Old Kenmore Clothes Dryer
  • clearchris
    • Dec 2013
    • 687
    So, this is a very, very old dryer, and I love it. I can take it apart almost with my eyes closed, it's usually very easy to repair. Anyway, the timer module refuses to advance. I replaced the timer module with a used one (new unavailable), it worked for a few weeks, and now the new (used) timer module isn't advancing again.
    I opened up the first bad timer module, and the RSI contact was pretty toasty, there was a nearby burn mark like it suffered a big arc at one point. While I had everything apart, I tested the timer motor and it appeared to work. I cleaned the RSI contact and reassembed it.
    I have attached the dryer schematic, and there's a note, which seems relevant, but I don't understand what is going on. "With TM-RSI closed, timer motor does not run until a heat contact opens." Looking at the schematic, I'm completely unable to explain why one of the heat contacts opening up would make the timer motor run.
    Can anyone explain this? I'm having a terrible time troubleshooting this when I don't understand the theory at work. Thanks!
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Old Kenmore Clothes Dryer
    The timer switch in the lowest circuit with the heater element is closed by a coil in the timer motor circuit when the Tm is connected to CS. When one of the heat contacts in the heat element circuit opens to control the heat in the dryer the TM returns to RSi to continue run the timing through the 240-volt circuit through the resistor and heat element. I do not see the control coils on the schematic, so I am going from prior knowledge. If you look at the table to the right it will tell you when each switch is being used for each setting. Possible cause of burn contact is resistor value being too low. That is RS to RS. Need to look up the part number and measure the resistor if you cannot see reading on the resistor. and measure out of circuit with ohm meter. I thought the switch timer was on a coil, but I believe it is indeed a manual timer. This dryer must be old I believe all the switches are mechanical switches.
      • Jul 2011
      • 6057
      First of all the RSI is only active when it is in auto mode
      Second of all the reason why there is a high value resistor on this circuit is because when the heater is on it does not have enough current to run the timer until it open then the current can flow through the heater element to run the timer motor
      In refrigerator they do the same thing with the door heater circuit controlling some circuit which right at moment I remember the device it powers but I learn about this in a appliance repair class years ago and it was a hard for me to understand it at first
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        The cs timer circuit and the heater element circuit are two different circuits one goes to 120V the other to 240V. It you go to the table to cs you will see that the timer still runs. The timer motor runs off 120V. When it connects to RSi it connects to the 240V. The 240V circuits has the heating element in series with the 120v timer motor and the resistor. Looks like all the switches are mechanical. Very old dryer. Well before the late 1980's
          • Jul 2011
          • 6057
          I did remember what the device was that the door was feed from the compressor motor windings
          I left something in my description about why the timer motor does not run when the heater is activated is even thought it has 240 volts and has a drop down series resistor is because it is a 110 volt timer motor and also remember that current takes path of the least resistance and when heater elements is activated it is the least resistance not the timer motor but when the heater element is not activated it is the next least in the path of least resistance
          The reason why it was done this way for automatic mode back then they did not have moisture sensor like do now but the principle is basically the same in that when the drier get to temperature it then the timer runs until the temperature cools down and activates the heater element again the amount of time the timer is running in theory the drier the cloth are
          You do not see this type of circuit very often and when people see this type circuit they are confused by it
          • clearchris
            • Dec 2013
            • 687
            You can say that again! Thanks everyone, I'll check the resistor, it's quite possible it's fried or out of spec.
            And yeah, it's probably from the 70-80s, possibly the late 60s. But it just works, the dryer is a monster that just does it's job. A few years back I replaced the belt, the felt seal, the rollers, and the wear parts are good to go for another 40 years.
            Newer models, you hear about the drum cracking and all other kind of silly stuff because the manufacturers wanted to save a few bucks. Not this one, it's built like a tank and made to be repairable. This is the only issue that has given me grief. It's still on the original heater too. And now I have a spare timer (assume the new timer needs some contacts cleaned as well), the only really hard to find part for this machine.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              It was confusing and at first, I had thought what you said previously but, looking a little farther I saw the two voltages. I had assumed they just did not list the coils that control the switches in the schematic until I looked at the read out for what closes when. That read out is like a matric where you can read across and also read down That is when I realized all the switches are mechanical that are controlled by the operator when they turn on the settings.
              • keeney123
                Lauren
                • Sep 2014
                • 2536
                That is what I miss about the old days. A piece of equipment that does its function and keeps on running. I believe this is attributed to simplicity in design and the ability to repair it.
                Just make sure the resistor is the cause of the burnt contact by measuring it and then looking up the part number. The resistor would need to be lower in value to cause the contacts to burn out.
                The mechanical switches are set by the operator. When the timing motor times out, they return to the original states. That is almost too simple to understand.
                Also, make sure that the centrifugal motor switch is open when you first turn on the switch to RSI. Basically, you can just ohm out the centrifugal switch from the heating element to L2 with the dryer unplugged from the AC receptacle. If you read a short, then you will have to replace the centrifugal switch.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Is this your timer part? This one is new.
                  https://www.genuineapplianceparts.co...b5cb6a07843f27
                  • Joe24
                    Maytag Whirlpool Kenmore clothes dryer data bus
                    by Joe24
                    Patient is a Maytag/Whirlpool/Kenmore clothes dryer. Not sure of exact model, doesn't matter. All boards are out of production.
                    Specific problem is a Maytag 8544799 / WP8544799 motor-control board, aka Diehl Controls 708879-05. Customer states the board "doesn't work, motor doesn't run". Not sure how the repairman made that assessment, or if it's even accurate. He can't get replacement boards, and the owner decided to buy a new dryer, so whether this board is the problem is speculation on his part. Again, doesn't matter.
                    I've been over the board looking for...
                    01-13-2025, 06:50 PM
                  • connorcc2005
                    Kenmore refrigerator adaptive defrost timer fix. Part: AP4909015
                    by connorcc2005
                    I have a 20 year old Kenmore side by side refrigerator that was acting up with the following issues:
                    • Evaporator coil in the freezer was frozen up.
                    • Unit was still holding temperature
                    • Evaporator fan would run 2 to 3 seconds on then shut off only to repeat.
                    Defrosted the evaporator coil and began testing. Defrost heater ohmed out good. Defrost thermal switch on the evaporator line in the freezer tested good. Once the evaporator coil was defrosted, the freezer and fridge worked but the fan continued to cycle on and off continuously. I suspect the evaporator coil was destined to freeze up again...
                    03-20-2024, 01:14 PM
                  • juergenb
                    Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                    by juergenb
                    i am asking for some Help.
                    I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                    The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                    So i got a few of these from Banggood.
                    I swapped the motor and now i have a new fault condition.
                    In a working Frother you would press the start button, it will light red and work for a few minutes.
                    If you press longer it will light blue and just mixup the milk.
                    With the new Motor it just starts...
                    03-23-2021, 11:24 AM
                  • sbt123
                    charnwood w821 mini wood lathe motor problem
                    by sbt123
                    hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                    10-27-2024, 03:43 AM
                  • tmcw
                    Tumble Dryer - motor start capacitor
                    by tmcw
                    I was looking for a replacement capacitor for a tumble dryer, and I found one on eBay that has the correct values, and even looked similar, but of course, when the capacitor arrived, it didn't look like the cap in the listing picture.
                    I've attached the old (left) and the replacement (right) caps in a picture. The new one has plastic housing, the old one has a metal housing and is bigger. Am I likely to have any issues with this replacement?
                    Thanks....
                    05-09-2022, 09:11 AM
