Common Failures on a GE Fridge Board Example (WR55X10775, WR55X11072 200D4852G025)
  • JDC
    • May 2015
    • 273
    I've worked on more than a few of these boards and the outlined parts in red seemed to be the most common. These board vary in parts, especially the number of relays on them. The part numbers listed in the title are examples.
    These boards (like most appliance boards nowadays) have a kind of protective shellac coated on them. I use professional strength Good Off on solder joins to remove what I can so I can get good contact with my meter leads.
    A schematic exists showing what each relay is responsible but I don't have that handy right now.
  • erdos
    • Jul 2012
    • 15
    Re: Common Failures on a GE Fridge Board Example (WR55X10775, WR55X11072 200D4852G025
    I have a GE fridge (Model Number GSS23GSKNCSS) that recently gone south. the issue is that defrost heater doesn't turn on as expected. I replaced the main control board (part #WR55X31689) to get defrost function working again. I'm curious how I proceed with diagnosing the defrost issue and find corresponding component on the board.
    • redwire
      • Dec 2010
      • 3912
      Fixing appliance control boards, first look at the soldering for the relays and connectors. Those seems OK in the pictures though.
      But there's some kind of soldering disaster just under the transformer where "70633401.1" is printed on the board, above R163, R166. What happened there?
      It's got 5 relays, which one is for the defrost heater? K6 bigger for the compressor motor.
      For now I would guess it's a bad relay for the defrost heater. Defrost function sometimes includes a temperature sensor at the evaporator.
      AiSHi brand chinese electrolytic capacitors I don't find that good, the blue ones like C111 and neighbors I would test too.
      I see a tiny fuse "M3" near J15 pads, as well as the main Belfuse by C88 if anyone else works on one of these.
      • erdos
        • Jul 2012
        • 15
        thank you for the reply! that's very helpful! I'll look into above mentioned components for potential failure.
        K4 seems to be the relay for defrost heater, since to its left, L1 is marked as compressor / defrost.
        • mikey5791
          Help repair Panasonic fridge not cooling
          by mikey5791
          Hi all forum members,
          Few days ago, i might have forgotten to close my home fridge freezer door completely. The next day, the ice cubes and frozen meat almost melted halfway and the freezer doesn't feel cool. I shut it off, wipe dry and let it air dry for one whole day. The next day i switched on the fridge, the compressor run for a second and it shuts off(no vibration and no sound at all) only the internal freezer compartment fan is running but is not cooling even i switched on a full day.
          After shut off, i dismantle the rear water pan holder and reached to the compressor wiring....
          07-16-2025, 02:01 AM
        • CG2
          Liebherr Fridge Freezer KGT 3456 not working
          by CG2
          To be a bit more specific, I've got a 20-ish year old Liebherr that has just stopped working. This was quite a sophisticated beast for its time. It's a twin compressor model, and you set the desired temperatures of the fridge and freezer parts from a couple of little control panels above the door. It displays the actual temps on some eight segment displays there, flashing if it's working to get to where you want it. There's a control board with a microprocessor on it that read the temperature from a couple of sensors, switches the compressors on as necessary, and runs the display. There's also...
          01-25-2023, 02:12 PM
        • tmcw
          Fridge - Gram
          by tmcw
          Have this fridge, laboratory grade unit, not working fully.
          It's designed with a chilling unit at the top, on the inside, and a fan just below that. When the door is closed, the fan blows the cold air down through the fridge, and when the door opens, the fan switches off, presumably so that it doesn't blow all the cold air out.
          The fan isn't switching on, so in addition to not having uniform cold throughout the fridge, the chilling tubes tend to ice up. I took the lid off the top, electronics are in the lid, and when the door is opened and closed, I can hear the relevant...
          10-10-2023, 05:00 AM
        • J_T
          Operating frequency for motherboard common mode inductor/filter
          by J_T
          I have a question - I have replaced the PSU on my own iMac Pro. However, when removing the motherboard I knocked of a 120 OHM 30% 0.3A small surface mount common mode inductor/filter (~0602 size) in the ethernet circuit near the female RJ45 port.
          The closest match I can find on Mouser is 120 OHM common mode inductor at 100MHz - my question is this frequency correct for a motherboard? The schematic for the motherboard only provides '120 OHM 30% 0.3A' and the TDK part number does not return anything in google.
          Sorry, I am not experienced hence a basic question.
          01-04-2025, 05:54 AM
        • Liam.25
          Beko fridge compressor clicking
          by Liam.25
          our fridge and freezer stopped cooling last weekend, it’s a Beko fridge.
          looking at the bottom, I can hear the relay clicking on the plug attached to the compressor.
          There is also a 3uf capacitor, I’m thinking this is a run capacitor, I tested this with my fluke and and it measured at 1.5uf, so I replaced this (new one tested just over 3uf) so that’s where it should be.
          I was thinking this was the issue. The compressor seem to run for like a minute then shutoff again.
          inside the relay, there is a Klixon 4tm thermistor,...
          03-23-2024, 07:42 AM
