907A knockoff soldering handle voltage
  • spleenharvester
    • Mar 2010
    • 921
    Hi all
    Element just blew on my 907A knockoff handle. I've ordered a new one, but checked the voltage at the element and it's reading in as 30V AC. Is this enough to kill the element, it should be 24V right?
    Cheers
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • petehall347
    • Jan 2015
    • 4446
    • United Kingdom
    Re: 907A knockoff soldering handle voltage
    is that voltage unloaded ?
    • redwire
      • Dec 2010
      • 3912
      30VAC is about 25% high, which is typical for a cheap 24VAC power transformer with no load present. It also depends on if you have high mains voltage as well.
      With the heater load it would sag down to ~24VAC, a transformer's voltage rating is under full load and they jump up a fair bit higher with no load. It's worse with lower quality/cheap transformers, or the chinese realizing the soldering iron heater is never on 100% of the time so they undersize the transformer in the first place. The smaller the transformer, the worse their regulation is. In the old days you over-designed and put in a real say 3A 75VA transformer which would be huge and have 15% regulation but nowadays price is all that matters, copper and steel are expensive.
      • Peter_1402
        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
        by Peter_1402
        Hi Everyone,
        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
        1. Soldering iron works great
        2. There is a burnt mark on the hot air gun handle.
        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
        Reed switch tested ok with a magnet.
        From the above test, I can conclude...
        07-12-2025, 11:50 AM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
      • electron_jj
        Panasonic TH-L42D25A checking the PSU output voltage
        by electron_jj
        Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
        I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
        08-29-2021, 08:13 AM
        ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
        3+1 Voltage Regulator for IMVP-7/VR12 CPUs
        Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
        core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
        configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
        serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
        Based on Intersil's Robust Ripple Regulator...
        11-05-2024, 03:24 PM
      • ruletero
        Acer a515-43 low battery charge voltage
        by ruletero
        Hi
        Acer A515-43
        LA-H801P
        Fail: Does not charge battery, has low voltaje on connector.
        Laptop didn't want to turn on, only charge led blinked.
        I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
        I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
        Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
        10-24-2022, 02:31 PM
