
            • May 2013
            • 2161
            • uk
            Ok thanks I cant find a replacement mainboard anywhere
            • dskall
              • Oct 2016
              • 2905
              • usa
              Have you checked mainboard voltages? Try heating up your processor to see if TV will turn on?
              • tvguy12012012120
                by tvguy12012012120
                02-07-2025, 05:13 PM
              • fharris1977
                Vizio D50u-D1 Dead Set No Standby
                by fharris1977
                Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                12-28-2023, 10:25 AM
              • Crystaleyes
                Samsung BN44-00259A standby question
                by Crystaleyes
                Hi all.
                I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                08-11-2023, 05:15 AM
              • psssst
                Yamaha TSX 120 Standby Problem
                by psssst
                Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                03-01-2024, 07:25 AM
              • ChristianBr01
                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                by ChristianBr01
                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                04-23-2025, 01:48 AM
